Renesis NC Track Car - In the Build
Old Dec 1, 2009 | 12:41 AM
  #201
Originally Posted by Hymee
Here is a 3D PDF file. You can spin/rotate, zoom in/out, and if you check out the right mouse menu, you can even make parts hidden or transparent, so you can see inside that rear timing cover (and whatever else).
Note to design stealers: If you are thinking of copying this, go right ahead. There are some intended fatal flaws in there, just to cause some grief :evillaugh:
Main Assembly (4MB Download - PDF)
Discharge Adaptor (153 KB Download - PDF)
How is that Danny?
Cheers,
Mark.
hymee,
clear box or check you email at aus designs..
Old Dec 1, 2009 | 01:19 AM
  #202
ORX-800's Avatar
How is that Danny?
Old Dec 1, 2009 | 01:23 AM
  #203
ORX-800's Avatar
Craft Square bling!
Old Dec 2, 2009 | 10:47 PM
  #204
hoss -05's Avatar
Lucky #33
Silly me I was waiting for the mazdaspeed three engine before I pulled the trigger!
Old Dec 25, 2009 | 05:32 PM
  #205
rotarenvy's Avatar
craft square hmmm
Old Dec 25, 2009 | 06:57 PM
  #206
Hymee's Avatar
Race Steward
Originally Posted by rotarenvy
craft square hmmm
Do you think they do those for the Wagon???
Cheers,
Hymee.
Old Dec 25, 2009 | 08:13 PM
  #207
rotarenvy's Avatar
Cheers,
Hymee.
what the little beater you drive? are you thinking of pimping it
Old Jan 5, 2010 | 05:29 PM
  #208
ASH8's Avatar
Super Moderator
Great work Danny...
I don't know if it is too late...some suggestions..
I would definitely look at upgrading your COIL Bracket as the Series II has vented type..see pics, only $25US.
Also I would def suggest you look at upgrading your Oil Pressure, particularly if you are going to track/race, see the thread on this..Mazmart has a kit.
http://www.mazmart.com/ItemDetail.aspx?id=586
EDIT:
Once you have done the OP Mod you can also install the Series II OIL Filter (N3R1-14-302), it is taller though, it will fit but I don't know if Oil Filter would interfere with your Mods?
Old Jan 5, 2010 | 05:38 PM
  #209
hoss -05's Avatar
Lucky #33
What ASH8 said. Also Bump.
Old Jan 8, 2010 | 03:43 PM
  #210
rotarenvy's Avatar
Originally Posted by ASH8
Great work Danny...
ash to me that channel is not for cooling. it may be to stiffen the mount and reduce vibration but it wont do much for cooling.
the air in the channel would be still and still air is a great insulator. it would help hold in the heat generated by the coil. it may insulate slightly against heat transfer from the engine but would have a very minor effect compared to the heat transfer from the other contacting surfaces and radiant heat from the engine bay.
Old Jan 8, 2010 | 07:09 PM
  #211
ASH8's Avatar
Super Moderator
No Problem..you are entitled to your theory..
I presented this Bracket to My Local Mazda Service Manager, he contacted MA for me and the results were...
Bending or warping was not an issue in Series I, radiant heat and arcing because of the heat between the Coil Base and the Flat steel bracket was.
In Mazda's wisdom it was agreed the modified Bracket was for Cooling "Loosely", but mainly to help prevent 'direct' radiant engine heat transfer from the bracket to the bottom area known for the coils to "overheat" and expire with or performance degradation noted by the area Service Manager.
BTW: I am trying to get Mazda Australia to agree with a form of communication between our forum users and Alan Horsley, Mazda Australia's Racing Guru over the past 3 decades.
He is very busy ATM with the Targa Tasmania, but I hope I can get him to join this Forum and answer ANY performance Related questions we Rotary Enthusiast may have...
What do you think...Value or Not?
Old Jan 8, 2010 | 07:11 PM
  #212
ASH8's Avatar
Super Moderator
BTW, Have you thought about removing your sump pan and modifying BY Pass Valve to improve your Oil Pressure???
Old Jan 8, 2010 | 11:08 PM
  #213
timbo's Avatar
rock-->o<--hard place
I wish you good luck ....I'm not sure how valuable monosyllabic answers and posts will be
Old Jan 9, 2010 | 02:17 AM
  #214
Old Jan 10, 2010 | 05:20 PM
  #215
Revolver's Avatar
Shootin' from the hip
At the risk of hi-jacking Danny's thread, I am sure many people could learn a lot from Horsley but as Timbo says, he's not exactly known for his patience or being chatty. I could imagine it getting messy once the trolls and conspiracy theorists get wind of his involvement...
Old Jan 10, 2010 | 06:45 PM
  #216
Hymee's Avatar
Race Steward
I don't want to hijack Danny's thread either, but I reckon the chances of getting Mr. Horsley posting here are about as good as Pakistan's were to win the Sydney test match! LOL.
Cheers,
Hymee.
Old Mar 7, 2010 | 04:57 AM
  #217
ORX-800's Avatar
Remember this item?
Well here is the finished item.
With the oil pressure and oil temperature senders installed.
....and fitted onto the engine.
Next step is to get the oil lines between the engine and supercharger drive made up. Even though time on the car has been extremely limited over the past three months, I have made key decisions and acquired more parts.
Cheers,
Danny
Old Mar 7, 2010 | 09:08 AM
  #218
Will you be selling that? That is awesome. Wish I ad that when i did my Fluidyne cooler install.
Old Mar 7, 2010 | 05:59 PM
  #219
Hymee's Avatar
Race Steward
I think we will be. It is an integral part of the S/C kit. A much nicer solution for a remote mount oil filter. Think of easier oil filter changes!
Cheers,
Hymee.
Old Mar 7, 2010 | 07:39 PM
  #220
Put me on the list.
Old Mar 8, 2010 | 03:11 PM
  #221
Revolver's Avatar
Does this mean I get me one of 'dem too???
Old Mar 8, 2010 | 03:18 PM
  #222
ORX-800's Avatar
...of course Dave!
Old Mar 8, 2010 | 05:50 PM
  #223
Hymee's Avatar
Race Steward
There are so many more nice and improved nice bits now than was first proposed! (and estimated on )
Cheers,
Hymee.
Old Mar 8, 2010 | 05:54 PM
  #224
tubingchamp's Avatar
What mawd bug?
Cheers,
Hymee.
Sure are..
How are those coming by the way?? :D
Check your e-mail Mark!
Old Mar 9, 2010 | 03:12 PM
  #225
Revolver's Avatar
Originally Posted by ORX-800
...of course Dave!
Woot!
