Brettus Turbo install thread
Old Nov 6, 2008 | 07:22 PM
  #76
blackenedwings's Avatar
Life begins @ 30 psi
So jealous...brain hurts.... ....I mean, congratulations.
Old Nov 6, 2008 | 09:00 PM
  #77
Brettus's Avatar
Boosted Kiwi
Originally Posted by atl8
The coil dwell is in milliseconds, so 395 is .395ms, which is the stock value across all voltages at 9000. I've seen Scott recommend using values of 3-3.5ms for FI, and how 2.0 is "adequate" for NA applications. But I've never seen the actual ratings for the Mazsport coils posted anywhere.
Regardless, the stock table interpolates the values from highest value top down by battery voltage, and right to left by RPM so I find it unlikely that 3000 or 3500 would be what you'd want to set it to at 9K.
Yeah - talked with Hymee about that . We think the stock table is ms x100
so 395 = 3.95ms .
Going back to first principles ....
at 9000 rpm we have 3000 rpm of the rotor but 3 firings per rev so 9000 firings per min = 1 firing every 6.7ms
So the stock dwell of 3.95ms makes sense
Also at 1000rpm we have a firing every 60ms and the table is 1800 at 1000rpm .
Again 18ms of dwell would make sense there as well . 0.18ms or 1.8ms does not .
Old Nov 7, 2008 | 03:47 AM
  #78
rotarenvy's Avatar
Originally Posted by olddragger
288 is ok at 8.5 and a fair indicator of power. I have at times seen close to 300 at around 8.5-8.7. Not comparing now--it doesnt mean mine is better etc etc.
OD
so has anyone referenced 280-290g/s (kind of need to know @ what rpm too) to a dyno reading?
Old Nov 10, 2008 | 05:03 PM
  #79
Brettus's Avatar
Boosted Kiwi
Latest runs show i'm getting 300g/s
Old Nov 10, 2008 | 09:47 PM
  #80
Brettus's Avatar
Boosted Kiwi
Getting AFRs pretty well nailed ...
Boost is currently 7.5psi up to about 6000rpm then tapering down to 5.1psi at 8250rpm
Old Nov 10, 2008 | 09:53 PM
  #81
Easy_E1's Avatar
Get those numbers up to the 12.3's and you should be happy.
Old Nov 10, 2008 | 09:57 PM
  #82
05rex8's Avatar
sold the 8... :(
congrats man, I wish my AFR's were that close!
Old Nov 10, 2008 | 10:00 PM
  #83
Brettus's Avatar
Boosted Kiwi
Do you think that will give me a few extra horsies ?
Old Nov 10, 2008 | 10:03 PM
  #84
Easy_E1's Avatar
12 to 12.3 will get you more HP. On the edge though.
Old Nov 11, 2008 | 07:40 PM
  #85
Brettus's Avatar
Boosted Kiwi
You asked for the videos so here goes .
First one is through the gears , not really trying i get 0-160km/hr in 12.7 sec . Would be under 12s if i took it to 9k in third !!!!!!
http://www.youtube.com/watch?v=EkiV4sgu65E
This one is from when I was still NA , 0-160km/hr in 15.7sec with one less gear change (higher red line)
http://www.youtube.com/watch?v=NzlvSC_8N-Y
If you have them both open at once and click on the Turbo one after the NA has been running 4sec you will get a good idea of the difference .
Old Nov 11, 2008 | 08:46 PM
  #86
05rex8's Avatar
sold the 8... :(
nice!
Old Nov 11, 2008 | 09:28 PM
  #87
Originally Posted by Brettus
I'm seeing 288 g/s MAF at 8500 - what do you see and is this an indication of the power output ?
in my experience in this car G/S is nearly exactly the flywheel HP
Old Nov 11, 2008 | 09:36 PM
  #88
oh and good on ya Brettus
Old Nov 11, 2008 | 09:41 PM
  #89
Brettus's Avatar
Boosted Kiwi
cheers for that zoom . Dyno is booked for tomorrow afternoon
Old Nov 11, 2008 | 09:54 PM
  #90
mysql's Avatar
Doppelgänger
Here's one of mine to compare. I was down over 40 whp on the dyno with this configuration.
