Weight of Stock RX8 Parts
Old Nov 11, 2009 | 07:53 AM
  #151
VS8's Avatar
VS8
4 Cylinder Rotary
well i dont see weight of door panels on front page
Old Nov 12, 2009 | 01:21 AM
  #152
It's in here, read the thread, you'll also see where I asked for the front page to be updated, sometimes you have to work for an answer, can't always be handed to you on a platter
Old Nov 12, 2009 | 08:19 AM
  #153
Zelse's Avatar
悪魔のR
The thread creator probably left the forum or whatever, which is why it hasn't been updated. We should probably remake this thread...
Old Nov 14, 2009 | 02:48 PM
  #154
ebb's Avatar
ebb
PPF with heat shield 31 lbs +/- a pound. (including vibration damper of 3 or so)
Driveshaft 10 lbs (6 spd)
differential entire assembly with mount 81 lbs
I am going to add stuff even though the first post does not get updated. At least you can search the thread to find things.
Old Nov 14, 2009 | 03:14 PM
  #155
VS8's Avatar
VS8
4 Cylinder Rotary
i cant seem to find the weight of the front and rear door panels in total
Old Nov 15, 2009 | 11:37 PM
  #156
ebb's Avatar
ebb
Try searching this thread for the word panel, it works
Old Nov 15, 2009 | 11:44 PM
  #157
VS8's Avatar
VS8
4 Cylinder Rotary
well i just checked and i found front door panel...but wat is the weight of the rear door panel
Old Nov 18, 2009 | 11:48 PM
  #158
Thanks for the good info
that driveshaft sure feels heavier than 10# though, kind of surprising
Old Mar 26, 2010 | 03:38 AM
  #159
TrochoidMagic's Avatar
is adjusting valve lash
aftermarket high flow cat weight request:
RP supercat.
couldn't find any documented weight on this part...
if someone knows, please post it.
thx
Old Apr 14, 2010 | 01:40 AM
  #160
Xyntax's Avatar
THREAD KILLER
RP supercat.
thx
15 lbs. I had it on my former RX-8. It was also posted here back then. I think the stock is twice the weight, 30 lbs. I remember it falling on my chest when I dislodged it.
Old May 2, 2010 | 01:23 PM
  #161
megalemons09's Avatar
Great thread but I've read the whole thing and I haven't found how much weight I would save by stripping ALL the interior. Anyone with answers?
Old Jun 13, 2010 | 04:40 AM
  #162
king angels's Avatar
My dad did that and he lost 80 pounds. I hope it helped you become healthy. Sorry, look at thier website.
Old Jun 13, 2010 | 05:08 AM
  #163
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
Weight on catless midpipe? Ap duel Rez.? Cant find but I'm assuming less then rp supercat which is 15lbs.
Also weight on hks hi power?
Just been super couious.
Thx.
Old Aug 7, 2010 | 09:22 AM
  #164
Beefy98's Avatar
Is the spare tire included in the factory curb weights? I pulled mine out. The spare w/bar/bolts, jack, tools, and case with sealant/compressor all came to 39 lbs.
Old Aug 7, 2010 | 09:53 AM
  #165
No, the spare & mount is an accessory item. You would need to list the total weight of those components separate of the other stuff that came standard from the factory. Ideally you might list the total for the tools/jack as one item, the tire inflator kit as a second, and the spare/mount parts as a third.
Old Aug 25, 2010 | 01:22 PM
  #166
Beefy98's Avatar
Don't know if this has been listed yet.
"Triangulated" strut brace (09-up) between 4 and 5 lbs..
Old Sep 12, 2010 | 01:38 PM
  #167
vglnte1's Avatar
has anyone stripped the car completely and weighed it? Im talking about carpet, roof liner, back seats, everything...
Old Nov 28, 2010 | 08:58 AM
  #168
rx8dorifto's Avatar
Originally Posted by brillo
I have begun compiling a list of all the weights of the various stock parts of the car
Please PM Zoom44 or Brillo to add any additional information.
Bumper Reinforcement - 15.6lbs
What's the real purpose of this bumper reinforcement bar? Do we really need it?
thinking of removing it to cut the weight off front wheel axle.
Old Nov 28, 2010 | 10:16 AM
  #169
Spin9k's Avatar
Momentum Keeps Me Going
^ the purpose of the 'bumper reinforcement'...
"The front box-section reinforcement bar is welded to the octagonal-sectioned "crash cans". The reinforcement/crash can assembly is bolted onto the front longitudinal frames."
"Do you need it?" Probably not, unless you get in a front-ender...but it may provide some front end stiffness to the frame as well.
Old Dec 25, 2010 | 12:33 PM
  #170
it's just there for the 5 mph USA crash requirement
Old Dec 31, 2010 | 09:57 AM
  #171
Factory trunk lid without wing - 15 lbs
APR GTC-200 aftermarket rear wing with standard mounting supports and hardware - 10 lbs
APR front splitter - 8 lbs
Old Jan 4, 2011 | 07:21 AM
  #172
OE front appearance package air dam - 3.75 lbs
OE front bumper center grill insert - 1.5 lbs
Old Jan 14, 2011 | 10:21 PM
  #173
Appearance package rear aero flares - 1 lb each side (2 lbs total both sides)
Old Feb 4, 2011 | 01:17 AM
  #174
dmedz8's Avatar
Needs Boost!
does anyone know the weight of the trunk lining or the TurboXS exhaust with race pipe?
Old Feb 4, 2011 | 11:00 AM
  #175
8upbad's Avatar
Jared
I didn't see anyone mention the radio. I have the Bose system and I was thinking about taking it all out along with the seats.
