rx8 going to shop tommorrow for sputtering should i ask for certain test?
Old Jan 2, 2008 | 05:07 PM
jamesunc1's Avatar
hello im new to the forum i have a 2004 rx8 6 speed . have had the cat replaced and all recalls done on it . I noticed today when i started it up and was letting it warm up that the engine light was flashing then when i started to drive it was stalling on me is there anything i should ask them to check when i bring it in would realy appreciate the imput thanks
Old Jan 2, 2008 | 05:20 PM
dillsrotary's Avatar
jersey fresh
engine compression test, sounds like a faulty engine, how many miles do you have on it?
Old Jan 2, 2008 | 05:56 PM
jamesunc1's Avatar
I have 44426 on it. Im hopeing its nothing serious ive been noticeing the pickup hasnt been the same since the catalitic converter was replaced from the last time it was in shop for engine light.
Old Jan 2, 2008 | 05:57 PM
Is it an Auto or MT?
did you let it warm up? What RPM and speed were you doing when she stalled?
Old Jan 2, 2008 | 06:00 PM
magikone69's Avatar
at 44k miles have u changed your plugs yet...might be the problem.
Old Jan 2, 2008 | 06:17 PM
mzrx's Avatar
as magikone69 said check your plugs and coil packs. my car sputter around 45k miles and it was plugs and coil packs that needed to be replaced.
Old Jan 2, 2008 | 06:44 PM
jamesunc1's Avatar
it is a manual transmission and i dont think they have been changed unless it was done on the recall i bought the car a year ago in florida. i appreciate all the imput ill ask them to check that tommorrow. and see if they can do a compression test just to make sure
Old Jan 2, 2008 | 06:46 PM
jamesunc1's Avatar
i let it warm up almost half way then when i pulled out in reverse it started to sputter first time it ever happened to me so i parked started it again and then it seemed to be fine on the ride home
Old Jan 2, 2008 | 07:17 PM
laythor's Avatar
I zoom therefore I am.
If it turns out to be your coils and plugs you might want to think about upgrading to this: https://www.rx8club.com/series-i-major-horsepower-upgrades-93/mazsport-ignition-solution-134081/
Old Jan 2, 2008 | 08:17 PM
Ok, James. Sounds like your car is fine and just needs a tune up.
Old Jan 3, 2008 | 04:35 PM
jamesunc1's Avatar
I wanted to thank every one for the help got my car back from the dealer today they gave it a tune up changed the plugs and wires . seems to be running good now. Hopefully now i can start fixing it up.
Skyl3r
Dec 2, 2019 04:51 PM
gregs
Aug 6, 2015 11:43 PM
dbarber
Jul 25, 2015 01:34 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
tbiggybig
41
Jul 22, 2015 11:47 PM
