Would a high quality vacuum cap work in this application?
Old Jan 28, 2008 | 02:08 PM
max5roadster's Avatar
INDY RX8 CLUB - Officer
I am trying to block off the coolant lines for the Throttle Body Bypass at each of their respective end points for a cleaner look. Would a vacuum nipple (thick black kind) and a clamp hold for the long run? I guess I can just run the longer one over to it (from the T-stat to the rear rotor under the UIM) if need be.
Old Jan 28, 2008 | 05:21 PM
Old Rotor's Avatar
Look at this it only took one minutes and does the same thing. Look at the whole thing I showed where the pics were also. Most people got help with it. I looked at screw last week and no rust or corrosion either. Better cold weather performance and no more detonation.
https://www.rx8club.com/rx-8-discussion-3/no-more-detonation-%2Amiac%2A-121249/
Old Jan 28, 2008 | 09:13 PM
I just routed the hose from the T-stat to the rear rotor end and left it like that. No splices. While I had the UIM off, I Sea-foamed it. I found the runner closest to the trans to have the most carbon in it for some reason.
Old Jan 28, 2008 | 09:28 PM
^^ That's what a lot of us have done....
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Nisaja
Apr 14, 2019 08:04 AM
Kahl
Aug 20, 2015 11:49 PM
Kim Jong Illest
Canada Forum
Jul 23, 2015 03:22 PM
AussieGray
Jul 16, 2015 03:58 AM
