So, you want to be a tuner? Look no further.
Old Aug 24, 2015 | 06:23 PM
  #301
FOUND IT !!!
Good news and bad . I found the map that affects the transition at low rpm WOT from CL into OL . Bad news is ................ it isn't available on the Cobb AP .
Here is what the stock map looks like :
Old Aug 24, 2015 | 07:08 PM
  #302
FazdaRX_8's Avatar
Nice,
well its just another reason why mazdaedit is better.
now if only you could relabel them on the fly
Old Aug 24, 2015 | 07:11 PM
  #303
Awesome Brettus! Wish ATR had that. For what it is worth I was able to take care of the boost transition with CL targets.
Old Aug 24, 2015 | 08:37 PM
  #304
yeah ...been doing that also but I think this will work even better .
Old Aug 25, 2015 | 08:14 AM
  #305
Kane's Avatar
Senior Member
Wierd. I've never had a problem getting an 8 out of Closed Loop.
Is this unique to the series 2 maybe, or past 2007 ECU's I wonder?
Old Aug 25, 2015 | 11:01 AM
  #306
blu3dragon's Avatar
Mmm, nice find. Might explain why my s2 likes to be in closed loop so much. Not too bothered as I am NA, but still useful.
Looking back at my logs, it seems my car switches to OL once load goes over 100:
Old Aug 25, 2015 | 02:04 PM
  #307
Here is one I just dug from another series 2 map which is the same as some of the series one maps I just looked at as well:
Couldn't find any that looked like yours in Mazdaedit but I have tuned a couple with the AP that have done exactly the same thing as yours so must be the same . I would change that map back to 80 or so as your N/A loads are higher than most and could be running a little lean before the switchover.
Old Aug 25, 2015 | 02:10 PM
  #308
It isn't a problem on most 8's as they exit in the 80s (which happens as soon as you mash the throttle) . But I've seen a couple of cars that have been exactly like Bluedragons that exit at 100 (both series 1s) and it does cause some issues when tuning for FI.
Old Aug 25, 2015 | 02:31 PM
  #309
paimon.soror's Avatar
I haven't been reading up to see what the fuss is about regarding this map, but i can dump mine when i get home if you need more data points on S2's ... mine is a 2010 w/ a Cali ECU (According to vin).
Old Aug 25, 2015 | 03:11 PM
  #310
blu3dragon's Avatar
I'd be interested to see yours Paimon. Mine is a 2010 CA car as well.
I did lower mine to go OL at 80-90 after my earlier post. I might lower it a bit more now I've seen the S2 graph from Brettus. I wonder why it would be set so differently on different cars?
Old Aug 25, 2015 | 03:18 PM
  #311
Just found another s2 map (US market) ..... exactly the same as yours . The other map I posted was from a car in Turkey.
Differences could be to do with emissions tuning
Old Aug 25, 2015 | 04:20 PM
  #312
Mine
Attached Thumbnails So, you want to be a tuner?  Look no further.-capture.png
Old Aug 25, 2015 | 04:33 PM
  #313
Kinda wierd ... look at the X axis numbers (column 1) on ours compared to the one Brettus posted ...
3500.............100.0
4000.............100.0
5490.............100.0
5500.............94.5
5990.............93.8
6000.............0.0
Old Aug 25, 2015 | 04:36 PM
  #314
Starts going down right about where the P2s fire up on an NA engine ...............
Old Aug 25, 2015 | 04:56 PM
  #315
I meant the gap between 4k and 5.4k on the adjustable values
Old Aug 25, 2015 | 05:03 PM
  #316
Looks like they wanted a sudden decline at 5500 rather than a steady transition.
Old Aug 25, 2015 | 06:51 PM
  #317
Any real benefits for an na engine to try and taper the graph to look like the turkey ecu?
Old Aug 25, 2015 | 06:56 PM
  #318
nah .... just flatline it at 80% and you will be good .
Old Aug 25, 2015 | 06:59 PM
  #319
You mean up to the 5500? Or across the board (6k)
Old Aug 25, 2015 | 07:03 PM
  #320
Yeah .... up to 5990 . Sorry
Old Aug 25, 2015 | 07:07 PM
  #321
sweet deal, i'll give it a go thx
Old Aug 25, 2015 | 07:39 PM
  #322
Fyi s2 owners. One of the recent (been months since I flashed an update to my exu) updates to mazda edit added a Speed4 ON and OFF to the fan speed/ECT 2d map that is set to about 120F. Just incase you flash and wonder why your car is loud as hell and sounding like a vacuum when you turn it on after a flash lol.
From my last testing it seems that speed1 and speed2 control the low fan speed and speed3 is high fan speed. Speed4 seems to also be high fan speed.
Not sure why we don't have control of the med speed yet
Old Sep 5, 2015 | 07:44 PM
  #323
AlienHack's Avatar
Halo guys. Although i just registered i have been reading these forums for one year now and have read all the tuning threads.
I own a 2004 european rx8 231 hp.
The car in general is great (drivability, the rotary engine itself, interior exterior etc) but at oem state its not superfast in strates. I had it dynoed and oem it gave 231 hp in crank.
I also hapen to have a honda s2000 so i have tested the cars in strates against each other. When they were both oem the S2000 from rolling 70km/h to 240 km/h was 3-4 cars ahead.
But i went on and upgraded my rx8s exhaust with full 76mm collector headers and 76mm test pipe and 76mm tube to double exhaust tips. This upgrade alone gave the 8 almost 10 hp in the dyno and on the road now it goes toe to toe with my s2000 and also 1 other oem s2000 i tried against. So the car witn exhaust alone , gained 3-4 cars difference on the road.
So now i am in a mode where i want to give that little extra power to the 8 so it can be faster than an oem s2000. I love the rotary engine its so smooth and i realy want to know that my 8 goes faster than my s2000.
So my question is, if i make a good mazdaedit tune (either to a tuner or by myself as i am an experienced ecu tuner and i already have a wideband installed ) lean out the a/f ratio from 11.2 i get now to a more agressive 12.3-12.5 and also give a more agressive spark avance what can i get in terms of power?
What gains have you guys seen on the road after a good tune? When testing your car witn a friends car did you gain 1 car after tune? 2 cars? 4? Has anyone tested that?
I dont want to go FI i just want 10more hps on my 8 that translate in 3-4 cars gain on the road... Can i get these with a good tune?
Old Sep 8, 2015 | 07:22 AM
  #324
Kane's Avatar
Senior Member
12.3-12.5 is too lean IMO for these engines.
From completely stock OEM tune to a ragged edge dyno tune, I've gained 13hp off of just the tune itself.
Old Sep 8, 2015 | 06:03 PM
  #325
AlienHack's Avatar
Hmmm if +13 hp is possible from tune alone maybe my 8 has hope... So i will go ahead and buy mazdaedit