Code:
Coolant	MAF	ThrottleO2	Load	IAT	RPM	MPH
203	241.43	100	12.07	86.67	93	5668	59.03
203	248.71	100	12.06	86.27	93	5779	60.28
203	250.98	100	12.18	86.27	93	5869	61.52
203	256.99	100	12.39	86.67	93	5959	62.14
203	261.31	100	12.55	85.88	93	6069	63.38
203	263.7	100	12.62	85.49	93	6153	64.63
203	270.9	100	12.48	84.71	93	6256	65.25
203	270.9	100	12.27	83.92	93	6334	66.49
203	265.14	100	12.14	81.57	93	6436	67.11
203	271.38	100	12.66	81.18	93	6542	68.35
203	277.14	100	12.74	81.57	93	6648	69.6
203	289.79	100	12.5	83.53	93	6743	70.84
203	295.88	100	12.43	83.53	93	6860	71.46
203	301.48	100	12.29	82.75	93	6970	72.7
203	309.97	100	12.29	82.75	93	7062	73.33
203	305.7	100	12.22	83.14	93	7138	74.57
203	314.24	100	12.09	83.14	93	7239	75.81
203	314.24	100	11.99	82.35	93	7340	76.43
203	324.02	100	11.85	82.35	93	7410	77.68
203	317.98	100	11.64	80	93	7510	78.3
203	318.51	100	11.65	80.39	93	7557	78.92
204.8	321.25	100	11.68	79.61	93	7673	80.16
204.8	322.91	100	11.78	77.65	93	7785	80.78
203	331.24	80	11.82	78.04	93	7786	82.02
204.8	318.54	24.31	11.35	65.88	93	7847	81.4
204.8	27	3.92	11.87	14.51	93	7327	81.4
204.8	33.41	3.53	11.33	8.63	93	6888	80.78
Old Nov 11, 2008 | 09:57 PM
  #91
mysql's Avatar
Doppelgänger
^ That's with the AccessPort btw.
Old Nov 11, 2008 | 10:33 PM
  #92
Brettus's Avatar
Boosted Kiwi
/\ quite a noticable difference - what PSI were you running ?
A little experiment . The Greddy gives peak power at around 6krpm so I thought I would try some short shifting to see if it is worth going past 7k shift point.
http://www.youtube.com/watch?v=9ItRibHBMLc
Result 13.0s flat 0-160km/hr . A tad slower but in the same ballpark - interesting . I think i'll shift around 7500 at the track
Old Nov 11, 2008 | 10:37 PM
  #93
olddragger shifts at the same point on the track with the pettit kit..
the fi takes all the shifting out of track days!!!
Old Nov 11, 2008 | 10:48 PM
  #94
mysql's Avatar
Doppelgänger
OK, here's the dyno run when I was really down on HP. I also data logged and video tapped it.
The MAF and RPM numbers that were logged during the dyno session:
Code:
MAF    RPM
302.01	6622
309.97	6719
316.38	6791
317.45	6896
331.24	7007
335.13	7094
339.07	7202
340.78	7287
343.07	7393
344.21	7492
331.24	8085
It's going to be difficult to make sense of this since the car wasn't working properly. I guess this is a good example what it looks like with the AP and not setting the dwell on the "upgrade" coils. So with properly functioning coils the same g/sec would likely have produced more power. I don't have data logs of previous dyno runs to compare unfortunately.
Here is the video footage of the dyno run: http://tyrannical.org/baddyno.wmv
You can hear it breaking up..
And finally, here's the dyno chart (I'm also including the raw .csv and .drf):
File Type: zip
Old Nov 11, 2008 | 11:02 PM
  #95
317.98 g/s @ 7500 from the first post
vs
344.21 g/s at 7492 in you latest post
you're off nearly 30 g/s just between these 2 runs and you say the second post is low as well?
Old Nov 11, 2008 | 11:11 PM
  #96
mysql's Avatar
Doppelgänger
boost levels are likely different. I was only data logging because the car wasn't running properly. Otherwise I wouldn't have bothered making logs..
I posted the wrong dyno picture earlier, so I've corrected it and included the raw log from the data logger and the dynojet .drf file.
Old Nov 11, 2008 | 11:12 PM
  #97
gotcha
Old Nov 12, 2008 | 12:12 AM
  #98
Brettus's Avatar
Boosted Kiwi
just speculating here .... My Mazsport coils have been good with stock dwell settings up to 8psi (so far) .
So ...... it seems your problem is more likely caused by wrong dwell when you were running the Int x .
Stock dwell seems ok . If anyone can shed more light on this i'm all ears .
Old Nov 12, 2008 | 06:16 AM
  #99
mysql's Avatar
Doppelgänger
That is completely possible.
Old Nov 12, 2008 | 10:26 PM
  #100
Brettus's Avatar
Boosted Kiwi
Here is the dyno
Red line is without the boost controller.
Blue line is with boost set to 8PSI
Impressed with the top end vs the stock Greddy
The peak number is OK but not startling 193kw = 259hp
