How to cut off sound system?
Old Dec 10, 2008 | 10:35 PM
DOMINION's Avatar
I don't buy Kool-Aid
Lightbulb How to cut off sound system?
I have been thinking and I'm trying to come up with a way to cut off my sound system when ever I want. A SAFE way to do so would be good lol
Heres what I have been thinking of. When I installed my system, I can tell that I lost power. I changed the plugs went out and got a red top battery keep up on the oil changes but its all the same. Just like when I had my AT and installed my system I lost power. Not much but you can tell its on the lowend.
So What I'm thinking of is a way to cut the wire that runs from my battery with something like a kill switch or just disconect it and put something on the end of the wires so its not sparking all around my engine bay lol and when I want to run around on the track I can. Well not that I cant now just that its not the same like when I had all my BPU and no sound system
Anything? Or should I take it to a audio shop and let them do it?
Thanks guys
Old Dec 10, 2008 | 10:44 PM
You are looking to disconnect your power to your sound system at the track??
Like the off switch??
Old Dec 10, 2008 | 10:53 PM
paulmasoner's Avatar
Asshole for hire
get a marine breaker switch and put it inline on the power to your amp.
Old Dec 10, 2008 | 10:57 PM
Wire a switch up to a relay.......use low power to trigger relay...and the high power circuit to drive the amp...very safe and easy
Old Dec 10, 2008 | 11:52 PM
DOMINION's Avatar
^That sounds like a great idea! can I do the same for 2 amps? and where can I get this relay switch?
Old Dec 11, 2008 | 08:16 AM
nuke0907's Avatar
Never Blend In
why?
Old Dec 11, 2008 | 08:30 AM
firebirdude's Avatar
User and Abuser
You probably lost power because you're hauling around 200 more pounds.
Why not just a switch inline with the remote turn on lead? Amps don't draw power when turned off. For proof, I left my car in a storage hanger for 6 months while I was deployed to the Middle East. (3 amplifiers. ~3800WRMS) Came back. Car fired right up. Had a flat tire though.
Old Dec 11, 2008 | 11:35 PM
mikeschaefer's Avatar
I wanna rock! Rock!
i don't know why you would need to prove something like that though.
Power off means no power
Old Dec 11, 2008 | 11:49 PM
Juice's Avatar
I made some poos
I was thinking the same thing. There should be no reason that your car lost power because of the system. There might be a drag from the alternator with the system at full hilt, but not enough to notice, maybe 1-2HP at most. I'm pretty sure it is simply from the heavy box/subs/amp that you added.
If you want to get something, get some quick release connectors for the power/ground/remote lines, attach the amp to the box and then you have something that is easily removable.
For the power/ground, you can get a connector like this:
http://www.hifisoundconnection.com/S...id/0/SFV/30046
For the Remote line, you can use something like a spade connector found at any Radio Shack.
Old Dec 12, 2008 | 07:08 AM
User and Abuser
parasitic draw
Old Dec 13, 2008 | 07:40 PM
DOMINION's Avatar
Its no where near 200 punds. But yea the parastic draw. I just want to seperate the wire with a switch or even if I have to pop my hood and do it by hand. Its all good. Thanks for all the great info I always find on here. You guys rock! This is going to be my next DIY.
Old Dec 14, 2008 | 07:36 AM
jenkins-crew's Avatar
They have circuit breakers for audio systems.
Old Dec 14, 2008 | 07:43 AM
User and Abuser
Parasitic draw certainly isn't going to make you loose HP. And yes, they do make circuit breakers for car audio purposes. Smallest I've personally seen them is 100 amp though.
Old Dec 14, 2008 | 08:09 AM
Phoenix Gold VB-200 - about 23 bucks.
http://www.avtoybox.com/vb-200.html
Old Dec 14, 2008 | 05:54 PM
DOMINION's Avatar
^Oh I like the looks of that. Thanks man!
Never said I was loosing hp due to Parasitic draw. How ever I have lost hp due to the system install. Ever sence I went from 8g to 4g wireing from the battery to my stuff in the trunk.
So if this dont work then I will upgrade my alternator.
Lets see what happens.
Old Dec 14, 2008 | 08:00 PM
User and Abuser
#1 Well if it wasn't power draw and it wasn't the system weight.... what's left!?!
#2 H/O alternators DO rob you of a few ponies. More load to turn the pulley coupled with the frequently used smaller pulley diameter.
#3 That is a 200amp breaker. You'll melt your 4g wire before that breaker trips. Again, the smallest I've seen them is 100amp. What are you running back there?
Old Dec 14, 2008 | 09:49 PM
I have 0 ga wire......they have different amp sizes...get the best one for your application.
juicemantwon
Sep 26, 2015 12:30 PM
rrubenr33
Sep 21, 2015 06:44 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
Tsurugi
Sep 7, 2015 08:27 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
