Steering issues
Old Nov 2, 2008 | 08:40 PM
Jasonawojo's Avatar
Steering issues
Went autocrossing today, and on my last run I spun out at a decent clip. As I was sliding sideways I heard a bit of a metal groan.
Later, when pulling onto the highway I noticed that my steering wheel is entirely off center (straight at ~11), the car doesn't track straight on it's own, and there is a little vibration here and there in the wheel. At first I thought the alignment was out, but I haven't actually experienced a wheel being off center before? How likely is it that a control arm, etc, is bent?
Old Nov 2, 2008 | 08:49 PM
expo1's Avatar
He's as bad as Can
Could be the arms, or the steering rack, you can see the part near the bottom of THIS photo.
Old Nov 2, 2008 | 08:59 PM
G3tR3DDY2GR3DDY's Avatar
my guess... this would cause your car to veer off and your wheel to be crooked. If this is bent...
Old Nov 2, 2008 | 09:14 PM
interesting.
i am fighting that same issue.. but no spin, no vibration.. just wheel at 11 and a mild pull to the right..
just had the car aligned. same issue.. odd.
Old Nov 2, 2008 | 11:51 PM
Originally Posted by swoope
interesting.
Take it back and get them to align the wheel....they screwed it up when they adjusted the toe (likely all on one side) They have to put it back on the rack to do it properly Hopefully the alignment is correct...
Old Nov 3, 2008 | 09:13 PM
Jasonawojo's Avatar
Alright, thanks for the diagrams. I'll take a look when I'm somewhere where I can lift the car. Definitely something up though, front wheel was losing traction on an on-ramp, triggering traction or stability control.
Old Nov 3, 2008 | 09:34 PM
HeavyMetal699's Avatar
Yup, if they don't tighten the hell out of it after an alignment it will mess up. My alignment guy went to town on my car and found several loose bolts.
There are horror stories about certain alignment shops in Houston.
Old Nov 3, 2008 | 09:52 PM
chancejat's Avatar
Drive it like u stole it!
interesting.
same here ....got it aligned and now it sits at 11 and pulls rights.....took it back they said it was fine......
Old Nov 3, 2008 | 09:54 PM
Me thinks you need to find another alignment shop
Old Nov 3, 2008 | 09:56 PM
chancejat's Avatar
i think i will after i install new springs and shocks...
Old Nov 4, 2008 | 07:13 PM
dan nailed it. took it back, they straightened the wheel.. found the toe was off.. fixed that.
car is yummy again..
WranglerFan
May 31, 2022 07:51 AM
iwannarun
Sep 6, 2015 01:37 PM
MIGhunter
Sep 5, 2015 07:21 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
