help w/ power outlet in center console not working
Old Dec 11, 2004 | 03:00 PM
bxb40's Avatar
Rotary Newbie
Question help w/ power outlet in center console not working
I was looking today to install a XM radio unit in the center console compartment (as I have the PIE AUX adapter there) and discovered that the power outlet is not working. The one next to the ash tray does work but would need it for the radar detector. Fuses seemed OK - any idea what/where to look for a cause?
Old Dec 11, 2004 | 05:03 PM
snap-on's Avatar
Have you ever had the console out? Or has the dealer ever had it out?
Maybe they forgot to connect it.
Old Dec 11, 2004 | 06:07 PM
TexasKyle's Avatar
Beeeep
Just a shot in the dark....did you have the car on? They dont work if the ignition isnt on....
Old Dec 11, 2004 | 09:11 PM
bxb40's Avatar
Rotary Newbie
Thanks, I'll pull the rear console out to check if it is connected. I had the front part out to install the PIE adaptor, maybe something is not set right.
Yes, the ignition was on, the ash tray one was working just fine.
Time to finish the XM install tomorrow
Old Dec 11, 2004 | 09:14 PM
My ashtray one stopped working yesterday...but my console is working....going to have to check it out tomorrow. could be socket, fuse? fused seperately? or plug disconnected?
Old Dec 11, 2004 | 09:48 PM
bxb40's Avatar
Rotary Newbie
There are two separate fuses for the two power outlets.
Old Dec 11, 2004 | 10:07 PM
truemagellen's Avatar
Attracts tree branches
just remember don't plug anything with a high load into the ashtray socket...it can't handle lots of amps like the center console one can
also you dont need to remove the center console to access the center console power outlet...just use a flathead screwdriver covered in tap and pop up the piece that holds the outlet...then pull it out...inspect it and you can put it back (considering that removing the back part of the center console takes ALOT more time then the front part of the center console)
Old Dec 12, 2004 | 03:04 PM
bxb40's Avatar
Rotary Newbie
Done. The wire harness was never connected to the power outlet (took a while to find it under the console). Everything A-OK now. XM radio rocks!
Thanks, guys.
Old Dec 12, 2004 | 04:51 PM
Tbone's Avatar
NW enthusiast
which one?
Which XM did you buy? the Roady2 or Commander, or another?
Trevor
Old Dec 12, 2004 | 05:22 PM
Trevor
Roadie 2 its in his sig
Old Dec 12, 2004 | 06:15 PM
irish8's Avatar
Get in ma belly!!
Thanks, guys.
Easy install? Does the brain fit well in the ash tray pocket? Where did you mount the antenna? I guess the song info is not displayed on the LCD?
Sorry for the Q's....just interested.
- Irish
fullsmoke
Nov 24, 2015 04:09 PM
SIllver
Aug 1, 2015 07:34 PM
MolecularConcept
Aug 1, 2015 03:15 PM
escapedan
Series I Do It Yourself Forum
Jul 29, 2015 10:44 PM
yapakanichi
16
Jul 28, 2015 03:44 PM
