414 WHP Esmeril Racing Turbo RX-8
Old Nov 8, 2008 | 12:03 PM
  #101
cheeto's Avatar
has money, but unsure
all i want to know is at what RPM does full boost kick in. i love the fact that the MM turbo comes on to full boost before 4k rpm. how does the esmeril do?
the reason i ask, is that i will need good throttle response and quick boost when i am at the autocross track.
Old Nov 8, 2008 | 12:12 PM
  #102
Red Devil's Avatar
If you're in any type of competition with the RX-8, and you're below 6K rpms, than you are not driving the car properly.
Old Nov 8, 2008 | 12:44 PM
  #103
cheeto's Avatar
with a big turbo and even above 6k rpms, it can still have lag. thats what im worried about.
Old Nov 8, 2008 | 03:06 PM
  #104
GaMEChld's Avatar
Registered Noob
I forget precisely when I reach full boost, but I do know if you're at 6k there is zero issue, this thing spools right up when you're that high. If memory serves me right I think you get full boost around 5k or so, depending on the gear. I'll try to be more specific when the weather clears up and I sort out an issue with the car.
Old Nov 8, 2008 | 09:12 PM
  #105
cheeto's Avatar
maybe chris can chime in on my issue.
Old Nov 9, 2008 | 11:21 PM
  #106
BDC's Avatar
BDC
BDC Motorsports
Depending upon the hotside A/R, it'll be in the 4k-5krpm range. Once it gets goin', hold on to your butt. That's how full T4's are on 13B's. Great stuff.
B
Old Nov 10, 2008 | 12:33 AM
  #107
Flashwing's Avatar
3-wheeler
Originally Posted by ChrisRX8PR
Sometimes I just don't get it....There is a huge "want" factor regarding 400whp on a renesis and a benchmark is set and 2-3 years later when a company finally actually reaches it and provides proof then its not practical, and its not "reasonable" and so lets handicap everyone else...this is unbelievable to me.
Bottom line is....we gave you a 400whp+ Renesis...Period!
Chris
First Chris, congrats on an awesome benchmark. Developments like this were just a matter of time, engineering and effort. I've had to listen to notions for a while that this rotary wasn't capable of 400+ whp without serious modifications but we're finding the technology and the means. Excellent work.
I think much of the need here is more with how turbo kits are marketed rather than their capability. I know owners with 500+ whp vehicles that make that power safely but a "reasonable" power level would be something safe to drive daily IMO.
Nobody is going to handicap you guys for this.
Originally Posted by BDC
I'll be curious to see if any one customer, who possesses the same hardware et al, can replicate this.
B
I think this is a great opportunity to examine the difference between Esmeril's kit and which leads me to the point of my post. The importance here (from a customer standpoint) is to be able to tell the difference between what the "kit" is capable of and what the car is capable of.
Originally Posted by rotary.enthusiast
This dyno plot was done at 16 PSI which is much higher than the shipped kit is set up for. With time, money, and a good tuner somebody could do it probably, but IMO people that have those things will be looking elsewhere to begin with.
Thanks RE for pointing out that key aspect. The reason why the MM kit is marketed as it is for the fact that MazdaManiac wanted to ensure customer's knew what to expect from the kit out of the box. It's the age old practice of underpromising and overdelivering.
What owners and future buyers of the Esmeril kit should keep in mind is that, unless specified, the kit as it's currently shipped would need modifications and additional parts to reach the 400+whp goal. If the dyno plot was created using the kit as shipped I'd glady stand corrected.
Originally Posted by GaMEChld
it's gotta be brutal to keep it that high regularly, I don't think this is meant to foster hope of driving around with a 400WHP rx8 daily driver, it's just a new best for the kit.
Right, this wasn't a thread showing the best way to run the Esmeril kit on the street, just showing what it can do.
Should it even be put into the thread? I think that thread is for reasonable driving. I don't think we're supposed to drive around with 414whp, it was just a fun benchmark. The MM/BHR kit is listing its reasonable levels of power, not its all time highest dyno runs.
No, the dyno thread is to show what current RX8 turbo kits are being marketed for power wise. Now, Esmeril could choose to market their kit as a 414 whp kit of they so choose. I would argue that it would be a misrepresentation unless the kit came with exactly what was used to produce the results of the dyno.
Again, the MM kit was marketed at 310whp because MazdaManiac knows the kit will make that power with proper tuning on virturally every RX8 that uses it. If the kit makes more power then that's great! The idea is to avoid having customers buy your kit and then spamming you with upset emails and phone calls cause they didn't make 400whp like you said the kit would make.
The 3071R turbo was chosen for various reasons aside from the fact that you really can't jam anything larger into the space by the manifold than that size. At the time of the kits creation 400whp was the assumed limit of the car on pump gas as well as the transmission/drivetrain. Simply put, the amount of air needed to make that power was calculted and then the 3071 was chosen cause it flows that needed air at it's most efficient point.
