AC Compressor Fail
Old Nov 17, 2008 | 06:10 AM
scoreo99's Avatar
AC Compressor Fail
Has anyone experienced their AC Compressor failing only when its raining outside?
Any other time it works fine, but when I need the defroster, I can hear the clutch kick in on the AC Compressor, and then it immediately shuts off. It tries to kick in again and immediately shuts off. This is at idle usually or very slow speeds. At highway speeds it will come on and stay on properly.
I've tried fuses, relays, and resetting ECU (thought it may have had something to do with a temperature sensor)
Old Nov 17, 2008 | 07:59 AM
*sigh*
you're not serious right ?
Old Nov 17, 2008 | 08:00 AM
scoreo99's Avatar
Originally Posted by nycgps
*sigh*
I'm dead serious. Driving home on the FDR in the rain and having to wipe the inside of my windshield every 5 minutes isn't fun.
Old Nov 17, 2008 | 08:03 AM
have u check ur HVAC control ***** ?
Old Nov 17, 2008 | 08:07 AM
scoreo99's Avatar
Of course. no matter where temp setting is, the compressor clutch clicks in then immediately shuts off. clicks on, then off immediately.... its like the compressor is refusing to stay on.
Old Nov 17, 2008 | 08:09 AM
have you check the compressor's freon level ? or it might need a little lube ?
Old Nov 17, 2008 | 08:13 AM
scoreo99's Avatar
I added a can of freon (or r134 whatever it is) when the AC Compressor is running, its running really cold. The car just had its AC Condenser and pulleys replaced. I'm just hoping there is something I could do myself without having to drop it off at the dealer. I just got it back after a month and a half. (it was in an accident)
Old Nov 17, 2008 | 09:30 AM
EDZRIDE's Avatar
2005 White GT
Assuming the shop properly charged the system after their repairs, you could have overcharged by adding freon; this could cause the Hi-Pressure switch to open and cycle the clutch. Go back to the shop and have them put some gauges on your system.
Old Nov 17, 2008 | 09:39 AM
scoreo99's Avatar
Cool, thanks for that EDZRIDE, I'll let u know what they find.
Old Nov 18, 2008 | 01:18 PM
scoreo99's Avatar
Just got off the phone with the dealer, it seems that they overcharged the system. They set it to the correct amount. Hopefully this solves the issue.
Old Jun 25, 2011 | 10:28 PM
hondakilla's Avatar
mines clicking on and off too i cant figure it out either
gwailo
May 14, 2024 06:57 AM
Racingjunkie
Sep 29, 2015 05:05 PM
tommy26Germany
Sep 29, 2015 10:33 AM
thewatcher101
Sep 18, 2015 01:48 PM
