Vendor Classifieds For our approved Vendors to post their for sale threads
Adaptronic Select Rx-8 Standalone ECU
Old Aug 13, 2012 | 12:00 PM
  #201
ShellDude's Avatar
weeeeeeeeee
AP flashing while Adaptronic connected confirmed as operational.
Old Aug 14, 2012 | 08:01 PM
  #202
Kane's Avatar
Senior Member
Are we still doing the September thing? I never got a confirmation email.
Old Aug 17, 2012 | 07:13 AM
  #203
ssspeedfreak's Avatar
There's a September thing with Kane! All ears on this one!
Old Aug 17, 2012 | 07:16 AM
  #204
Kane's Avatar
Senior Member
Sorry, in TX.
We can do a NY thing maybe later on.
Old Aug 17, 2012 | 07:20 AM
  #205
ShellDude's Avatar
weeeeeeeeee
Kane, if you do a MD, PA, NJ, or NY thing, I'm definitely there! How's the online stuff coming?
Old Aug 17, 2012 | 07:21 AM
  #206
Kane's Avatar
Senior Member
It's coming. In the middle of moving, so things have been hectic lately.
Old Aug 17, 2012 | 05:17 PM
  #207
I second that! I don't know how many people would join in on a tuning section in the north east but it would be a great thing!
Old Aug 19, 2012 | 12:53 PM
  #208
ShellDude's Avatar
weeeeeeeeee
Another update:
So I (actually Dave did the bypass) bypassed SSV and VDI control by cutting the 1L and 1W leads going into the Adaptronic and factory ECU then wired them directly to the factory ECU using the factory harness and 2 lengths of wire.
See here: PCM INSPECTION for more details.
Also, in PA we have to pass all but one readiness test and both my EVAP and Secondary Air tests are failing. After some research I found that two leads in the 4th loom (4D and 4H) are the control signals for the EVAP pump. See here: DTC P2401 (it's google cache to the "secure" MNAO online DTC manual)
I then compared that to the Adaptronic RX-8 wiring diagram and noticed that both 4D and 4H are "NC" (not connected). After a brief email exchange with Andy he confirmed they are not connected and I'm in the process now of bridging the wires to see if I can get my EVAP test to pass.
Old Aug 19, 2012 | 01:42 PM
  #209
ShellDude's Avatar
weeeeeeeeee
So damn close... Secondary Air is now reporting a duration. Apparently the range is 1000ms to 4992ms and my damn pump ran for 5190ms throwing a pending a code.
Now I have to wait 6 hours for a full cooldown to run the stupid test again.
Prior to my wiring job the Secondary Air Monitoring PID wasn't reporting anything for duration so I'm definitely making progress.
Old Aug 20, 2012 | 06:03 PM
  #210
ShellDude's Avatar
weeeeeeeeee
got EVAP and Secondary Air to pass with my little wire job! Finally can go get her inspected.
Also, will be opening an "Adaptronic Select Owners Thread" shortly. I have quite a bit I can contribute at this point.
Old Aug 20, 2012 | 09:13 PM
  #211
09Factor's Avatar
Original Turbo 'd Auto !!
Old Aug 27, 2012 | 12:51 PM
  #212
Adam Busch's Avatar
I want to use alternative fuels such as LP or CNG in my 04 RX Renesis 6speed. I just bought the car and have not used flash mapping or chips before to accomidate the needs of the perticular gas.
I know the Turbine style properties of the wankel will support basically any type of fuel.
I have heard of people using diesel as well. Has anybody done this and tuned it properly.
Thoughts and feedback are welcome please
Old Aug 27, 2012 | 12:52 PM
  #213
What does that have to do with this thread? Start your own damn thread or read the many other threads that discuss alternative fuels.
Old Aug 27, 2012 | 08:22 PM
  #214
ShellDude's Avatar
weeeeeeeeee
Actually 9k, the Adaptronic has a tab sheet devoted to flex fuel. No idea how any of that would translate to our car but it certainly has those options assuming you're willing to wire in the necessary sensors, etc.
Hell, I don't even know what a "Flex Fuel Sensor" is
Attached Thumbnails Adaptronic Select Rx-8 Standalone ECU-screen-shot-2012-08-27-9.20.29-pm.png
Old Feb 27, 2013 | 02:25 PM
  #215
iconchrono's Avatar
Don't mind me...
Don't mean to necro an old thread, and I'm sorry I've only lurked for 3 years and never posted, but I believe I can contribute here, lol.
I'm quite certain the "flex fuel sensor" referred to here is actually a sensor you can purchase and place in your fuel tank or elsewhere along your fuel system which will detect the type/quality of gasoline (i.e. regular, premium, E85, etc.) and pass that information along to the ECU, allowing it to adjust parameters as neccesary.
Having not yet worked with the Adaptronic unit or software yet, I can't say for certain though.
Cheers!
RXFEVER
Sep 11, 2016 02:51 PM
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
RXFEVER
West RX-8 Forum
Sep 28, 2015 08:30 PM
Paul_Y
Sep 21, 2015 02:23 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
