td04 turbo
Old Jul 7, 2009 | 12:57 AM
VS8's Avatar
VS8
4 Cylinder Rotary
td04 turbo
is the td04 turbo from the subaru wrx to small to put in my car...i have one just wanting to be used
Old Jul 7, 2009 | 01:17 AM
Its smaller than the Greddy Kit snail......so what would you think
Old Jul 7, 2009 | 01:22 AM
05rex8's Avatar
sold the 8... :(
roflsauce
Old Jul 7, 2009 | 02:08 AM
VS8's Avatar
VS8
4 Cylinder Rotary
well it just seems like waste of turbo
Old Jul 7, 2009 | 02:51 AM
Mawnee's Avatar
I divide by zero
Buy a WRX to bolt it to ?
Old Jul 7, 2009 | 03:38 AM
bse50's Avatar
#50
If you're not able to read a flowchart for a turbo you can't build a properly balanced turbo kit for your car from scratch.
There are some charts posted here that might help your research and build though
Building a kit is not just copy\pasting some objects on some pipes!
Old Jul 7, 2009 | 10:37 AM
chickenwafer's Avatar
Nope
It's a bad idea
Old Jul 7, 2009 | 11:07 AM
ChrisRX8PR's Avatar
13B-RE
Get another one or two and put them all on...maybe then will you have enough flow for about 340whp...
Chris
Old Jul 7, 2009 | 11:10 AM
Way too small, get a T88, that should suffice.
Old Jul 7, 2009 | 02:19 PM
VS8's Avatar
VS8
4 Cylinder Rotary
how bout the vf39 from the sti
Old Jul 7, 2009 | 02:26 PM
bse50's Avatar
#50
IHI VF39
Aspect ratio 18
Turbine Impeller Dia ID 48mm/ OD 53mm, 11 blades
Compressor Impeller Dia 46.48mm/60mm, 6+6 blades
Equipped with compressor blade sealing
Wastegate port 25mm dia
WG Port open 77.7 kPa @ 2mm, 89.9 @ 4mm
Now it's up to you.
Old Jul 7, 2009 | 02:30 PM
There are better options, the VF39 does not have a ball bearing center section. BTW, it's an IHI turbo. Plus isn't it a dual scroll turbo? I could be wrong though.
Old Jul 7, 2009 | 02:34 PM
VS8's Avatar
VS8
4 Cylinder Rotary
its a single scroll...only reason i ask is because i have 3 friends who have turbos just laying around
Old Jul 7, 2009 | 02:37 PM
TX
I know one of the STI's had a dual scroll, either way its too small I think for the rotary. Look up the flow charts for the VF39.
Hunterkelley24
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
05rx8mazda
Nov 28, 2015 09:42 AM
MolecularConcept
11
Sep 29, 2015 09:21 PM
