i have a problem, can some1 help me?
Old Aug 19, 2008 | 09:02 AM
J1MO7's Avatar
i have the stock head unit with locs
1 10 jl audio
1 mono alpine amp
and 80% of the time when its hot and i turn the system off or on mute the bass jus goes flat when its supposed to be off and its really annoying
also the bass does not go down when the volume does thats a diff issue tho
Old Aug 19, 2008 | 09:26 AM
J1MO7's Avatar
and even when i switch songs inbetween the time it takes for new song to play the bass jus blaresssss at full blast
Old Aug 19, 2008 | 11:19 AM
DeViLbOi's Avatar
The devil made me do it
Check your ground.
Old Aug 19, 2008 | 11:35 AM
simplec's Avatar
Check all of your connections (one is most likely loose)- especially your ground and power, or you may have two bare wires touching.
Old Aug 21, 2008 | 04:05 PM
J1MO7's Avatar
ok checked that and did nothing but i did make a new discovery......
even with my car stero powered off but battery on when i have the trunk open its fine but when i close the trunk bass line goes flat as loud as possible
any suggestions?
Old Aug 21, 2008 | 05:56 PM
Socket7's Avatar
ಠ_ಠ
how are you powering your remote input for the amp?
Old Aug 22, 2008 | 09:05 AM
simplec's Avatar
You could probably solve this problem by going to an auto install shop and having them hook it all up again for you. Does your amp turn off when the radio is off?
Old Aug 22, 2008 | 01:27 PM
Socket7's Avatar
ಠ_ಠ
I think he's using an auto sense for his remote turn on instead of tapping a real remote line. Theres a thread here about how that can cause a sustained bass tone to play when you close the trunk
Old Aug 24, 2008 | 08:55 PM
J1MO7's Avatar
circuit city installed
Old Aug 24, 2008 | 08:59 PM
firebirdude's Avatar
User and Abuser
Circuit City warranties their labor for life. Provided you don't screw with the installation. So make it look like you never touched anything, and then take it into any Circuit City nationwide.
Old Aug 24, 2008 | 09:01 PM
lurch519's Avatar
www.evoperform.com
loc connected to rear speakers, and signal sense is used on the jl amp instead of remote turn on. rear speakers move (even when no music is playing) sending signal to amp, amp amplifies signal, playing subs, subs move air, which moves rear speakers, rinse repeat. it has been discussed before, but its probably lost in the threads. its actually better to tap at the factory amp for front spks or at the radio, and use a turn on lead
Old Aug 24, 2008 | 09:03 PM
User and Abuser
J1MO, tell Circuit City that to get them moving in the right direction. But let them do the work. I'm telling ya, if you screw with it, their warranty is voided. You paid for it. Use it.
Old Aug 25, 2008 | 11:41 AM
J1MO7's Avatar
ok only 1 problem I don't have the paper work from circuit city, but they could look it up in computer right?
Old Aug 25, 2008 | 12:49 PM
User and Abuser
Yep. They're going to ask you for the telephone number you gave them when purchasing the installation. And if they STILL cant find it in their computer, they have copies of every work order on file. Just tell them approximately when the installation was done.
Old Aug 25, 2008 | 12:51 PM
they can find you in the system, they should have all the records.
My first thought was a ground issue but Lurch brings up a good point
Old Aug 28, 2008 | 03:07 PM
J1MO7's Avatar
Thanx guys went to cc n they fixed everything
Old Aug 28, 2008 | 04:05 PM
User and Abuser
Old Aug 28, 2008 | 09:58 PM
lurch519's Avatar
www.evoperform.com
and what was the issue?
Old Sep 4, 2008 | 08:26 PM
jstkilntim's Avatar
resU deretsigeR
Typical CC install.
Old Sep 11, 2008 | 02:47 PM
J1MO7's Avatar
swapped out locs n put a filter on
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
