G0t M4xx 21's custom install - clear Lexan Amp Rack
Old Jan 23, 2006 | 04:01 PM
G0t m4xx 21's Avatar
Xbox hacker
All righty, last weekend was a very busy weekend for me, finishing up my full custom A/V project.
It started off with installing a modded Xbox under my seat, which I use as a carputer, and an A/V server, and a 7 inch screen where the ashtray normally goes.
Later, I replaced the rear 6x9's with a pair of Infiniti Reference speakers.
Finally, I have installed TWO Soundstream Van Gogh Amps (one for the single Dayton 12" Sub, the other for those Infiniti rear speakers), a 1 farad capacitor, and fully hidden wiring through the trough under the door panel.
The Amps are in the divot in the trunk, mounded to a frosted Lexan plate. the bottom plate then has 5 standoffs to hold up the top plate, which protects the amps from whatever I put in the truck, and serves as a mount for the two fans, the capacitor, and a 12" red CCFL light.
Old Jan 23, 2006 | 04:07 PM
adrian-1's Avatar
Ex- member.
Sweet setup. Very CLEAN install.
Noticed your in Austin. Do you ever make the texasrxs.org meets at Rudy's? (It's the 1st Wednesday of every month at 7pm at Rudy's BBQ on 183). I will try to make it out next week.
Old Jan 23, 2006 | 11:31 PM
Xbox hacker
Yeah I went there once, nice group of people. I should be back out there soon.
Old Jan 24, 2006 | 12:30 AM
BlueEyes's Avatar
Can you take more pics from different angles of the screen please and thanks.
Old Jan 24, 2006 | 12:55 AM
Imidazole's Avatar
Like... uhm... how bout pics that actually include a view of the subs, eh?
Old Jan 24, 2006 | 02:43 AM
Tamas's Avatar
Registered Lunatic
Looks pretty - but be careful with that lexan, it can get scuffs and scratches in no time and then it would look really bad.
Old Jan 25, 2006 | 12:19 AM
Xbox hacker
A 7 inch screen is such a tight fit that I just dremeled away part of each side of the opening to fir the screen in there, and jsut let friction hold the screen in, there were no mount points for the screen since I had to remove the screen and its circuit board from its housing. The bezel just bolted on after the screen, and has the screen's controls mounted on it (power, menu, "+", "-", status LED, and the IR receiver for the remote.)
Here's some more screen pics:
Old Jan 25, 2006 | 12:18 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Very nice indeed, just on question. In the first picture it looks like your ground wire is smaller that your power wire...is that so?...why?
Old Jan 25, 2006 | 09:35 PM
Xbox hacker
No, they are both 4 gauge
Also, you can't really see it form the pics, but that Audiobahn cap is kinda rotor shaped, just a nice little touch.
Old Jan 26, 2006 | 12:48 PM
blacxicano's Avatar
What screen did you use?
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
just1jack
Sep 9, 2015 04:45 PM
blkswan
Sep 2, 2015 10:04 PM
