The Official Overboosted Overlords Club
Old Oct 25, 2009 | 12:08 AM
  #1476
blackenedwings's Avatar
Life begins @ 30 psi
The Synapse Syncronic I've heard nothing but good things about... I'm seriously considering getting one. I noticed a pretty significant difference between recirc and VTA with the GReddy RS BOV. Throttle response suffered, and I had boost lag compared to recirc. Thats in addition to the huge explosions every time I took my foot off the throttle.
Old Oct 30, 2009 | 05:25 PM
  #1477
rotarenvy's Avatar
I'm still running the std leading and trailing plugs but with summer heating up I think it is probably wise to run a cooler plugs.
what are the pros on cons of the various spark plug configurations?
I could just run all trailing plugs as I have a spare set. this seems like there
is a risk of having the trailing plugs fire out of sequence since mazda thought a cooler trailing plug is necessary.
or I can run FD plugs for leading and trailing. this set-up needs spacers but I have no idea of how to find and setup the spacers?
the other problem I may have is poor compression on the rear rotar that makes my car hard to start. I have read that cooler plugs may make the car harder to start.
anyone like to give some advise?
Old Oct 30, 2009 | 05:56 PM
  #1478
Brettus's Avatar
Boosted Kiwi
/\ yeah - my car takes about an extra 0.5sec to start with the colder plugs in .
FWIW the spacers (on the trailing) are just precautionary as there is not actually any interferance without them - contrary to popular belief . If you can get the crush washer off another plug somehow - that would be sufficient to allow plenty of clearance .
Old Oct 30, 2009 | 06:03 PM
  #1479
MazdaManiac's Avatar
"Popular belief"?
Are you gonna make me have to dig up the pictures again?
The plug is 2mm longer than the hole you are screwing it into.
It doesn't "interfere". It distorts the housing.
Old Oct 30, 2009 | 06:06 PM
  #1480
rotarenvy's Avatar
so what do I use as spacers?
Old Oct 30, 2009 | 06:09 PM
  #1481
Charles R. Hill's Avatar
Owner of BHR
Here we go, again.......
If you're gonna use colder plugs use the BUR9EQPs on the leading side and the RE9B-Ts on the trailing side. Simple as that and MM has been doing it for a long time.... sans "spacers".
It is when one uses the BUR9s on the trailing side where spacers become necessary, which is pointless as the OEM Iridium plugs are already 9s.
If you have a set of "H.O." ignition coils use nothing less than Platinum plugs as the coppers will quickly be destroyed by LS, Yukon, and MSD coils.
Old Oct 30, 2009 | 06:21 PM
  #1482
Brettus's Avatar
Boosted Kiwi
Originally Posted by MazdaManiac
"Popular belief"?
We have had this argument before and nothing has changed .
Hole depth to shoulder = 21.2
plug thread length to crush washer ,when crushed = 20.5 (21.5 to shoulder)
0.7mm clearance - bit close for comfort so an extra crush washer is all that is required .
When you learn how to use your vernier calipers get back to me .
Old Oct 30, 2009 | 06:24 PM
  #1483
rotarenvy's Avatar
thanks Charles
excuse my ignorance, what's "H.O." ignition coils? in another thread of yours If I remember correctly BUR9EQPs are platinum so there doesn't seem like anything to worry about?
Old Oct 30, 2009 | 06:33 PM
  #1484
Owner of BHR
Originally Posted by rotarenvy
thanks Charles
No problem, Jarl.
H.O.= "high output".
The "P" in "BUR9EQP" means Platinum. NGK also offers a "BUR9EQ". Big difference so check the box before you buy 'em.
Old Oct 30, 2009 | 07:07 PM
  #1485
maxxdamigz's Avatar
Baro Rex
Charles - what kind of plug life are you seeing on the BUR9EQPs in people running 10+ psi? My car runs great with a new set but they don't stay new for too long.
Old Oct 30, 2009 | 08:13 PM
  #1486
Brettus's Avatar
Boosted Kiwi
/\ I ran mine for about 12000 miles but I went a little too long as they were quite badly rounded . I would say 10000 miles max .
Old Oct 30, 2009 | 08:22 PM
  #1487
When you do the same, you will be quite dismayed.
