DIY: Mazda Ignition Coils (with pics)
Old Aug 11, 2009 | 05:17 PM
  #26
dozer's Avatar
on his 3rd rx8
Old Aug 11, 2009 | 05:18 PM
  #27
rodjonathan's Avatar
silent assasin
question do i have to change my plugs with my coils and wires ... reason being i just got a sweet deal on coils and wires but cant spend money on plugs yet so should i just wait and put em in all together? the coils and wires have about 10k on em in oppose to my 30k
Old Aug 11, 2009 | 05:19 PM
  #28
nope, you don't HAVE to. I usually recommend people do it all at once since you're already workign in that area but if you don't mind doing a little work you can do them on seperate ocassions.
Old Aug 11, 2009 | 05:31 PM
  #29
silent assasin
cool thanks i dont mind the work ill prolly do em in a few weeks but will do the coils and wires now
Old Aug 12, 2009 | 09:02 PM
  #30
Teoz's Avatar
Just did my coils tonight. Is it common to have the white spots under them? Out of 4 coils 3 had the white spot. One being quite big. But oh my did it make a difference. No more sluggish take offs. Just need to clean the MAF and TB tomorrow and hope to get the bitch to idle better.
Old Aug 12, 2009 | 09:15 PM
  #31
tmak26b's Avatar
yes its normal, you can only test them under load. I say just replace it every 30K to be safe.
Old Aug 31, 2009 | 01:29 PM
  #32
silent assasin
probably a silly question but what order are the coils in t1t2 etc ...
Old Aug 31, 2009 | 01:31 PM
  #33
dozer's Avatar
on his 3rd rx8
i honestly wasnt payin attention, i just did one at a time so i wouldnt fck anything up
Old Aug 31, 2009 | 02:16 PM
  #34
silent assasin
ok cool ill look some more i remember reading it somewhere coz i got coils that were used for 2k miles for free so i wanna use them the same way they were used for the 2k thanks though
Old Sep 4, 2009 | 01:06 PM
  #35
J wind's Avatar
I would do both coils and plugs, or in my case, the wires too. When I finished last night, I took a good look at my old plugs, man were they rusty.
Old Sep 25, 2009 | 02:38 AM
  #36
jeanosh's Avatar
Hi does anyone know if there is a sequencing number to the coils? my CEL light came on and had it checked, and the meter says something like 'No.4 Ignition Coil Failure'...so which is no.4? the one nearest to the windscreen? yes I know I should change all 4 but theres only one available now, so just wanna replace it first. Anyone can help with the ordering number??
Old Sep 25, 2009 | 06:26 AM
  #37
Huey52's Avatar
Registered Zoom Zoomer
A simple "coil order" search: https://www.rx8club.com/showthread.p...ght=coil+order
From front of vehicle to rear: Leading 1, trailing 1, leading 2, trailing 2 (#4 is T2)
Old Oct 13, 2009 | 02:32 PM
  #38
Bullitt's Avatar
In the pipe five by five.
That's one of the most perfect DIYs I've seen. Thanks!!
Old Oct 17, 2009 | 02:39 PM
  #39
dozer's Avatar
on his 3rd rx8
Old Oct 17, 2009 | 06:59 PM
  #40
Easy_E1's Avatar
Dozer,, Your my HERO!
Old Oct 17, 2009 | 09:42 PM
  #41
Jasonvaldez's Avatar
i did this worked great i took it on the road and was alright then i noticed it almost died at an idle and was idling a little lower then normal. i havnt driven it more then a mile after the change so maybe it needs to get used to it because the previous ones had 70,000 miles on them
Old Nov 10, 2009 | 02:19 PM
  #42
dozer's Avatar
on his 3rd rx8
im bumping for all teh n00bs
Old Nov 10, 2009 | 02:24 PM
  #43
sephyobsessed's Avatar
WTB Rotary Engine
So considerate of you dozer...too many repeat questions? lol
Old Nov 10, 2009 | 02:27 PM
  #44
dozer's Avatar
on his 3rd rx8
yes.
they should make my thread a sticky, alongside the spark plug DIY... its way to common, and the solution is way too easy
Old Nov 11, 2009 | 08:54 AM
  #45
WTB Rotary Engine
Indeed, I concur with your opinion on this matter, people should search **** before they go asking on a new thread...There are TONS of DIY threads up here ^_^ and this one is a good one!
Old Nov 17, 2009 | 03:09 PM
  #46
g0rdhan's Avatar
Im sorry guys, but forgive my lack of knowledge, what are the coils? and what do they do?
Old Nov 17, 2009 | 03:11 PM
  #47
dozer's Avatar
on his 3rd rx8
they send the spark to your spark plug
Old Nov 18, 2009 | 03:12 AM
  #48
g0rdhan's Avatar
how do you tell if they need to be replaced?? i just got my 8.. so im trying to learn as much as i cna
Old Nov 18, 2009 | 06:29 AM
  #49
Huey52's Avatar
Or to more properly elaborate, the coils are mini-transformers that increase the battery's 12V to a very high voltage that is then conveyed to the sparkplugs via the 'plug cables (that's why the cables have very thick conducters compared to the coil input side). The gap between the sparkplug's annode and cathode (base and tip) provides for an electrical arc which forms the spark that ignites the gasoline vapor.
But yeah, the coils basically send the spark to the 'plugs.
See enclosed for coil check:
File Type: pdf
Old Nov 18, 2009 | 10:03 AM
  #50
damn, Huey to the rescue.
I was just gonna put, "they're like a distributor" but your answer is way better.
