help! time sensitive
Old Jul 24, 2008 | 07:32 PM
Zeal's Avatar
Totally Rotarded
ok, so my tranny was acting up and brought it to the stealership, i suspected tranny damage, but they said it was just the clutch.
i bought a stage 1 exedy clutch kit and lightweight flywheel and the mechanic working on my car says my output shaft is F***ED. what should i do here? continue install and bring it back to them saying it was like that with stock parts? put stock stuff back on?
since dealer told me it was the clutch, should this automatically mean to them that i didn't do anything to screw anything else up with the other parts?
thanks for any response
Old Jul 24, 2008 | 07:39 PM
Jon316G's Avatar
Grasshopper
I would put it back to stock and take it to the dealer.
If the clutch or output shaft is bad, let the dealer take care of that under warranty.
You start messing with the tranny, they can use that against you and say that the warranty is void for the tranny.
Get is looked at and fixed if needed, THEN upgrade if you want.
Old Jul 24, 2008 | 07:47 PM
Zeal's Avatar
Totally Rotarded
the clutch isn't under warranty, hence why i decided to just upgrade instead, but didn't know there was actually a tranny problem. technically, it's a very similar product, stock is an exedy clutch, think they'd give me a lot of problems?
Old Jul 24, 2008 | 07:58 PM
Outkast187's Avatar
NO, you can actually have them install it at the dealership if they are doing warranty work. I have done it here several times, never once used OEM clutch.
Old Jul 24, 2008 | 08:08 PM
Zeal's Avatar
Totally Rotarded
hope **** works out X___X thanks guys
Old Jul 24, 2008 | 10:28 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah put stock parts on and take it back to the dealership
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
uZu
Dec 30, 2015 12:35 PM
tigg.z
Aug 26, 2015 09:51 PM
arjunmshah
Aug 6, 2015 10:56 AM
dbarber
Jul 25, 2015 01:34 PM
