Baseline Automated Tuning Beta Now Available for Download
Old Nov 20, 2008 | 06:27 PM
  #76
Kane's Avatar
Be sure to check out the site folks - I am going to start putting more indepth info there to save typing and editing time.
http://www.ppo2performance.com/
Old Nov 21, 2008 | 06:16 PM
  #77
morkusyambo's Avatar
Dongbag extrordinare
Kane. I need to know the AFR latency for stock injectors and the logging interval for the stock ECU.
Old Nov 21, 2008 | 06:20 PM
  #78
I'm totally clueless when it comes to Microsoft Office. I can't get past the psi table during initial setup.
Old Nov 21, 2008 | 06:23 PM
  #79
Kane's Avatar
I am unsure what the AFR latency is for the stock O2 sensor; you can try to make a log and let off the throttle to find out.
Logging Interval - Do you have the AP? For the AP; it looks like the logging interval is 100ms - per CW's log.
Old Nov 21, 2008 | 06:31 PM
  #80
Kane's Avatar
After PSI - click NEXT; and it should open the RPM form.
Old Nov 21, 2008 | 08:00 PM
  #81
Kane's Avatar
Looks like my site crashed....bummer - I have a call in to my webmaster...
The links from Post 1 still work.
Old Nov 21, 2008 | 09:24 PM
  #82
Kane's Avatar
Site is back up - kinda...
Old Nov 22, 2008 | 02:49 AM
  #83
J.Cab's Avatar
1st RX8 BNR Turbo Owner..
Originally Posted by Kane
It should be - but my tester had an O2 sensor issue (or something).
If you set up the Manifold scale in load like the AP; all else being equal your fueling will work the same - the air calculations; Like Horsepower etc will be off - but the actual tuning part should work. - Key word SHOULD; haven't tested it yet - but you can play with it if ya want to.
I am waiting on a MAF/Load based EMS (like the AP) to actually verify this information - and make the appropriate changes to my software so all the stuff works.
Kane, I am going to try and get with Chris ASAP. Installed the new O2 Sensor, and AFR are good to go. Was even able to get down to 11.1 while in boost. I am going to datalog some, and then send him and "cc" on the emails. Finally my car is running a lot whole better.
Old Nov 22, 2008 | 04:34 PM
  #84
Kane's Avatar
Cool; let me know how it goes.
BTW; did you tell everyone about your tuning demo with Chris's FD, I heard you were a bit apprehensive....
Old Nov 23, 2008 | 03:32 PM
  #85
Kane's Avatar
Did you get past this?
Old Nov 23, 2008 | 04:53 PM
  #86
Should I enter the maximum psi with boost, which would be 9, or do I add that to sea level which would be 23??
Old Nov 23, 2008 | 04:54 PM
  #87
Kane's Avatar
Boost only; so 9 or 10 if ya wanna be safe.
Also be sure to do vacuum too; negative PSI numbers
Old Nov 23, 2008 | 05:01 PM
  #88
How would I setup the injectors for a stock system?
  #89
So all I need is one # indicating maximum vacuum and one indicating maximum boost??
Old Nov 23, 2008 | 05:06 PM
  #90
Kane's Avatar
Stock injectors are P1-280/290cc (I forget off the top of my head; 99.999% sure they are 280) Secondaries-380cc and P2-380cc.
You need to do a manifold scale; so like the RPM scale youneed to specify the range you wanna be in.
-14.7
-12
-11
-10
-9
-8
....0
10
Like that. Unless you are tuning with the MAF (AP and Flash tools).
Then you want to use Calc Load
.1
.2
.3
.4
1.2
1.3
1.4
1.5
and so on.
For RPM's scale you do the same thing but with RPM.
500
1000
1500
2000
8500
9000
You can make the scales smaller (More numbers) if you want more detail.
Old Nov 23, 2008 | 05:16 PM
  #91
Kane's Avatar
Here is the Fuelinfo from Mazda
Attached Thumbnails Baseline Automated Tuning Beta Now Available for Download-fuel.jpg
Old Nov 23, 2008 | 05:24 PM
  #92
Okay. I'm currently building the rpm/psi/target AFR tables
  #93
How would I input that into Baseline??
Old Nov 23, 2008 | 05:27 PM
  #94
Hey Kane. I don't have a laptop available so i'm planning on importing an EFI Dude csv log into Baseline. Then making a map with the ATR on my desktop with the resulting #'s. Think that'll work??
Old Nov 23, 2008 | 05:42 PM
  #95
Kane's Avatar
Ah ok - then do the Manifold scale in load.
As for the fuel info; as you can see the Mazda stockers have a range in them - so just set up up with 280-380-380 cc values.
As for fueling style it would be staged; the P1 are available all the time; the Secondaries are available after 4000 RPM and the P2's are (not 100% sure; I have mine seperated from the PCM completly).
Anyone know about the P2's?
Old Nov 23, 2008 | 05:44 PM
  #96
Kane's Avatar
Should. Show me the CSV from EfiDude... I need to checks it out.
Old Nov 23, 2008 | 06:01 PM
  #97
Can I put a range in for the fuel injectors, like 69-78, or just the maximum flow of 78??
Old Nov 23, 2008 | 06:04 PM
  #98
Would 2.6 be the maximum duration in ms for the P1(red) injector. Also, should i setup 4 different injector tables(2 P1 and 2 P2), since the software doesn't seem to account for staged injectors??
Old Nov 23, 2008 | 06:05 PM
  #99
Kane's Avatar
Do the max I guess; or the midpoint - and the image I showed is for 15 seconds; so times by 4 to get cc per min.
Baseline will learn what they actually are as you tune.
Old Nov 23, 2008 | 06:06 PM
  #100
Kane's Avatar
No Do three injectors; the software does it in injectors PER rotor or Cylinder.