The Esmerial turbo has the ability to flow more air but the sacrifice is the need for more time to build boost. It just goes to show you that it's critical to size a turbo for the application you intend. It's all a compromise.
Sorry for the long post!
Chris I'm in no way attempting to poke you guys. I think there's a great opportunity to contrast how products like this are marketed and you guys provided a great example of one way it's done. I hope that Esmeril customers are able to easily duplicate your results.
Old Nov 10, 2008 | 11:00 AM
  #108
GaMEChld's Avatar
Registered Noob
^ I just found out Chris is daily driving that 414WHP tune. I assume once he can personally vouch for it's reliability, he may start marketing as such. And I'm pretty sure the modifications he has is the kit as shipped and the ignition upgrade. Crazy stuff.
Old Nov 12, 2008 | 03:01 PM
  #109
ssspeedfreak's Avatar
I agree with the sizing the turbo with the desired results. Thats why the TQ graff is what I like to see because I'm not looking for those hudge revs to make power. If this kit makes decent power Hp and Tq at a reasonable rev thats what matters, weather or not its at full boost doesn't matter to me. Lets see when all this happens.
Old Nov 12, 2008 | 04:06 PM
  #110
enthegen's Avatar
wfc#046
So where are some photos and videos of this car?
Old Nov 13, 2008 | 01:22 PM
  #111
636's Avatar
636
Rice Police
Hey Chris , can you post up videos of the dyno session and maybe some street videos? I want to see
Old Nov 19, 2008 | 03:07 PM
  #112
I just don't know why this thread doesn't get the hits that the RP Supercharger that never came out does! Come on guys no love here, I mean I'm not sold yet on anything but just to have the choice to have an Rx8 over 400hp and 300TQ is money! I'm still holding out to see what MM/BHR can do but this kit is definatly on my list. My only suggestion would be just to put the ignition upgrade into the kit and it will be a true 400HP 300TQ(my big dream) out of the box! What about the fuel pump? Mazsport always says it NEEDS to be upgraded, chris how do you feel about that?
Old Nov 19, 2008 | 03:45 PM
  #113
ChrisRX8PR's Avatar
13B-RE
Thanks for the props!
Our kit brings a complete fuel upgrade including a new fuel pump and injectors. The included combination should be good to make it to 400whp safely. Our website has a general list of what's included as well as a few pics of the components.
Chris
Old Nov 19, 2008 | 07:54 PM
  #114
Rotore_787's Avatar
I kill Vtec's
nice chris raitru bro ta cabron el turbo. i been researching and lookin at the dynos and this really caught my eye 414whp more then 300tq is awsome for rx8 owners on top of that they're about to market apex seals!!! my thought is if those apex seals are the real deal then we could posibily make more then 414whp and more TQ!!!!! lol so como yo dije nice job chris ill be lookin at your kit
Old Nov 23, 2008 | 07:38 PM
  #115
ok chris lets hear about these apex's!
Old Nov 26, 2008 | 11:37 AM
  #116
neXib's Avatar
Kickass numbers!
Out of curiosity, if it's the apex seals that are prone to problems with detonation. How do you even approach the "first" tune. Since neither too rich or too lean is safe. One ping and you're gone? (forgive me for asking, I'm curious about all theory on these engines)
Old Nov 26, 2008 | 05:24 PM
  #117
636's Avatar
636
Rice Police
^^Go with a safe map and tune rich and go slowly from there?
Old Nov 26, 2008 | 06:04 PM
  #118
neXib's Avatar
The reason that I was asking is that it was implied that rich isn't always safe. But I assume that within reason it probably is, with what you call a safe tune.
Old Nov 28, 2008 | 12:59 PM
  #119
cheeto's Avatar
still need to see a map to see when boost kicks in.
Old Nov 28, 2008 | 01:19 PM
  #120
Falken's Avatar
Drop it into 3rd
I'm sure the math gurus on this website could give some equations for approximate initial tune, if you asked nicely.
Old Nov 28, 2008 | 06:18 PM
  #121
Dethwalkin's Avatar
Chris
Hey Chris, Ever sence I told you that your "included injectors" failed and I lost a motor, you haven't returned any of my many phone calls. What's up. Please dont give me any song and dance. Just call me. If you can't afford the call then tell me when I should call you.
Old Nov 29, 2008 | 01:49 PM
  #122
GaMEChld's Avatar
Registered Noob
He's hard to reach by phone usually. I've tried before, but all my communications have been handled through PM.
Old Nov 29, 2008 | 02:04 PM
  #123
Dethwalkin's Avatar
i'm mainly trying to talk with Jason from mazdaparts. I know he works hand in hand with Chris.
Old Nov 29, 2008 | 03:56 PM
  #124
GaMEChld's Avatar
Registered Noob
Also, I don't think either of them do business on the weekend, so you'll probably have to wait till Monday
Old Dec 6, 2008 | 03:30 PM
  #125
NYC Drift King's Avatar
Supercharged by Pettit
wow a long read but I'm hopefull. Good Job.
