6 ports or 4 ports
Old Sep 3, 2006 | 10:37 PM
ae82ted's Avatar
Post 6 ports or 4 ports
Hi All,
I'm new here, and have just bought a RX-8 and i'm living in HK
I have a very wrried question. My car is an 03 6 spds manual RX-8, As i know there are two types of Engine. the 250ps 6 ports and 210ps 4 ports mainly for Automatic transmittion.
However, i also read some posts on the internet saying that the 4 ports engine would comes along with the 6 speeds manual.. is that true?
If yes, how to distinguish which one is 6 ports engine which one is 4 ports?
Also i'm going to change the spark plugs on my car, its bone stock, what is the suggestion on the degree of them. Some people said 9degree for the upper 2 and 7 degree for the lower, what are u guys idea?
Thanks for your help.
Old Sep 4, 2006 | 12:13 AM
Silver_Surfer's Avatar
I4NI
First let me say hi! Welcome!
Second: Degree your sparkplugs? Might you mean "Index"?
Nevermind, degree= heat
Old Sep 4, 2006 | 12:21 AM
KJ238's Avatar
Air + Fuel + Spark = Boom
Hello... if you are 6 speed, it shoud be 6 port...
Plugs, stock shud be fine...
Old Sep 4, 2006 | 01:32 AM
N rider89's Avatar
^NieL
yeah 6 speeds have 6 ports
Old Sep 4, 2006 | 01:49 AM
Easiest way to tell if you're 6 port or 4 port is by looking at your tachometer.
9 K Redline. You have a 6 port.
anything else. you have a 4 port.
The differents is that, the last *2 port* found in the 6 port engine will ONLY OPEN above around 7250 rpm ~~~
So that MEANs, if you use your engine below that rpm, theres no differents between the 2 engine.
you live in HK? really, you can pm me, I can read chinese
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Evan Gray
Nov 24, 2015 01:00 AM
bosstin87
Oct 5, 2015 06:52 AM
Stubbs
Sep 27, 2015 04:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
