Racing Beat Race Flash
Old Feb 18, 2007 | 12:27 PM
staticlag's Avatar
The Professor
Ok, so I decided to get the racing beat race flash for my 2004 Mazda RX8.
On 2/16/2007, a friday, I sent my ECU via USPS to Racing Beat in Anaheim California.
Will post results when my ECU comes back. And will dyno when the weather here clears up.
The following are some questions I sent to Racing Beat reguarding the flash:
-----Original Message-----
Subject: ECU flash
Hello,
I was interested in purchasing the ECU reflash for the 2004 Mazda RX8 and was wondering about the difference between the Street and the Race versions of the flash.
Thanks,
Daniel
Subject: RE: ECU flash
The race version is intended for extended high RPM racing applications only on a car equipped with a very high flow open exhaust system (i.e. no cat converters). If you are using the car for street applications, the "standard" reflash is much better suited.
Best regards,
Jim Langer
Racing Beat, Inc.
714-779-8677
Fax 714-779-2902
www.racingbeat.com
Jim,
In reguards to the differences in flashes, could you please explain a bit further on the differences in the flashes? Does the race version change the OMP injection as compared to the street version? Is the Race version going to fry any cat in the system because of higher temps?
I have the Racing beat intake, exhaust, and ram air duct, and a high flow aftermarket catalytic converter. And was wondering if you think that I could gain additional performance by usage of the Race flash in my system.
Thanks,
Dan
Your question was forwarded to Jim Mederer, Racing Beat's co-founder and chief engineer, for review. The following is his reply to your inquiry:
The flashes we offer do not change the MOP. The pump already runs max at high rpm / high volumetric efficiency. The max inlet temp for the cat is 900C (1652 F). Our flash does increase the EGT, but in testing, it is still well below the limit. The stock PCM runs rich at high prm, so yes, you will gain some power by flashing the PCM.
Jim Mederer
The biggest thing that I am hoping for when I get my car back is:
-210 rwhp on 87 octane gas, with improved cooling.
My biggest fears are:
-the necessity to start using premium gas again
-dynoing lower than my already 203 rwhp
-cat failure within 5000 miles.
I should be recieving my ECU back in two weeks. Should arrive at RB on tuesday of next week, from there 1-2 days then 3 days to UPS it back to me. We shall see.
Old Feb 18, 2007 | 01:29 PM
alnielsen's Avatar
On 1/16/2007, a friday, I sent my ECU via USPS to Racing Beat in Anaheim California.
Do you mean 2/16/2007? I will be looking forward to your results.
Old Feb 18, 2007 | 01:34 PM
Charles R. Hill's Avatar
Owner of BHR
Or, if you want an immediate review you can p.m. "imrtommy" who not only has the re-flash and likes it, but says it enhances the nitrous oxide kit he has on his car. And Racing Beat tells people it won't work with nitrous........Tommy's glad he asked me to look into it for him.
Old Feb 18, 2007 | 01:41 PM
Fanman's Avatar
Why 2 weeks ? Usually they turn things around in a few days. But I am interested in hearing your results as I think I might be going to this next.
Old Feb 18, 2007 | 01:47 PM
Trekk's Avatar
Goat rider
I have the flash on my 06 and have no problems at all with it. I just gotta watch my tech a bit better cause hitting 10k rpm's isn't very hard.
I wouldn't run 87, just because the difference between that and 93 is very small in price.
The car does seem to pull nice after the 5500 area. I'm not saying its from added power (cause i dont know if it added power) but its from consistent power to the redline.
Hmmm maybe ill go make a video of it today and post it up. So you can watch the RPM's
Old Feb 18, 2007 | 02:02 PM
Brettus's Avatar
Boosted Kiwi
keep a close eye on this . I found detonation with a heat soaked motor once I leaned out the AFRs .
Old Feb 18, 2007 | 02:58 PM
you're dreaming if you think you'll get 210 RWHP on 87 octane fuel
Old Feb 18, 2007 | 03:07 PM
Cody Red's Avatar
always filling [the c]up
You're using 87 octane? Dang.
oh well, can't wait to see the results.
-Cody
Old Feb 18, 2007 | 07:46 PM
Owner of BHR
The power you feel above 5,500 is from the re-flash. That's where RB focused their attention.
Old Feb 18, 2007 | 09:45 PM
8rotor8's Avatar
Back in the day...
