What filter is this?
Old Aug 12, 2003 | 03:58 AM
M-ster's Avatar
Hi guys, I have did a search but can't quite find the answer here, so
what filter is that (that's circled in the picture).
Old Aug 12, 2003 | 04:00 AM
Lock & Load's Avatar
Thumbs up
Commonly known as oil filter.
Old Aug 12, 2003 | 04:19 AM
RobDickinson's Avatar
Commonly known as one of the 2 oil coolers.
oil filter is somewhere else....
Old Aug 12, 2003 | 04:23 AM
M-ster's Avatar
Thanks for the quick respond, kind of un-sightly isn't it, (the filter that is). Can't they be move to a more inconspicuous location?
Old Aug 12, 2003 | 05:02 AM
tribal azn2's Avatar
they are NOT OIL FILTERS, they are OIL COOLERS. like the radiator. thats the only place they can be. they wouldnt be able to cool if they were placed elsewhere.
Old Aug 12, 2003 | 08:03 AM
RX-8 Zoomster's Avatar
Tribal is right. That is one of the two oil coolers on the hi-performance engine (Manual). The automatic or standard engine has only one oil cooler. This is the oil filter, and where it is located.
Old Aug 12, 2003 | 08:44 AM
dcfc3s's Avatar
RX-7 Guru
On a rotary, the oil does a lot of the cooling work - it cools the inside of the rotors, and absorbs quite a bit of heat. Oil coolers are an absolute necessity.
Dale
Old Aug 12, 2003 | 10:44 AM
Elara's Avatar
I love this forum. I've learned so much about cars in general on here. When we walked outside this morning to go to work, I pointed that out to my husband and said "That's the oil cooler," like I knew that all along (I always read the boards before work). He just gave me a funny look.
Old Aug 12, 2003 | 12:11 PM
M-ster's Avatar
Thanks guys, thanks for clearing this.
The oil filter as we know will need to be changed in every oil change. How about the oil cooler, in looks and feels very much like an 'air filters' does it require frequent cleaning or changing?
cheers
Old Aug 12, 2003 | 03:36 PM
Sputnik's Avatar
cheers
The oil cooler is a radiator for the oil, not any kind of filter or consumable item. While you flush coolant regularly, you don't change the radiator. Same goes for the oil coolers.
---jps
Old Aug 12, 2003 | 05:36 PM
M-ster's Avatar
Got it! Very much like one of these oil cooler in the aftermarket add ons.
Thanks guys
Old Aug 12, 2003 | 05:56 PM
Thumbs up
Sorry m-ster i should have said oil cooler as the filter sits on top of engine and gets changed at regular intervalls , i have a head cold and wasnt thinking strait .
Old Aug 13, 2003 | 04:26 AM
cheers
As Sputnik said, there is no flush necessary. However, I would periodically check to make sure there was nothing obstucting the air flow, ie. leaves, paper, bugs, etc. Also I would make sure that the air fins do not become bent or pinched together, which would also obstruct air flow to a point. Same things to watch out for on your radiator.
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Jun 14, 2022 08:32 AM
airlive
Jun 28, 2020 07:46 AM
Danield97
Sep 30, 2015 05:59 PM
drlubell
Sep 26, 2015 11:58 PM
