Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Official SARX Lounge
Old Nov 10, 2011 | 10:31 AM
  #5351
shadycrew31's Avatar
WENTGERMAN
Originally Posted by 9krpmrx8
Tidbit:
Don't use allen head bolts on the down pipe to turbo connection. I wanted to use them because they are stronger than grade 8 and heat treated for high temp use but they are impossible to get tight in that location. So now I am off to NAPA at lunch to high temp treat hex bolts. I did get the turbo bolted up and the lines ran though so the hard part is done.
I bought regular steel bolts at home depot...
Old Nov 10, 2011 | 10:57 AM
  #5352
When I took my engine to the engine shop the old guy at the shop told me to never use hardware store junk bolts (as he called them). So I actually did a bit of research as to what the numbers meant on the bolt heads and the differences between metric bolts and SAE bolts and I found the steel bolts I bought from Lowes were really low grade and not heat treated. The same goes for the bolts that Autozone, Oreilly's and Advance carry.
The guy at Advance told me only NAPA or fastenal would carry bolts like that. I did get some nuts from Fastenal and Advance special ordered the studs I needed but neither had what I wanted otherwise so I went to NAPA and got the allen head shoulder bolts I wanted because they are heat treated and Grade 12.9. They had the best assortment of high strength heat treated bolts so that is my go to place. They also have 10.9 (grade 8) hex bolts that are heat treated so I will go with those I guess since it is too tight of a fit to go with shoulder bolts.
Old Nov 10, 2011 | 11:12 AM
  #5353
WENTGERMAN
I figure I'm spending so much on my kit and building it exactly how I want. I should skimp and buy cheaper bolts to risk losing my entire investment...
Wait a minute....
Old Nov 10, 2011 | 11:33 AM
  #5354
Wait a minute....
, yeah I figured getting quality bolts, fittings, and hoses was probably a smart idea. Hopefully it is money well spent.
Old Nov 10, 2011 | 11:39 AM
  #5355
WENTGERMAN
I spent a premium on samco couplers and high end t bolt clamps skimping on bolts was really dumb of me. I am taking the bolts to Napa and getting proper ones.
You have a few exhaust studs left yes?
*edit after I get my GD suspension back together.
Old Nov 10, 2011 | 11:56 AM
  #5356
Yeah I have studs and 10.9 nuts for them left, I had to buy a bag of 25 of the nuts from fastenal. To use the studs I have will have to be cut if used on the bottom holes of the Greddy manifold as they are too long.
Old Nov 10, 2011 | 12:27 PM
  #5357
WENTGERMAN
Sweet any extra bolts you have I'll take off your hands when I'm ready to pop my turbo in.
Old Nov 10, 2011 | 01:26 PM
  #5358
I highly recommend studs on the manifold to turbo connection but only three, the fourth hole at the rear is a bitch to get too so I used a grade 8 heat treated hex bolt there with a lock washer since it was easy to get too using a rachet end wrench. using a stud and a nut there could be a pain but still doable.
The allen head shoulder bolts worked fine on the air pump port (using my RB block off plate) on the downpipe and the oil drain fitting so since I have them, You should use them at those areas. I also used allen head shoulder bolts and lock washers on the inlet pipe and outlet pipe of the turbine. The inlet requires two bolts of the same size but the turbine outlet pipe requires one shirt bolt and one long bolt. Shoulder bolts hold the inter-cooler to the brackets as well.
I'm gonna cross post this in my thread.
Old Nov 10, 2011 | 01:33 PM
  #5359
WENTGERMAN
I don't like Allen head bolts, I swore I'd never use them again after my 300zx days.
Old Nov 10, 2011 | 01:43 PM
  #5360
I have a set of allen head sockets so as long as they are fairly easy to get too they are good because they are grade 12.9 and very hard to break or to stretch from heat. 1500F-1800F is a lot of heat. But in tight spots they are a pain in the ***.
Old Nov 10, 2011 | 04:37 PM
  #5361
Grungepup's Avatar
Oilfield trash
shady.... you coming down on sat?
Old Nov 10, 2011 | 05:14 PM
  #5362
WENTGERMAN
If I have my bushing project done for sure!
Old Nov 10, 2011 | 05:29 PM
  #5363
How is that going?
  #5364
Grungepup's Avatar
Oilfield trash
just drive down without the bushing.... the ride will be ok
Old Nov 11, 2011 | 12:09 AM
  #5365
WENTGERMAN
How is that going?
Up to 4!!!!!!
LOL Wordddd fawk control arms they are def not needed!!
Old Nov 11, 2011 | 12:19 AM
  #5366
hoss -05's Avatar
Lucky #33
Bad *** shady. You should have them powder coated some crazy color as long as they are out... LOL
Old Nov 11, 2011 | 12:32 AM
  #5367
WENTGERMAN
Hmmmm
well i cant drive anywhere to get them coated...
But I might have some paint left over from my wheels wouldn't be a crazy color...
Maybe I have some blue engine paint left, ill look through my storage unit and see what I can find.
Old Nov 11, 2011 | 02:17 PM
  #5368
My car will never be a show car, I cleaned a lot and my underpinnings are still filthy.
Old Nov 11, 2011 | 03:10 PM
  #5369
WENTGERMAN
pfffft show cars are overrated
Old Nov 11, 2011 | 11:14 PM
  #5370
WENTGERMAN
Def not making it tomorrow haven't even finished one upper control arm.
Old Nov 13, 2011 | 03:39 PM
  #5371
WENTGERMAN
Success! sadly the housings for the upper control arms got damaged pretty bad. I smoothed it out and evened it out best I could.
I am in the final stages of cleaning the control arms and prepping them for install.
Old Nov 13, 2011 | 05:13 PM
  #5372
WENTGERMAN
Old Nov 13, 2011 | 11:17 PM
  #5373
WENTGERMAN
Well... Looks like I may have bent my upper control arms...
FML...
Old Nov 13, 2011 | 11:29 PM
  #5374
You bend one? How? That sucks.
Old Nov 13, 2011 | 11:47 PM
  #5375
WENTGERMAN
I'm pretty sure it happened when I pressed the sleeve out.