I got the flash for my 05 friday too. And damn... it's fun to drive the car again. It holds the power to about 9700k. Worth every penny if you are staying NA
Old Feb 18, 2007 | 09:53 PM
1stgen8's Avatar
Just curious to know what other mods do you have? I'm thinking about the flash also. I currently have a custom CAI and Greddy exhaust. I want to add the flash and AEM pulleys next.
Old Feb 18, 2007 | 11:03 PM
romycha1's Avatar
I would like to get the flash, but this is my only vehicle, and I would be without transportation, if I pulled the ECU. How long does shipping and the reflash take? Also, can it be done to a stock vehicle?
Old Feb 18, 2007 | 11:16 PM
brillo's Avatar
Go Texas Longhorns!
So is there a race flash or not? I just emailed Jim to ask, my new HF cat can handle near continous 2,000* temps, so I can handle what ever this flash can do.
Old Feb 18, 2007 | 11:24 PM
yes
Old Feb 19, 2007 | 12:45 AM
chickenwafer's Avatar
Nope
I am very interested in this as well please post dyno results (pre and post)
Old Feb 19, 2007 | 01:22 AM
8rotor8's Avatar
Back in the day...
I have so far the Revi w/ duct, RB exhuast, RB spark plugs wires and the flash.
The flash really adjust the fuel curve so it leans out in the uppers RPM's. Any NA mods you do with the flash will only make it feel faster. The main difference I felt was after 6K it just keeps pulling instead of leveling off like it did stock. When I got it I was driving around topping off 2nd and 3rd gear like crazy!
Old Feb 19, 2007 | 06:20 AM
RotorManiac's Avatar
Absolute Rotary Madness
....I should be recieving my ECU back in two weeks. Should arrive at RB on tuesday of next week, from there 1-2 days then 3 days to UPS it back to me. We shall see.
I hope you get good results, I am really curious to see them
Old Feb 19, 2007 | 06:32 AM
So what happens if I get this RACE flash and keep a CAT. Will it kill the CAt or any other Negative effects to the car ?
Old Feb 19, 2007 | 07:21 AM
Trekk's Avatar
Goat rider
The rx8 already runs very hot stock and can destroy a cat pretty easy. Lean out the fuel (racing flash) and the EGT's will just get higher and higher.
If your gonna waste money on that you might as well get a catless pipe to pick up the extra 5-8 hp (maybe up to 10) it can free up.
Old Feb 19, 2007 | 08:08 AM
If thats the case then I might as well get a catless pipe with RB flash. but I need one with resonator or else my gf going to kill me. (cant let her know I have a Catless 8 .....)
Old Feb 19, 2007 | 09:30 AM
dgrx8's Avatar
FN GR8
my wife didn't notice the sound difference when i got my resonated b&b midpipe ... but all she does now is complain about how bad it smells!!!
Old Feb 19, 2007 | 03:09 PM
8rotor8's Avatar
Back in the day...
The rx-8 stock doesn't produce enough heat stock to kill the cat. Mazda made it rich for a safety measure. Read RB's R&D, they leaned it out to a safe level.
Old Feb 19, 2007 | 04:10 PM
brillo's Avatar
Go Texas Longhorns!
Here is Jim's reply to my email
The street flash was developed on a completely stock engine. We tested all rpm ranges and found that only the upper ranges could be improved. We have also built race engines and we found that, with no muffler and a few other mods, the mid range needed a bit more fuel and the high rpm requirements were slightly different, so we made a map for that. For a muffled street engine, we recommend only the street flash. Each flash was the best we could do for that circumstance.
Jim Mederer
Old Feb 19, 2007 | 04:17 PM
Owner of BHR
imrtommy, at my suggestion, informed RB that he was using a cat-less midpipe and he was under the impression that they took that into consideration on which flash to use. A 3" exhaust with no cat doesn't pose much of a restriction, if any, so I would order the race flash if/when I decide to do it. One strange thing that has happened each time I wrote RB is that they don't seem to fully read that which is written (kinda like many of us on this forum) and their answers rarely addressed the specific question I was asking. I wrote to inquire about the re-flash with nitrous and they kept assuming I was talking about a "dry" system. This went back and forth three times before I just decided to figure it out for myself after reading their website.
Old Feb 19, 2007 | 06:32 PM
staticlag's Avatar
The Professor
Hearing that makes me hope even more for the best with my system. Hopefully my current mods will not have any ill effects on what the race flash is programmed to do.
Such is the chance anyone takes when getting a "canned" tune, as opposed to a custom one.
I will post the exact numbers of my last dyno, all i have to do it type them into an excel sheet.
