NEW! Esmeril Racing RX-8 Apex Seals Released for Sale.
Old Sep 11, 2009 | 01:03 PM
  #51
glassman's Avatar
Originally Posted by ChrisRX8PR
How do you think Atkins, RA, ALS, NRS, KIWI, ETC started selling their seals for the RX-7? they certainly didn't test them for 5 years
Chris
No, just 4 years and I've posted on a few occasions the specs for my material.
Old Sep 11, 2009 | 01:45 PM
  #52
ChrisRX8PR's Avatar
13B-RE
That is great. I will not be posting the specs of ours. That is a decision we made, that fact that one manufacturer posted theirs in a different market where there are already many other brands of apex seals does not mean I will do that here. There have been more than a few buyers already...I know at least two of them will pushing them to the limit. Let the customer reviews begin.
Chris
Old Sep 11, 2009 | 02:35 PM
  #53
rotarygod's Avatar
As a person who does work with different metals based on their properties I can tell you that even if he did say exactly what metal it is, it doesn't tell us a whole lot. It doesn't take much effort to figure out which metals would or would not be good to use. Based on temperature requirements, expansion properties, pre-heat treatment hardness, etc, anyone who knows a little bit about metals could figure out what the base metal is or at least get one that has very similar properties.
What this doesn't tell us is how fine are the tolerances, specifically compared to stock seals? Are they slightly thicker, thinner than stock? Have they been heat treated? Even if they have been, at what temperature where they taken to, how long did it take to get it there, how long was it held, and how long did it take to cool? Were they just normalized, quenched, and tempered or where they held to a certain heat for a certain amount of time with controlled cooling over a certain period? You can drastically change the hardness and brittleness of nearly any metal quite substantially through the heat treat process so even just doing a hardness test on a finished seal is nearly worthless information.
Was the whole seal heat treated or was it just the sliding surface? Since the edge of the seal is rounded (as it has to be), how accurate was this shape held. What is it's radius? How fine of a surface finish is there on the seals? Were they machined pre or post heat treat? Was there both pre and post heat machining?
These are the kinds of questions you need to know in order to determine exactly what he has. Just knowing what metal is was and if it was heat treated don't really tell much. It's the process that is proprietary as it doesn't take a genious to figure out what metals are viable candidates. Mazda uses cast iron with an electron beam edge only heat treat fwiw. Cast iron is inherently brittle. It also doesn't have a very large coefficient of heat expansion. Right off the bat we know that if it's not as brittle, it's probably not iron and it's probably not cast. If it is iron that he used, which I doubt, I guarantee it wasn't cast and then machined to shape.
The point of this is to basically say to get over the lack of material being disclosed. Most people wouldn't know what to do with the info if they had it and those that would probably wouldn't care enough to go make a set anyways. If they work well, the results will speak for themselves. You guys aren't going to be able to go to your local metal shop, buy sme scrap metal and then cut your own seals so what they are and how they are made isn't of any importance to anyone.
Old Sep 11, 2009 | 04:26 PM
  #54
stinksause's Avatar
The Stink w.o The Sause
lol ... leave it to rotarygod to show everyone up ... props
Old Sep 22, 2009 | 05:12 AM
  #55
@!!narotordo's Avatar
FLAME ON!
Cool. Now I know where to get my seals and my turbo kit lol
Old Nov 9, 2009 | 12:48 PM
  #56
Nemesis8's Avatar
Bigus Rotus
I did not see this mentioned, or if it was, I missed it. Is there any rotor machining to accept these? Or are these the same dimensions as the OEM seals?
Old Nov 9, 2009 | 12:56 PM
  #57
reddozen's Avatar
Gold Wheels FTW
Plug and play.
They're made to fit the RX8 rotors and housings. I'll be using them in my new motor if I can ever get my finances back on track.
Old Nov 9, 2009 | 01:00 PM
  #58
shaunv74's Avatar
Power!!
Chris: Any plans to create upgraded side seals? I know this is a common failure mode for the Renesis even in NA form. I suspect due to the impact with the side ports. Maybe something that is also less brittle and would have enough flex to it to take the hits and keep on ticking.
Old Nov 10, 2009 | 10:01 AM
  #59
Nemesis8's Avatar
Bigus Rotus
No compatibility issues with Idemstu Racing injection oil are there?
Old Jul 4, 2010 | 02:08 AM
  #60
csl's Avatar
csl
Can anyone who uses these seals on boost application please give some feedback? Thanks
Old Jul 4, 2010 | 02:24 AM
  #61
Brettus's Avatar
Boosted Kiwi
Thread with feedback here :
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/esmeril-racing-apex-seals-fid-renesis-post-your-experience-good-bad-195598/
Old Jun 2, 2015 | 09:34 PM
  #62
gamaliel31's Avatar
PR saludos
Chris
Mira lo que me hizo Galdy en bayamom. Me dijo que eres pana. Necesito los carbones pronto para poder subir de libras. ahora mismo estoy fabrica por dentro.
Panthersn
Jul 13, 2021 06:30 AM
uZu
Dec 30, 2015 12:35 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
thedragonrotar
Jul 22, 2015 08:46 PM
Thechosen1
Jul 22, 2015 08:28 PM
