West RX-8 Forum Serving CA, NV, AZ, HI
Las Vegas Lounge
Old Nov 18, 2009 | 03:41 AM
  #12226
fmmieres's Avatar
thank you guys.. the first thing that i need to fix i the fuel leaking.. i`m pretty sure that i just have to change the seal.. i`m going to autozone to try to find a seal.. i also have a problem with the coils.. i will make the upgrade,i need to replace the front brake rotors.. and than just some detail..
Old Nov 18, 2009 | 06:54 AM
  #12227
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
If your looking for the seal at the gas tank fuel pump, you have to go to the dealer. I ordered mine on line but the dealer has them. Do your self a favor and get an upgraded coil kit. I like BHR kits and he can help you out with front breaks also.
Old Nov 18, 2009 | 06:56 AM
  #12228
Phil's 8's Avatar
LAS VEGAS MEET SCHEDULE
FRIDAY NOVEMBER 27TH
Time: 730 PM
Place: IN & OUT BURGER
2900 West Sahara
EVERY ROTARY OWNER WELCOME
From out of town? Don't let that bother you, your welcome to our meet. Our members range in age from 16 thru 68 so don't let an age thing keep you away.
We are deviating from our normal third Friday due to issues for this month
Old Nov 18, 2009 | 04:07 PM
  #12229
Den18's Avatar
Having a problem with the brake light it wont turn off it just stays on...any sugg....guys
Old Nov 18, 2009 | 04:16 PM
  #12230
AJ's Shinka's Avatar
Enthusiast
All three lights or just one? Parking brake handle up just a little bit?
Old Nov 18, 2009 | 08:43 PM
  #12231
@!!narotordo's Avatar
FLAME ON!
fmmieres, well if you need a hand give me a call. I can swing by over the weekend.
Den, hows your brake fluid looking? low or over filled?
Old Nov 19, 2009 | 03:16 AM
  #12232
FLAME ON!
Runs like a champ AJ, you got nothing to worry about
Old Nov 19, 2009 | 03:35 AM
  #12233
Enthusiast
Thanks bro, Liza was in panic mode she was like call AAA. I was like hold on let me call Gil, he has photographic memory he can walk me through it. lol Thanks for coming out. I owe you another solid!
Old Nov 19, 2009 | 07:26 AM
  #12234
Phil's 8's Avatar
I'll be home this weekend so the garage and tools are available. Just give me a call.
Old Nov 19, 2009 | 12:30 PM
  #12235
chunbelievable's Avatar
Tetsumakysenpukyaku
Phil I just spoke to Ray at length about my car. There are few things I need to look at. First there shouldn't be an issue from using an 04 clutch on my 08 transmission.
Second, Ray wants me to remove my starter and look into the pressure plate to see if any of the bolts have backed off.
If those don't solve my problem then as a good measure he suggests that I get my clutch pedal welded up and adjusted to spec.
On the surface it would seem that my synchros and clutch are fine and that my issue may be something simple like the pressure plate or pedal. If those items don't work I'll have to take the tranny off and dig around inside for anything else that would cause the problem but Ray can't really think of what else it might be with the symptoms I have.
He suggests I take the pedal to you for welding. Is that cool with you?
Old Nov 19, 2009 | 03:02 PM
  #12236
Phil's 8's Avatar
Get the dam pedal off before it breaks or cracks then I can't help you. Get it to me and I should be able to get a quick turn around (we have done this to at least 50 pedals and never had a complaint or return). I have offered everyone locally this service and no one has yet done it. I taked with Ray and he filled me in on your talk with him. It never sounded like synchros or actual clutch. The pedal fix will make a big difference in the feel. I will be home this weekend so call me.
Old Nov 19, 2009 | 03:53 PM
  #12237
Tetsumakysenpukyaku
PM me your number, I don't have it. If I can get it off I will get you the pedal this weekend.
Old Nov 19, 2009 | 05:41 PM
  #12238
FLAME ON!
Talking
Anytime man. Check this out
Dam FC's ^_^
I need to install my front sway bar and endlinks. You got PB Blaster? or AJ you got some?
Who did your work? lol take it back to who ever did. Sounds like the person did 1/2 *** work.
Old Nov 19, 2009 | 05:58 PM
  #12239
Tetsumakysenpukyaku
^^ Courtesy did it.
My choices are pay to have it towed there and pay the diagnostic fee if they won't assume responsibility, which they probably won't and they'll blame it on my used transmission. Or I can try to figure it out myself and make the simple adjustment if I can. If I absolutely can't get it down myself I will bring it to Courtesy expecting the fight.
Old Nov 19, 2009 | 06:04 PM
  #12240
FLAME ON!
Damn. I would have them tell me whats wrong with it. Then have the work done by some that dont charge $95/hr!!! lol
Old Nov 19, 2009 | 06:11 PM
  #12241
Tetsumakysenpukyaku
$100 diagnostic and they might try to tell me it's the used transmission I bought instead of blaming it on their work. We have really ruled out the tranny but Courtesy has been SUPER shady since I have dealt with them. If I can I wanna figure this out myself.
If the pressure plate is the problem and we just have to tighten the bolts then great. If we figure out it is a shitty clutch that Courtesy gave me then fine, at least I know and we can bring it to them knowing they can't blame my transmission and try to sell me a new one.
Old Nov 19, 2009 | 07:03 PM
  #12242
Phil's 8's Avatar
$90.00 per hour is the new low end in the flat rate book for auto repairs. Finding someone with a shop and insurance that will work for that is going to be difficult. I believe that the current hourly rate at Courtesy is $125.00. Even that would not be bad if they knew what they were doing. I know Mike's friend works there but he is most likly the only one there that does good work.
I'm sure you can find some one to work for less but be careful as he will not have a business license or insurance.
Old Nov 19, 2009 | 08:32 PM
  #12243
Tetsumakysenpukyaku
I won't be going with a shop right away. I am going to try to fix this with friedns if we can finally figure out what the problem is. If we can't then I am going to try Chris at Area 77.
Old Nov 19, 2009 | 10:46 PM
  #12244
Enthusiast
Dam FC's ^_^
Dude that was Liza last night! Hahaha! Bring the car over and we'll PB blast the **** out of her.
Old Nov 19, 2009 | 11:40 PM
  #12245
flip's Avatar
LOVE / HATE Relationship
Vultures! Back off I want Jason's parts. Let the Hyena step in. I'm gonna make my 8 CF/CR Carbon Fiber/Copper Red. Panda 8.
Me thinks the next carbon fiber ***** should naturally go to the one w/ a Brilliant Black... so if Phil isn't intrested... that would leave.... ME!
I won't make the meet Phil... I'll be Black Friday'd out in Cali...
Old Nov 20, 2009 | 12:00 AM
  #12246
Enthusiast
That's fine, I don't want his CF. Gil where is that $65.00 spark plug sale?
Old Nov 20, 2009 | 06:55 AM
  #12247
Phil's 8's Avatar
Too bad you will not make the meet. I hear that since Cali is in such bad shape that they are holding visitors for ransom......
Old Nov 20, 2009 | 07:53 AM
  #12248
Phil's 8's Avatar
Time: 730 PM
2900 West Sahara
Old Nov 20, 2009 | 07:47 PM
  #12249
FLAME ON!
Cool
Founds it!
http://www.ecrater.com/product.php?pid=4127739
Old Nov 20, 2009 | 08:35 PM
  #12250
Enthusiast
are you sure about this? i bought some oakleys off ecrater and got a pair of foakleys
