Power Steering out after amp install ???
Old Mar 21, 2009 | 11:33 PM
kdparsons80's Avatar
Exclamation Power Steering out after amp install ???
The power steering light is on and the car turns like it has no power steering how could the amp I was installing change my steering? Any help would be greatly appreciated. Thanks.
Old Mar 21, 2009 | 11:44 PM
Electric power steering....could be wiring? fuse?? Check the usual steering issues..and then check all the things you worked on....
Not likely a coincidence
Old Mar 22, 2009 | 12:02 AM
Checked the connectors nothings loose the fuse is good. I unhooked everything i did except for the high level speaker wires running to the amp I installed. Still no change.
Old Mar 22, 2009 | 12:19 AM
Update!!! I disconnected the High Level inputs from what i thought was the rear speakers now I have power steering!!! Ha. Now all i have to do is figure out what the hell i did wrong in the first place??!!
Old Mar 22, 2009 | 12:20 AM
nuke0907's Avatar
Never Blend In
bose or non-bose?
Old Mar 22, 2009 | 12:47 PM
Bose. I don't understand how connecting high level inputs for my amp would affect the power steering, at least it works now.
Old Mar 22, 2009 | 04:57 PM
Look at the wiring diagram it may be a clue. Glad you found the problem.
Old Mar 22, 2009 | 06:22 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Did you turn/rotate the amp? I'll bet it turns real easy!
Sorry..........just couldn't resist.
Old Mar 24, 2009 | 09:45 PM
PRmade's Avatar
That was funny Mazurfer
drebbrnator
Dec 27, 2018 07:02 PM
Billy Marcial
Mar 1, 2018 06:50 AM
HMSS013
Aug 28, 2015 03:08 PM
atmd
Aug 19, 2015 12:43 PM
SIllver
Aug 1, 2015 07:34 PM
