Resetting the AC, what does it do?
Old Aug 16, 2009 | 07:10 PM
tmak26b's Avatar
I am just curious as to what happens to the AC system after the reset? I did the AC reset as instructed on rx8blog.com. I do have to admit it actually works as my AC cycles less and it is noticeably colder.
Old Aug 16, 2009 | 07:24 PM
Low Fly'n 8's Avatar
I believe it just defaults to "reirc" anytime you turn the air on.
AC RESET:
1. Make sure the car is off AND the HVAC fan is off AND the A/C on/off button is off.
2. Press and hold the front defroster (on the left) AND air source (recirc/fresh air) buttons
3. Continue pressing the buttons in step 2 and turn the key to ACC for 3 seconds
4. Continue pressing the buttons in step 2 and further turn the key to ON (NOT START) for 3 sec.
5. Verify the programming update by observing the REAR defroster LED blink 3 times.
6. Release the two buttons from step 2 and start the car.
Old Aug 17, 2009 | 12:31 AM
you answered your own question.
it keeps the compressor from cycling as often, and when you turn it to full cold it switches to recirc... and yes, it helps a lot.
Old Aug 17, 2009 | 11:28 AM
Nubo's Avatar
Lubricious
Changes the "duty cycle"
from
on-off-on-off-on-off-on-off
to
on............off...on............off...on........ .....
And puts AC in recirc mode whenever ambient temp is over 68F, temp set to min. and vents are in "face mode.
Old Aug 17, 2009 | 02:22 PM
tmak26b's Avatar
What makes the system cycle less before the set?
Old Aug 20, 2009 | 12:23 AM
programing of ac amplifier..
Old Aug 20, 2009 | 12:28 AM
Cool, have to try this.
cliffkemp
Dec 24, 2024 10:48 AM
OnebaddRx8
Aug 25, 2019 11:34 PM
fistofmeat
Oct 7, 2016 12:15 PM
TheRedRotor
Sep 22, 2015 05:30 AM
iwannarun
Sep 6, 2015 01:37 PM
