NW RX-8 Forum Serving WA, OR, ID, AK
Renesis v2.0
Old Dec 29, 2009 | 01:01 PM
  #26
pdxhak's Avatar
Official Post Whore
Originally Posted by dondo
i'm up for some grunt work. just tell me when.
Same here
Old Dec 29, 2009 | 01:07 PM
  #27
NgoRX8's Avatar
damn, looks like its going to be a beast of an engine.
Old Dec 29, 2009 | 07:11 PM
  #28
Originally Posted by tubingchamp
Dude.. You still have that sittin in your kitchen?
I remember seeing that last year on the first mechanical day at your place.. When we popped on Colin's coilovers.. Ha
I'm waiting till my OEM clutch goes....so far the damn thing is good as gold....
I have a modified transmission and the clutch to put in.....this winter if I get the time in the shop I want
Old Dec 30, 2009 | 03:46 AM
  #29
bse50's Avatar
#50
Modified transmission? do you mind to pm me about it?
/ot
Old Dec 30, 2009 | 11:44 AM
  #30
Brettus's Avatar
Boosted Kiwi
Sounds great - look forward to seeing some results .
Have a look at doing a long header with a joiner back past where the cat sits .
Old Dec 30, 2009 | 12:14 PM
  #31
Nemesis8's Avatar
Bigus Rotus
As much as I would like to do that, like Mark Pickering and Eric Meyer did, I will be using my Racing Beat header.
Old Dec 31, 2009 | 01:15 PM
  #32
Nemesis8's Avatar
Bigus Rotus
While I wait for the engine and intakes to be built, I have started another project.
I will also be building a custom midpipe by modifying a Racing Beat race pipe. I will add the Davesport performance metal core 100cpi catalytic converter, along with a Vibrant stainless steel race muffler or the stock OE resonator. I have the race pipe sitting in the garage and was only used once at ORP. I thought about hacking up my dual resonated Racing Beat midpipe, by cutting out the front resonator and selling it to somebody that might be reading my thread - hint, and welding in the Davesport. But I would hate to hack up that beautiful piece of workmanship. Those RB welds are sweet looking. There are multiple reasons for building this.
Old Jan 1, 2010 | 04:43 AM
  #33
As thick as that pipe is any welder worth their weight in salt should be able to make pretty welds
and please don't fall for that long tube hype, the people who keep yammering about it have selectively chosen not to acknowledge the other results demonstrating equivalent output, and while being emissions legal no less ....
Old Jan 1, 2010 | 08:52 PM
  #34
Nemesis8's Avatar
Bigus Rotus
^ Yes, I agree with your take on the welding. And by the way, thanks for replying to my hint. Our factory has welders with over 20+ years, so I will ask the boss if I can get a "government" job completed on the RB race pipe hack. Are you still still interested in the front RB resonator off their midpipe if I choose to hack it up? That is, if I don't like the Davesport/Vibrant RB race pipe result?
Old Jan 1, 2010 | 09:12 PM
  #35
Thanks, but I already bought something esle. You shouldn't have any problem selling it on the forum.
Old Jan 1, 2010 | 09:33 PM
  #36
olddragger's Avatar
Nem--sounds like a sweet build.
get a 150psi oil pressure gauge
if you are doing lim work trying to reduce heat soak--there are spots on the lim that can be opened to help ventilate it, casting marks inside the manifold that can be removed and work to be done on the vdi.
you will also need a true phenolic lim gasket as the intake has a rather large footprint on the engine and that alone will heat soak it!!. i have pics around somewhere where i did mine---
dont forget to get your injectors balanced and flow tested-i was surprised about the ones i had!.
i am seriously looking at getting a better oil cooler thermostat. you may want to look at that?
Wish i was there--
olddragger
Old Jan 2, 2010 | 12:14 AM
  #37
Nemesis8's Avatar
Bigus Rotus
Hey OD - thanks for looking at my build. The 150 range could be a problem, as I have the Racing Beat gauges, and it goes to 100 PSI, unless there is a swap for it. Also checked out your LIM awhile back when you did that work - real nice by the way, and will follow on what you did. I need to bounce some ideas off Brian at BDC. Yep - injectors will get a tune up. I'm sure this will nickel and dime me as I go, but so be it. I'm not going to cut corners as you can see.
Old Jan 2, 2010 | 02:27 PM
  #38
Nemesis8's Avatar
Bigus Rotus
New Parts Arriving
The newly designed SSV is here. Notice that the bronze bearing has a relief machined into it. It is covered with a wrap to keep the grease from drying up.
Attached Thumbnails Renesis v2.0-new-ssv.jpg   Renesis v2.0-new-ssv-bearing.jpg   Renesis v2.0-lim-gasket.jpg
Old Jan 2, 2010 | 06:07 PM
  #39
Nemesis8's Avatar
Bigus Rotus
More Parts!
The engine goes back next week to Mazmart
Attached Thumbnails Renesis v2.0-engman-reman.jpg   Renesis v2.0-greddy-oil-pan.jpg   Renesis v2.0-mazmart-thermostat.jpg   Renesis v2.0-rb-gauge-pod.jpg
Old Jan 2, 2010 | 06:12 PM
  #40
shaunv74's Avatar
Power!!
So jealous. :P
FYI: Racing Beat may have a higher pressure range oil pressure gauge they can swap out for you.
they don't have an '09 kit yet but may have a gauge that will work.
Old Jan 2, 2010 | 06:21 PM
  #41
That block will have more miles on it than your car
Keep me in the loop for when
Old Jan 2, 2010 | 06:22 PM
  #42
shaunv74's Avatar
Power!!
+1. I'm definitely down for showing up and helping out.
Old Jan 2, 2010 | 09:42 PM
  #43
olddragger's Avatar
rb uses auto meter gauges and auto meter has a 150 one.
Thats an oem intake gasket?
Going to port your TB?
Hard to set around new parts isnt it?
i was outside today in 37f weather working on this alzheimers delaying thing.
OD
Old Jan 3, 2010 | 11:11 AM
  #44
Nemesis8's Avatar
Bigus Rotus
That is good news - will call them to see if they will swap me, or I'll just buy one here locally. Yep - new LIM gasket for the block. I am working on a spare LIM currently, and the gasket that it came with needed replacement. TB has already been ported by Brian at BDC.
At least I get a big break on freight charges where I work. It cost me $180 to ship that motor 2800 miles. Dannobre does have a good sense of humor about the miles it will have on it. LOL
Wait till you guys see the UIM when it is complete
Old Jan 3, 2010 | 12:53 PM
  #45
Brettus's Avatar
Boosted Kiwi
Are you making a polished aluminium UIM ?
Old Jan 3, 2010 | 03:26 PM
  #46
Nemesis8's Avatar
Bigus Rotus
I'm aluminum plating an OEM manifold after it gets cleaned up a bit.
Old Jan 6, 2010 | 01:34 PM
  #47
Nemesis8's Avatar
Bigus Rotus
Sounds like the BHR Flywheel is in the mix now. I need to see if my Mazdaspeed counter weight will work with it. At first glance it looks promising.
Old Jan 6, 2010 | 02:00 PM
  #48
I don't think you will get any benefit from the AL plating or Ceramic coating.
Old Jan 6, 2010 | 02:32 PM
  #49
Nemesis8's Avatar
Bigus Rotus
That's not the point of doing it
Old Jan 6, 2010 | 09:09 PM
  #50
Blliiiiiingggggggg
