2004 Rx8 staring problem =[
Old Mar 10, 2011 | 05:07 AM
Andyn8s's Avatar
BC 2004 Rx8 staring problem =[
My 8 has 42k on it and its 2004
i bought it year ago second hand dealer(non-mazda)
When i start up my car today....it took so long to start up my engine!!!!
just like the Thread: https://www.rx8club.com/series-i-tech-garage-22/does-your-rx8-make-sound-when-starting-212836/
Also, when i stop at red light...the car start shakng like crazy!!!
Since my car is second hand...do i still hv a chance to go to Mazda and ask for a check or even a new engine?
Im so depress right now cant even sleep...i love my 8 so much
Old Mar 10, 2011 | 06:16 AM
hoss -05's Avatar
Lucky #33
Sounds like your in need of new coils, plugs, wires and engine mounts! Have you changed any of them out yet?
Old Mar 10, 2011 | 08:39 AM
Swampdonkey's Avatar
I bought my car 2nd hand as well back in 07 and its a 2004 while I was stationed in Maryland. When I moved back home to Arkansas in 09 car started having same problems starting up like yorus. I replaced my coils and would fire up right away. Also I took car in for a checkup and turned out had no compression and they replaced motor core for free due to extended factory warranty.
Old Mar 10, 2011 | 09:13 AM
hoss -05's Avatar
Lucky #33
What he said! Do the coils wires and plugs on your own. Not a hard job and will save you a ton of money over the dealer cost. It really should be the first thing you try. There is currently a company in the vendor forum selling those parts at a great price.
Old Mar 10, 2011 | 03:35 PM
Andyn8s's Avatar
coils wires and plugs...hmm i should check it out !! thanks so much
i did search online ytd ....and ppl are hving the same problems becoz of the "old 04-07" starter.....maybe i should try that too?
And...unfortunately im not good at "fixing car" lol is it easy to replace coils wires and plugs on my own?
Thanks again!
Old Mar 10, 2011 | 03:46 PM
STL05's Avatar
CCastlefly05
Very easy to change those it will take 30 min. There are great DIY jobs on here.
https://www.rx8club.com/showthread.p...changing+coils
https://www.rx8club.com/showthread.p...rk+plug+change
Old Mar 10, 2011 | 04:00 PM
Andyn8s's Avatar
thanks!!!! i did lookup for the coils wires and plugs....
it costs $2xx and $3xx? am i looking at the wrong items? lol
sorry for stupid questions i dont know know much about cars im still learning =[
Old Mar 10, 2011 | 04:05 PM
you need 4 of these: http://onlinemazdaparts.com/partloca...layCatalogid=0
one of these: http://onlinemazdaparts.com/partloca...layCatalogid=0
and a full set of spark plugs which for some reason isn't working all that well on their website now but send them an email and they'll take care of it.
Old Mar 10, 2011 | 04:19 PM
1.3_LittersOfFurry's Avatar
Flame On!
You can get the set here too
http://raceroots.com/index.php/produ...on-bundle.html
-Shawn
Old Mar 10, 2011 | 04:35 PM
STL05's Avatar
CCastlefly05
or here prolly the cheapest around but i could be wrong
http://www.mazmart.com/ItemDetail.aspx?id=1903
Old Mar 10, 2011 | 07:28 PM
04Green's Avatar
Moder8
Given the age, I would look at the stuff in the First $100 thread below as well. Lots of little stuff can add up. You are very likely to need the plugs and coils though soon.
Welcome.
Old Mar 11, 2011 | 12:27 AM
Imdiesel06's Avatar
im havng the same problem, but i replaced my park plugs and wires last summer and i just checked them out today and they look shot. it looks like i have alot of carbon buildup witch i think means loss of compression. what did mazda say to you about the warrintie cause i have the extended one also but they want proff of every oil change?? im second owner and i dont have recipets
Old Mar 11, 2011 | 12:46 AM
Andyn8s's Avatar
My slow start problem seems to go away becoz i drive my 8 more offen these days!!! but the shaking problem is still there =[
hmm.....for the proof of oil change i do hv the them after i purchase the car.
but before purchase i dont. I do have the Report of the car about the condition and it says good on the report... maybe it helps? or Mazda need the full proof of oil change since the car was born? thats not possible =[
Sorry i cant help much
Old Mar 11, 2011 | 02:32 AM
hoss -05's Avatar
Lucky #33
Your car is a 2004 with over 40k it more then likely needs new motor mounts. It is a common problem with 2004-2005 cars. I would not focus on getting a new engine. At this moment I would focus on your motor mounts, coil packs, spark plugs and spark plug wires.
That being said Check with any Mazda dealer/service center and they can pull any service records they have for your VIN. You never know maybe the last owner got all the oil changes and services done at Mazda. Someone had mentioned mazmart I would check with those guys.
Old Mar 11, 2011 | 04:53 AM
PeteInLongBeach's Avatar
And MAF sensor cleaning....
Old Mar 11, 2011 | 11:38 AM
I was lucky enough to have my oil change receipts. I had to call every place in Maryland I got an oil change at and have them fax me copies though lol. I guess the only thing you might be able to do is just wait a few months and build up a few oil changes I know they required 10 from me dunno if thats the same everywhere but then go back with the paper work and hopefully it will work.
Old Mar 11, 2011 | 01:06 PM
hoss -05's Avatar
Lucky #33
Yep! Dont focus on the engine replacement for now. Your engine could be just fine.
Old Mar 12, 2011 | 04:04 PM
Andyn8s's Avatar
if i take my 8 to some repair shop....and ask for installing a new motor mounts is that ganna work? coz u know not many ppl know how to fix the 8......or are the motor mounts installation same on every vehicle?
thanks guys!!!
Old Mar 12, 2011 | 04:42 PM
Razz1's Avatar
Mu ha.. ha...
Same.. take an auto shop class.
Old Mar 12, 2011 | 05:00 PM
Andyn8s's Avatar
i looked up on the web and found a TSB:
http://www.finishlineperformance.com...21-06-1559.pdf
would this give me a free motor mounts if i show this to the mazda dealer?
Panthersn
Jul 13, 2021 06:30 AM
SUKIEE
Oct 9, 2017 09:41 PM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
Mr.Durden
Aug 12, 2015 02:21 PM
