Greddy Turbo Kit F.A.Q's. post them here
Old May 21, 2009 | 12:11 AM
  #301
PhantomRX-8's Avatar
Bad Ass
Originally Posted by MazdaManiac
You can replace it all with AN-4/1/8" NPT stuff.
You will have to tap the threads in the "T" fitting and the top of the turbo.
Awesome! Thanks a lot man. Luckily Chickenwafer spoke up and said he had one that he'd sell me. But thats definitely good to know theres another option.
Old Jun 6, 2009 | 08:49 AM
  #302
m0nkeib0i888's Avatar
not sure if this questions been asked, but is there any reason why the greddy turbo kit is made for 04+ models only and not the 03?
Old Jun 6, 2009 | 10:36 AM
  #303
MazdaManiac's Avatar
There is no such thing as the 2003.
The 2003 is actually the 2004 model.
In some markets, they don't use the American dating convention for the car model year, so there is some confusion about vehicles sold in 2003.
Old Jun 6, 2009 | 10:59 AM
  #304
im in australia lol that explains it! thanx for the reply.
Old Jun 19, 2009 | 08:22 AM
  #305
RotaryMachineRx's Avatar
SPOOLN8
Do you think an STS turbo kit would have alot fewer of the problems the greddy turbo kit has.... reliability wise. Other than the obvious decreased running temperatures with the STS systems what other benefits/faults could you see by running a remote turbo like Squires?
Old Jun 19, 2009 | 02:58 PM
  #306
chickenwafer's Avatar
Nope
The only problem with the GReddy kit is an undersized snail- which is fine if you run the boost pressure the kit was designed for.
Be "problems" usually come from lack of tuning, which would be a problem with any kit. And STS doesn't have a kit for our car yet- although a guy on the boards here made his own remote setup
Old Jun 19, 2009 | 03:58 PM
  #307
SPOOLN8
Ya I know there isnt a kit for the Rx8 but at the shop that I go to here a guy bought an STS turbo and the accessories such as the intercooler, STS oil fill cap, etc; and had custom plumbing built by the shop owner for it. Although he was still waiting on his Access Port from MM to load up the maps so I havent seen it run yet... should be interesting though.
Old Sep 27, 2009 | 04:39 PM
  #308
KrumbZ's Avatar
1.3L of Fury
can u fit other turbine beside the T618Z on the greddy manifold???
Old Sep 27, 2009 | 04:41 PM
  #309
Kane's Avatar
Yes... look and BNR turbo upgrade and MM turbo upgrade.
Old Jan 27, 2010 | 04:01 PM
  #310
quillero20's Avatar
Ok here is a question, should you port the housings if your doing turbo on your 13b renesis ? What is the best way to get the turbo on your engine safetly.????
Old Jan 31, 2010 | 10:59 AM
  #311
monzue's Avatar
Persistance
Air intake filter
If anyone wants to know, I didn't know what size airinx filter to buy to replace the one I had, and so I bought the Airinx Filter in the medium size. When the Filter Came in, It looked too large, but I stuffed the filter in the housing and it was the correct size. Medium is what you need.
Airinx Type S - Small - 137mm base diameter
Airinx Type M - Large - 169mm base diameter
Old Jan 31, 2010 | 11:40 AM
  #312
Brettus's Avatar
Boosted Kiwi
Kane can answer your question on porting the housings - but if you have the engine apart you would be crazy not to fit stronger apex seals and fit some extra dowells
Old Jan 31, 2010 | 11:42 AM
  #313
Kane's Avatar
Yes, porting is good for FI.
Old Feb 7, 2010 | 09:06 AM
  #314
Frosty288's Avatar
n0 pants
What will need to be done to modify the Mazdaspeed intake for it to work comfortably with the turbo? Is there anything outside of what i'm expecting that I should know ahead of time?
I was figuring i'd just take the intake pipe to the turbo as far into the engine bay as I could and then either get some bends or use what I already have to connect part of the MS intake to the turbo, keeping enough straight run for the MAF sensor.
Old Feb 7, 2010 | 09:10 AM
  #315
Kane's Avatar
Pretty much - start with the MAF housing and run that from the greddy intake pipe by the alternator, then run the tubes out the bumper and go from there - I put mine above the crash bumper for water, but the factory set up puts it behind the intercooler and you may have to adjust it a little bit.
Old Feb 7, 2010 | 09:20 AM
  #316
Frosty288's Avatar
n0 pants
Alright sounds solid to me, I havn't seen that part documented much in the turbo build threads so when I do mine i'll be sure to detail it a little more for others.
Old Feb 7, 2010 | 09:25 AM
  #317
ZumnRx8's Avatar
RX8 & RX7 owner
Originally Posted by mazdamaniac
because the sfr turbo is big. The greddy is small. Search is your friend.
lol!!
Old Apr 8, 2010 | 02:41 PM
  #318
BlackStealth's Avatar
anyone else having a very difficult time tightening the bolts back on the turbo for the actuator and oil feed line? Any tips or recommended tools for easier access? If it weren't for this small issue, I'd be done a few days ago...
Old Apr 8, 2010 | 03:04 PM
  #319
Brettus's Avatar
Boosted Kiwi
See PM - but there is also a thread around here somewhere dedicated to installation issues like that . I'll see if I can find it for you .
here you go - some good info in that thread
https://www.rx8club.com/showthread.p...llation&page=2
Old Apr 8, 2010 | 03:05 PM
  #320
gregs's Avatar
Pull My Finger
i always tighten and mount the wastegate onto the turbo outside of the car, the oil feed line i tighten with the turbo not mounted to the manifold easy access from where the passenger side engine mount nomally is
Old Apr 8, 2010 | 03:24 PM
  #321
Ohh I tried that! I don't know how you managed to get the wastegate down to the headers after doing that though - it was extremely tight and wouldn't budge when I tried. The turbo basically had to be mounted for the wastegate to be fitted...(then again, I think my wastegate was upgraded to a 7 psi outlet??) As a result, I had to have the wastegate installed while mounted, then lift the turbo upwards while trying to secure the bolts for the oil return line... still proving to be difficult like a mother****** . I'm going to try Brettus' suggestion which is to remove the other engine mount to gain more access. Pray for me.
Old Apr 8, 2010 | 03:28 PM
  #322
gregs's Avatar
Pull My Finger
no need for removing the driver side engine mount, place the turbo with the wastegate in first..push it as far foward as possible, then install the exhaust manifold..super easy and plenty of space
Old Apr 8, 2010 | 03:42 PM
  #323
Brettus's Avatar
Boosted Kiwi
/\sounds good , never tried it that way .
Old Apr 10, 2010 | 01:46 PM
  #324
Well I did what you suggested and it worked!! thanks for the advice! Only one issue remains however - getting the 4 nuts tightened from the header to turbo. How did you manage that with the oil return pipe in the way?
Old Apr 10, 2010 | 03:12 PM
  #325
Brettus's Avatar
Boosted Kiwi
/\ oil return goes on last ......
