DIY: Mazda Ignition Coils (with pics)
Old Aug 20, 2010 | 03:50 PM
  #101
Tizop's Avatar
Great guide! Good pictures! I'll be doing this this weekend, and will defiantly be using this guide.
Old Aug 20, 2010 | 08:05 PM
  #102
Khaf's Avatar
I hope I am not going to get flamed for this post. My questions are regarding the attached picture.
Can I unscrew the screw with red arrow to remove the box marked with blue arrow to get some room to reach coils? (what is that box)
If still I do not have enough room can I unscrew the ones marked with green arrow to remove the accordion tube?
In both cases is there a washer in between that needs to be replaced once I unscrew it and opened it? When I am putting it back how much I should tighten them?
lastly what type of tie is the one marked with orange circle? If there is a vacuum line that needs to come out and have that type of ties how can I loosen and tighten it?
Thanks.
Attached Thumbnails DIY: Mazda Ignition Coils (with pics)-016.jpg
Old Aug 20, 2010 | 09:56 PM
  #103
yiksing's Avatar
the giant tastetickles
If i remember correctly, the blue one is just an airbox. You can disassemble any part there as long as you can put them back together but the easier thing is to remove the whole accordion tube and put it aside. The orange tie you just need pliers to loosen them but it still takes a bit of effort to pull the hoses off.
Old Aug 20, 2010 | 10:57 PM
  #104
Jon316G's Avatar
Grasshopper
Khaf- The green arrows are pointing to the clamps for the accordion tube.
Just unscrew it a few time until the clamp is free.
The blue arrow is pointing to the resonance chamber... its used for noise reduction.
Loosening the clamp (red arrow) will allow you to take that off, but the accordion tube is still in the way from reaching the coil's electrical connection, so why bother taking the chamber off?
Old Aug 22, 2010 | 12:35 AM
  #105
AdamK's Avatar
You can see my pics and what I removed here:
http://koczarski.com/RX8/Mods/BHRcoils/Coils.htm
Old Aug 22, 2010 | 01:57 AM
  #106
Khaf's Avatar
Thank you all, Adam you have very nice pictures. One question, I see that you removed couple of vacuum lines from your accordion tube. Did you simply pull them out and at the end push them back in? It's not going to leak later?
Old Aug 23, 2010 | 09:54 PM
  #107
RedLine9x's Avatar
nice pics for reference. just finished this a few minutes ago...beer of choice: Alaskan Amber. however i failed in the area of beer management for i accidentally kicked it over once in the process. it looks like you had MUCH more clearance than me, probably due to the K&N setup rather than the stock airbox which i just dismounted and pushed off to the side. also there was a wire bundle in the area i had to work around, kind of annoying but whatever. still got the job done.
Old Sep 10, 2010 | 12:20 PM
  #108
VashGS's Avatar
Zoom Zoom Addict
Thx ya'll I did coil swap with Oreilly BWD E1001 ($40 ea). It did have the B revision mazda part number. Runs a hell of a lot better. Looks like the original coils & plugs on it, with brand new warranty engine. Suspect former owner was told to do ignition job and sold vehilce.
Old Sep 23, 2010 | 09:43 PM
  #109
Khaf's Avatar
I want to thank everyone who contributed to this DIY specially OP.
Old Sep 23, 2010 | 09:58 PM
  #110
dozer's Avatar
on his 3rd rx8
you are most certainly welcome
Old Oct 25, 2010 | 05:53 PM
  #111
AdamK's Avatar
Originally Posted by AdamK
Installed the BHR coils over the weekend. Wow! It's like having my original RX8 back! No funny chirping when the car starts and it feels like it's running on 4 cylinders instead of 3.
I replaced 3 of the 4 plugs at the same time. The front trailing plug didn't want to budge when I tried to remove it. Gave me that sick feeling like I was going to do some damage if I tried any harder to get it out. Not sure if I just had bad alignment with the plug socket or??
Might take it to the dealer or a local rotary shop and see if they have any better luck.
