aftermarket deck install...no sound:s
Old Apr 11, 2010 | 06:13 PM
sr101's Avatar
I installed a JVC single DIN deck today, wired everything up, put the dash kit in turned it on (powers up fine) used a test light to all the wires...12v, ign, amp turn on everything lights up but nothings coming out of the speakers:s I do have the bose system so im wondering if theres a blown fuse on the factory amp? If anyone could chime in thatd be great..def lost here
Old Apr 12, 2010 | 03:32 PM
sr101's Avatar
I got the day off so I was going to pull the amp and test it out, can anyone tell me where it's located?
Old Apr 12, 2010 | 03:36 PM
The Reverend's Avatar
That's a lie
stick your head in the trunk and look straight up, between the two speakers it is held up
Old Apr 12, 2010 | 08:29 PM
sr101's Avatar
alright so I unplugged the amp and jumped a wire to one of the speakers and poof! music was playing...crazy how my amp would blow just as I install a deck:S anyone have a 4 channel amp for sale? haha
Old Apr 12, 2010 | 09:07 PM
He||hammer's Avatar
Destroyer of Dreams
I know this might be a pain but, you should try unplugging new H/U and hook up old bose and see if it is the amp or maybe the install, I've heard the bose can be tricky.
Old Apr 15, 2010 | 11:59 AM
mbentley's Avatar
zoom-zoom
did you connect the speaker outputs directly to the wiring harness or did you use line output converters to go from the RCA outs to the wiring harness?
Old Apr 18, 2010 | 09:52 PM
firebirdude's Avatar
User and Abuser
SERIOUSLY doubt your Bose amp fried all by itself. Seriously doubt it's fried at all.
Old Jun 7, 2010 | 09:19 PM
neokhz's Avatar
Ok so I am having the same issue. I just installed a Kenwood navi with the METRA
95-7510HG, all controls worked fine however I have no sound. I pulled it out and checked all wires, still nothing. I even took an rca and cut it up and went from the line out to the speaker connections and still nothing. Anyone have any ideas. Is there another adapter that I need for the bose or is it maybe a bad kit? I know the Kenwood works. We even tested it back in my truck that I just deinstalled it from yesterday.
Old Jun 7, 2010 | 09:22 PM
User and Abuser
??? You mean you cut the end off an RCA cable and touched it directly to the speaker's + and - terminals?
I'm no Bose expert, but something like this usually means the remote turn on for the stock amp is not connected.
Old Jun 7, 2010 | 09:23 PM
mbentley's Avatar
zoom-zoom
did you connect the amp turn on (remote) wire to the wiring harness? it will be the blue or blue/white wire. you need to connect that to turn on the Bose amp
Old Jun 7, 2010 | 09:32 PM
neokhz's Avatar
I might be the biggest idiot, It has been along time since I have done an install... Let me check it and I will let you guys know if I am a tool...
Old Jun 8, 2010 | 06:56 AM
User and Abuser
Is there an echo in here?
Old Jun 12, 2010 | 01:51 PM
m.morales84's Avatar
zoom-zoom
i have the same issue i connect all wires but no sound! if anyone knows how connect(right way) the wires to the unit please let us know!!!!! thanks
Old Jun 13, 2010 | 05:56 AM
mbentley's Avatar
zoom-zoom
...so did sr101 and neokhz get their problems solved or not?
Old Jun 14, 2010 | 12:01 PM
sr101's Avatar
I tried hacking in some RCA terminals and still couldn't get sound so I gave up and installed a 4 channel and upgraded all the speakers. Works great now haha, thanks for all the input
fc2se
NE For Sale/Wanted
Jun 1, 2016 08:55 PM
RX-8 Racing
20
May 14, 2016 06:25 PM
Rote8
Sep 22, 2015 03:43 PM
Wurromurro
Sep 20, 2015 05:02 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
