Starting Problem (don't think it's flooded)
Old Oct 16, 2005 | 02:17 PM
trainoffools's Avatar
Man of the Year
I did run it short yesterday after changing brake pads and moving it back into the garage but thought it was a warmed up enough. I've never had a flooded episode with my RX8 so not quite sure if it is or not. The first turnover it was just dead, no sound but all gauges and lights were very bright so it looked like the battery is fine. I tried again using the "flooded start" procedure in the manual and when I turn the key, the engine clicks very fast. Tried again three more times using accelerator pushed in all the way and also not pushed in at all and all I get is the fast clicking of the engine.
Any advice is appreciated.
Old Oct 16, 2005 | 02:23 PM
lurch519's Avatar
www.evoperform.com
either the battery is low, (has enough voltage to operate guages and such, but not enough to turn starter) or starter is bad. try charging the battery, if that doesnt work, take it to the dealer
Old Oct 20, 2005 | 01:26 PM
strokercharged95gt's Avatar
its flooded, i had to take off the front left wheel in myy driveway pull the fuel pump and injector fuse. yank off the spark plug wires, wratchet out the plugs and crank motor to eject gas. then put everything back, start it up and enjoy the smoke show.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Jaco Greyling
Jan 6, 2019 08:39 AM
Tyblat
9
Aug 6, 2015 10:43 AM
robd1337
Jul 31, 2015 09:35 PM
harithac
Jul 25, 2015 04:21 PM
