HELP my car is dying... ignition issues
Old Jan 25, 2007 | 05:48 PM
LiL BenNy's Avatar
Bubblicious? DEF.
Exclamation HELP my car is dying... ignition issues
recently my car's cel went on (flashign and now its solid)... when i was starteding the car up it didnt want to start and was bogging.. it was trying to stall out so i continuously revved it. the rpms went up REALLY slow. when i was driving it i kinda pounded on it because if felt like something was clogged... so i tried getting it out lol... the car pulled AMAZINGLY harder yet somethings wrong.
i brought it to mazda and they said it was something with my ignition. because of my mods they wont do any warrenty work. (understandable i guess.)
i have the viper remotestart, greddy sp2, aem cai, and ap pullies (engine mods) the remote started tappers into the ignition coil voids warrenty.... does anyone have a clue what could be wrong?
besides dealer where else can i get my car looked at?
thanks in advance
-benny
Old Jan 25, 2007 | 06:52 PM
https://www.rx8club.com/series-i-trouble-shooting-95/burned-my-coils-weekend-question-rx-8-gurus-107453/
Old Jan 27, 2007 | 11:01 AM
LiL BenNy's Avatar
Bubblicious? DEF.
CEL is a PO300 can anyone help? random misfire? i believe its the coils aswell...
Old Jan 27, 2007 | 11:02 AM
LiL BenNy's Avatar
Bubblicious? DEF.
how bad is it to be running bad coils? mazda said they want to charge 250ish for one coil and install... since i have an intake and and alarm that taps in to the ignition coil...
Old Jan 27, 2007 | 11:25 AM
I think the new coils are $20 ish......it takes removing one bolt and a weatherpac connector (plug) to remove them.
It would take about 30 min to replace all four with no mechanical ability at all.
$250....that is "Bend over Pricing"
Old Jan 27, 2007 | 11:28 AM
You can get a missfire from other problems as well...hopefully they actually diagnosed that the ignition was the problem...it could be a lot of other things...
I had that code with a dead coil...If it is not firing at all....the plug will be black and fouled......
They tend to fail intermittintly at first..and then completely. If it's a trailing plug like mine...it will actually run OK except at idle and real high RPM...a leading will run more crappy all the time.
Old Jan 28, 2007 | 11:36 AM
LiL BenNy's Avatar
Bubblicious? DEF.
so changing the coils isnt hard? what plugs should i get to replace them? from what ive heard majority of the people think its the coils so i think i may just take a stab at it.. what else could this possibly be?
for me its when i start up the car it grumbles and when i rev it moves up slow. it idles at about 2krpm for a while... then when im driving it accelerates slow then at about 3800rpm it finally wants to go but im already shifting at 4k so it a really awkward jerk.. also sometimes i have to ride the clutch inorder to get out of first otherwise it will bogg out and stall, and other times it just boggs and moves realllllly slowly...
Old Jan 28, 2007 | 12:53 PM
It will bog at 4K when it is cold......and 2K is normal for a cold start for a bit..
Have you installed a turbo yet...if so...sounds like you need a tune bad!
Old Jan 28, 2007 | 06:41 PM
LiL BenNy's Avatar
Bubblicious? DEF.
thats why i WANT to put the turbo in.. i feel like mazdas a bunch of retarts. i think they're flashes are *** and they go backwards. the flash i had in the summer was the best ive had. completely regret getting the update. now i hope to get the turbo installed and with the intx get a good tune so my car doenst run retarted.
Old Jan 29, 2007 | 12:41 AM
get new plugs and aftermarket plug wires to go with the coils, the Magnecor wires are very good and should especially be used with FI, the OE plug wires are junk and will cause this problem, you might try those first, also try resetting your eccentric plate calibration doing the in-car brake tap method, the calibration is directly related to proper ignition operation
Old Jan 29, 2007 | 04:45 PM
LiL BenNy's Avatar
Bubblicious? DEF.
is this the break taping until the oil light comes on?
http://www.mazdatrix.com/8ignition.htm
get the 8.5 or 10mm?
ok im really stupid how many ignition coils do we have? and the ones i need are the last ones on the page? should i go aftermarket? and coils and spark plugs the same thing?
Old Jan 29, 2007 | 07:15 PM
I think you need to find a mechanic or shop to help you out a bit....
4 coils...one per plug....either will work for wires
Most aftermarket coils will cause install problems...they won't be plug and play...so not a DIY unless you know what you are doing....
Old Feb 5, 2007 | 11:33 AM
LiL BenNy's Avatar
Bubblicious? DEF.
im playing to go fi (turbo) would it be fine if i ran colder plugs for now untill i get the turbo installed? since i need my coils and plugs replaced...
Old Feb 6, 2007 | 01:04 PM
LiL BenNy's Avatar
Bubblicious? DEF.
what plugs and coils should i get for the greddy turbo kit?
delicious_dallan
Jan 17, 2020 09:17 AM
marc2820
Jul 26, 2015 10:47 PM
madrotor
Jul 26, 2015 12:06 PM
dbarber
Jul 25, 2015 01:34 PM
thedragonrotar
Jul 22, 2015 08:46 PM
