while puttin on a tire, one of the screws broke the other is stripped HELP!
Old Oct 24, 2008 | 02:25 PM
jbk's Avatar
jbk
i got a flat the other day and today i got a used replacement tire. while i was putting on the tire i wanted to make sure it was tight on... i felt like it wasnt in all the way so used my body weight to make it tighter by stepping on the bar. unfortunatly the whole screw thats attached to the axle(or whatever it is) snapped off with the lugnut on it.
I would be fine with driving with 4 lugnuts on but the one next to it is stripped aswell... i plan on getting a new thing(can someone tell me what its called) but i still need to use my car daily...
can anyone tell me if ill be alright with just the 3 for now?
Old Oct 24, 2008 | 02:30 PM
ZumnRx8's Avatar
RX8 & RX7 owner
Its called a f***ing BOLT...And that has happened to me with my ACURA TL. NO u will not be alright. Go to Pep Boys or autozone or MAzda and ask for one of the bolts for ur wheel...U are going to have to remove ur rotor to change the two bolts. For a job like this u shouldnt be charged more than....$50-100 tops.. ITs noT HARD. I wish i had pics of when i did it....but then again that was 3 years ago.
Old Oct 24, 2008 | 03:22 PM
I think there is a DIY for the lug bolt replacement in the DIY section.....it is a bit of a PIA if you have never done it before. Nevertheless it is relatively easy fix
PS: Buy a torque wrench
Old Oct 24, 2008 | 03:29 PM
luis@championsmotorsports's Avatar
if you had to get out of the hood 3 is better than none but highly not recommended for daily use,
Old Oct 24, 2008 | 04:17 PM
Brettus's Avatar
Boosted Kiwi
good idea - you need to learn how much force to apply , a torque wrench will let you get a feel for it so you don't do this again .
Old Oct 25, 2008 | 09:12 AM
lepichichi's Avatar
I LuV mY Rotary....
get a torque wrench it will be a lot of help!
Old Oct 25, 2008 | 11:00 AM
nuke0907's Avatar
Never Blend In
another recommendation for a torque wrench.
its not a bolt, its called a wheel stud.
Old Oct 25, 2008 | 11:18 AM
you stepped on the bar?!
Old Oct 29, 2008 | 07:22 AM
PBlue's Avatar
Dial P for Phantom
dealer will charge you probably 500.
you could do it yourself pretty cheap, but based on your installation skills, i might find a local shop instead.
Rx8 VA Guy
Jun 4, 2016 12:42 AM
RX-8 Racing
20
May 14, 2016 06:25 PM
Michael Bryant
Oct 12, 2015 03:07 PM
GranTouTou
Sep 30, 2015 06:11 AM
