2010 Turbo Build: a.k.a. "Project JETS3T 8"
Old Nov 23, 2011 | 11:29 PM
  #376
FazdaRX_8's Avatar
so when will you post the dyno numbers?
was this on pump gas or e85??
Old Nov 23, 2011 | 11:47 PM
  #377
FazdaRX_8's Avatar
More dammit lol
Old Nov 23, 2011 | 11:48 PM
  #378
JETS3T8's Avatar
Here's the first video blowing off one of the charge pipes...
More videos coming...
http://youtu.be/94BS6GkVb7c?hd=1
To answer your question I won't be posting the numbers because there are no numbers (dyno charts) to post. Nelson was barely beginning his tuning and so he wasn't printing out/recording the pulls, just looking at the monitor.
I went into the dyno session knowing I had 2 "hurt" side seals, one on the front rotor and one on the rear rotor (my porting job possibly?), not enough to severely affect performance obviously but enough to cause serious blowby. There was SO much blowby that my catch can overfilled twice, it wasn't pretty and was too dangerous to keep going. Gonna relocate it and figure out a new venting system for now...
Old Nov 23, 2011 | 11:49 PM
  #379
Turblown's Avatar
Boostin'
Oh come on Richie post the rwhp numbers Nelson saw on the dyno!
Old Nov 23, 2011 | 11:53 PM
  #380
JETS3T8's Avatar
Here's the second video...
Fixed charge pipe...
http://youtu.be/IP4mT1XjGhk?hd=1
Old Nov 23, 2011 | 11:54 PM
  #381
FazdaRX_8's Avatar
Yes!!!!
ball park numbers?
so are you going to have to pull it again to do a rebuild?
Old Nov 24, 2011 | 12:15 AM
  #382
SayNoToPistons's Avatar
Wheels, not rims!!
Turblown facebook updates lookin' mighty entertaining.
Old Nov 24, 2011 | 12:17 AM
  #383
JETS3T8's Avatar
Here's the third video at 14psi...
Bypassed the boost controller, listen to that wastegate trying to keep up!
http://youtu.be/rclNkG3yRE0?hd=1
Old Nov 24, 2011 | 12:35 AM
  #384
JETS3T8's Avatar
Last video at 14psi...
http://youtu.be/gvpPiCdJsBc?hd=1
Old Nov 24, 2011 | 01:27 AM
  #385
xplod's Avatar
Nice pulls and sounds great!!
Are you going to keep running with the side seals ''hurt''?
Old Nov 24, 2011 | 09:12 AM
  #386
Turblown's Avatar
Boostin'
8 seconds to do a full 4th gear pull.. Shouldn't be too hard for people to figure out the power levels...
Old Nov 24, 2011 | 11:17 AM
  #387
firecran's Avatar
Renesis out... REW in
^this
Old Nov 24, 2011 | 11:19 AM
  #388
lastphaseofthis's Avatar
Release the twins.
wow. so this is the ECU You guys at Turblown were talking about... boost indexed timing tables?? :D.. i see a MAP sensor is required.... and the MAF can be ditched... will it use the stock TPS for Alphta-N tuning in addition to transient throttle response? is there a thread for this ecu yet? am i highjacking?
Great build, can't wait to see the 600 horse dyno.
Old Nov 24, 2011 | 04:49 PM
  #389
09Factor's Avatar
Original Turbo 'd Auto !!
Congrats on a job well done Richie!
Old Nov 26, 2011 | 09:09 AM
  #390
Its not just side seals, you also have massive blowby past the cutoff seal(s) as well. Reworking the catch basin isn't the answer as the engine will not be long for this world with that kind of blowby occuring.
Old Nov 27, 2011 | 11:39 PM
  #391
JETS3T8's Avatar
The intention of relocating the catch can is a precautionary measure to avoid a possible fire, not the "answer" to prevent blow-by, I should have been more specific.
Also, the excessive blow-by is not directly going to harm the motor, I'm not worried about it and don't need to be. It's the indirect dilution of the oil from the blow-by that I need to keep an eye on until the motor gets rebuilt which will be soon after the next dyno session...even then the blow-by will still be an issue with the amount of boost I'm running in addition to the high compression.
Old Nov 28, 2011 | 01:29 PM
  #392
\\Konig\\'s Avatar
turrrbo!
fantastic work so far! looking forward to hearing the results, your 8 is a beast!
Old Nov 28, 2011 | 02:35 PM
  #393
Chris's Avatar
Turbo Member
im just one of the kidz in the back going caaarrrrraaazzzyyyyyy
Hope to see some numbers soon!
Old Nov 28, 2011 | 03:47 PM
  #394
That's hot combustion gases under peak pressure going into the crank case, not cold air. Take care my friend ...
Old Nov 28, 2011 | 06:45 PM
  #395
ELI063's Avatar
Bat Mobile Driver
From: From Florida back to my home lands in MIchigan
more more videos plz
Old Nov 29, 2011 | 08:37 PM
  #396
Turblown's Avatar
Boostin'
Its going back on the dyno soon.
Waiting for the forum trolls to come say " well it won't last long at the power level, blah blah blah"
Old Nov 29, 2011 | 10:23 PM
  #397
ELI063's Avatar
Bat Mobile Driver
yea cant wait to see it and here the blah blah blah.... haha
Old Nov 29, 2011 | 10:25 PM
  #398
Brettus's Avatar
Boosted Kiwi
from the sound of it - it is already blown , so the trolls didn't even get a chance .
Old Nov 29, 2011 | 10:37 PM
  #399
JETS3T8's Avatar
Hahahahahahahaha! ROFL!
Old Nov 29, 2011 | 11:06 PM
  #400
ELI063's Avatar
Bat Mobile Driver
niiiice!!