The "hole" isn't the issue.
The curvature is.
The "mating" surface (which shouldn't be mating) is comprised of two different shapes.
I already posted the borescope pics to explain the proper caliper technique.
With Yukon coils and copper plugs at 9+ PSI, you will only get 5k - 7k of useful, full performance miles.
I've actually destroyed a new set of copper plugs in one track weekend. (Not detonation.)
Old Oct 30, 2009 | 09:23 PM
  #1488
Brettus's Avatar
Boosted Kiwi
The curvature is.
The hole is harder to measure admittedly - 20 yrs of engineering did teach me a few small things - how to measure stuff for one . The depth you are interested in is the depth at which the outside diameter of the plug would interfere.
The plug is very easy to measure however and the fact that you could not do that right leaves me pondering about your effort .
BTW ayone who has a plug and thinks they know how to measure stuff should do it and then chime in here - cuz MM can't seem to get it right .
The final test of course is to get an old housing . Look in the hole with a torch and you should see a dark carbon stain at the bottom .
Then screw in a plug , tighten it up good , then remove it . If there was interferance you should see a bright 'witness' mark at the bottom of the hole . Such a mark was absent when I did this proving ,to me anyway, that there is no interferance.
Old Oct 30, 2009 | 09:28 PM
  #1489
Brettus's Avatar
Boosted Kiwi
Sounds like good advice.
my 12000 was not exceptionally hard out however so 10k would be a good max. for people who mostly drive on the street and do lots of cruise mileage .
Old Oct 30, 2009 | 10:03 PM
  #1490
maxxdamigz's Avatar
Baro Rex
Excellent. My car has been running great on new plugs but I eat a set every 6k at 12.8 peak psi. As for shimming, I didn't think the 12 dollars I spent on enough shim washers for the life of the car wad worth thinking about. The housing is al no?
Edit: Ah crud - my last set of plugs were platinum.
Old Nov 6, 2009 | 03:38 PM
  #1491
Brettus's Avatar
Boosted Kiwi
Pretty sure I Just broke past the 350whp barrier - Think i maxed out the injectors though (280+380+480)
Old Nov 6, 2009 | 03:39 PM
  #1492
Kane's Avatar
U need to hit up kgparts for some bigger ones.
Old Nov 6, 2009 | 03:42 PM
  #1493
Brettus's Avatar
Boosted Kiwi
/\ was thinking i would just put the yellows in place of the reds ... ???
Old Nov 6, 2009 | 03:43 PM
  #1494
Kane's Avatar
You are destined to do things the hard way huh? HAHA; kgparts will make them bigger, balance them and tell you exactly what they flow - makes tuning way way way easier since it takes the injectors out of the equation.
Old Nov 6, 2009 | 03:46 PM
  #1495
Brettus's Avatar
Boosted Kiwi
i'll see if i can find someone local to do it .....
BTW if i tell you how i did it you would poke me in the eye with a soldering iron so don't ask ........
Old Nov 6, 2009 | 03:58 PM
  #1496
J.Cab's Avatar
1st RX8 BNR Turbo Owner..
you must be flowing tons of air...what is your g/s looking like now? are you pushing in excess of 14psi?
Old Nov 6, 2009 | 04:03 PM
  #1497
Kane's Avatar
I am sure I would; probably welded the wastegate shut or something.......:sho cking:
HAHA
Old Nov 6, 2009 | 04:06 PM
  #1498
Brettus's Avatar
Boosted Kiwi
I know its around 350 because i saw 30g/s (at a higher ambient temp) more airflow than what i saw on the dyno when it made 325 .
My airflow is 360g/s which does not seem that high compared to others on here but maf scaling has a bit to do with that .....
Not sure of the psi - it's about 10psi at 7500
Old Nov 7, 2009 | 12:19 AM
  #1499
J.Cab's Avatar
Thumbs up
So around 350whp at 10psi? WOW!!!
Old Nov 7, 2009 | 12:40 AM
  #1500
Brettus's Avatar
Boosted Kiwi
well - not quite .
I've noticed that you get much better whp if your pressure is decaying from a higher level than if you are at a set pressure right to the redline .
Not to mention that the 10psi was a rough approximation - not a logged variable ....
