Dynoed today before the engine gets yanked
Old Sep 19, 2006 | 11:27 PM
Tirminyl's Avatar
Listen to Zoom44
05 RX8: 28,22x miles. Shell 91, RP, Green Filter, Disconnected VFAD, Mod Airbox
Dynojet: 75.39dgF, 29.36 in-Hg, Humidity 27%, STD 1.03
Video- http://media.putfile.com/Rx8-Dyno
Will attempt to scan the graph at work tomorrow. Here were the numbers-
Old Sep 19, 2006 | 11:38 PM
Are they replacing your motor??
Old Sep 20, 2006 | 12:33 AM
Need to see the graph.
Old Sep 20, 2006 | 12:42 AM
glad to see someone else doing this... i plan to do a before and after dyno...
Old Sep 20, 2006 | 12:43 AM
Ja, but 180 HP with a vaccum leak?
Old Sep 20, 2006 | 12:48 AM
pretty sure that if he has modded the air box. he knew to plug the hole for the vdaf hose.
Interesting...................
Might explain what is going on with mine??
Old Sep 20, 2006 | 12:54 AM
or you could explain the vaccum leak he has???
Old Sep 20, 2006 | 08:37 AM
olddragger's Avatar
those are not bad numbers in itself.
olddragger
Old Sep 20, 2006 | 12:27 PM
Tirminyl's Avatar
Listen to Zoom44
Here is a crappy view of the graph. Again I will try to get a scanned version if I can.
My engine failed during the recall test drive. The engine had 14,7xx miles when I got it so I do not know how the previous owner drove it. She feels strong and good except for idle issues. She felt really good after leaving the dyno, silky smooth. I also have an oil sample that I will be sending in to have analysed.
I just wanted to see where everything was at before they replaced it.
Old Sep 20, 2006 | 12:31 PM
dmp's Avatar
dmp
RX8 and a Truk....
that's an ugly graph, brother. :-/
Dyno again after to see if it gets smoothed out
Keef's Avatar
the shit starter
Is capping off the vfad hose really necesarry? I keep reading about that, but I haven't capped it off...
Old Sep 20, 2006 | 12:51 PM
Tirminyl's Avatar
Listen to Zoom44
I will dyno with the new engine in April, so I should have 13-14k miles on it.
Old Sep 20, 2006 | 05:08 PM
olddragger's Avatar
yes you need to cap it off
OD
Old Sep 20, 2006 | 05:12 PM
what will hapen if you dont .
Cuz I have K&N Typhoon Version 2, they didnt say anything about that tube. I feel it when engine is on, it still sucking air into it ... I always wonder should I unplug the wires and close the tube.
Old Sep 20, 2006 | 05:31 PM
Keef's Avatar
the shit starter
just capped... though I don't understand what it changes, nor feel a difference....
Old Sep 20, 2006 | 05:56 PM
Tirminyl's Avatar
Listen to Zoom44
Added a vid to the first post.
Old Sep 21, 2006 | 07:35 AM
Well, I left it like that for *quite* a while (since I have the intake actually)
Car seems ok ... no CEL, No stored codes.
so I guess Im fine
vapor2
Nov 3, 2020 03:38 PM
UHATEIT
Mar 31, 2019 05:31 PM
ion_four
Jul 30, 2015 09:48 PM
dbarber
Jul 25, 2015 01:34 PM
RX7.9
Jul 20, 2015 12:01 PM