I ended up paying the dealer $100 to change the plug. They got it out and determined it was the factory plug. One of the threads on the plug looked folded over so they "chased" out the threads in the head before installing the new plug. The mechanic was confident I shouldn't have any trouble with it. I was fearing the worst, but it all turned out OK in the end.....
The car is still running GREAT with the BHR coils!!
Old Oct 30, 2010 | 01:57 PM
  #112
marcx987's Avatar
just swapped my coils(didnt use diy just leaving note for stock airbox owners but for my 40 of choice would have to be king cobra)
and a note for all those with stock airboxes you dont need to remove it to do this.
just remove the noise dampening box by loosening the screw that attaches it and you can easily reach the coils with a proper extension.
this does include people with big hands like me should have plenty of room .
Old Nov 9, 2010 | 10:40 AM
  #113
AdamK's Avatar
So my car has been running a little "off" ever since getting it back from the dealer. There was a barely noticeable stumble at low RPMs just as the accelerator was starting to depress. I was thinking maybe they knocked a plug wire loose when they were replacing the one plug. I checked them a week ago and they were fine. So last night a gave the engine another look over and found they never tightened the clamp on the air tube from the filter box to the engine! Tightened it up last night and was pleasantly surprised this morning on the drive to work. The hesitation was gone and everything felt normal again! I was pretty surprised that this could make a noticeable difference. The rubber joint on the tube fits pretty snug even without the clamp tightened. I guess <some> air was leaking though and affecting performance??
Old Dec 9, 2010 | 02:07 PM
  #114
MommaRX's Avatar
In for write up! Good job!!!
Old Dec 9, 2010 | 02:47 PM
  #115
dozer's Avatar
on his 3rd rx8
thank you
Old Jan 9, 2011 | 02:04 PM
  #116
Chino075's Avatar
Thanks for the DIY. I did the lazy way and just removed the noise dampening box (as marcx987 mentioned). Lost a couple of skin but end result was the most important
Old Jan 9, 2011 | 02:08 PM
  #117
dozer's Avatar
on his 3rd rx8
Old Jan 19, 2011 | 01:54 PM
  #118
Decclan's Avatar
Decclan
Nuts...just paid dealer for this!!! I could have done!
I just replaced two IG coils at dealer and it looks so simple. Then again I didn't exactly know what was wrong when my RX-8 sounded horrible one morning so wouldn't have known what to look for. The dealer charged me $300 parts and labor. I figure this is breakdown.
(2) IG coils - $75 each ($20 - $25 price mark up)
Actual service technician pay for job done - $25
Service Manager time in berating technician, screwing job up somehow then having same technician fix manager's screw up - $200
Total: $300.00
Old Jan 19, 2011 | 01:57 PM
  #119
dozer's Avatar
on his 3rd rx8
that sounds about right...and only 2 were replaced? thats horrible, you wouldve saved your self time and money + you could've had ALL 4 replace if you did it yourself, the job only takes about 25 minutes
Old Feb 5, 2011 | 11:22 PM
  #120
Decclan's Avatar
Decclan
Oh believe me!
I will be doing the next ones and I will also be coming to this forum for other issues. I just did the A/C temp **** fix that is posted in this forum and it worked great. Saved me $250.
Love this site
Decclan
Old Feb 5, 2011 | 11:24 PM
  #121
dozer's Avatar
on his 3rd rx8
Old Feb 20, 2011 | 07:28 PM
  #122
snizzle's Avatar
Shakezula, the Mic Rula
Great DIY, changed my coils and plugs this afternoon.
Still got the rough idle but it's certainly improved..... guess I need to get the TSB motor mount checked at Mazda.....
Old Feb 27, 2011 | 09:13 PM
  #123
The Silver Fox's Avatar
The Silver Fox
Nice!
I was going to pay a boatload of money for someone to do a tuneup on my 04 but this guy makes it look to easy. Well done sir...
Old Mar 26, 2011 | 04:35 PM
  #124
Nofty's Avatar
stock
Great DIY. Instead of taking out the full stock airbox, I just removed the rubber piece inbetween MAF and filter box. After that it was easy access. Don't forget the new castle I had with me.
Old Mar 27, 2011 | 06:02 PM
  #125
Nice one dozer, did this a few weeks ago finally
