Looking for a cooler running RX-8?
Old Aug 21, 2006 | 08:04 PM
MazsportScott's Avatar
Mazsport.net
Looking for a cooler Running RX-8? After extensive testing Mazsport is proud to release our "Cooling Fan Control Kit." We believe this is the single most effective modification you can make to lower the operating temperature of your RX-8.
This plug and play kit is designed to be installed by the novice mechanic with basic hand tools in less than 30 minutes. By altering the temperatures at which the factory cooling fans are turned on and off significant reductions in engine temperature have been made. For example, during testing of turbo charged RX-8’s, normal operating temperatures between 210-220 degrees were decreased by 20-30 degrees with no other modifications! Non turbo models using the kit have reported 10-15 degree reductions in operating temperature as well. This product will benefit all RX-8’s!
Although the main objective of this product is to lower engine operating temperatures customers are also reporting other effects.
· Colder air conditioning (lowering condenser temperatures using added airflow will increase air conditioning efficiency)
· Smoother Idle (Engine operating temperature and compression are directly related in the Rotary Engine. The cooler the engine operating temperatures the higher the engine compression. In some cases this may help improve idle quality and hot starting)
· Better low RPM engine response and power (Increased compression and reduced under hood temperatures/heat soak)
These kits are in stock and ready to ship. Order online at http://www.mazsport.net/index.html or call 1-800-538-9989 .
Old Aug 21, 2006 | 08:18 PM
Mortal Moxie's Avatar
Taylor not Tyler
Old Aug 21, 2006 | 08:25 PM
jdzoom8's Avatar
Here is the link on the mazsport.net site: http://mazsport.net/store//page9.html.
Cost is $150.
Things that make you go hmmmmm.
Old Aug 21, 2006 | 08:26 PM
3MTA3's Avatar
Where's My Car?
Originally Posted by Mortal Moxie
Follow the provided link if you're looking for a price!
Old Aug 21, 2006 | 08:37 PM
Taylor not Tyler
When the price isnt stated right off the bat, the product costs too much money.
Early sales rule.
I thought my reply implied that... Guess I was too... vague?
Old Aug 21, 2006 | 08:42 PM
and the product works...
running na in fla..... i am running 10 to 15deg cooler than before.....
i have to beat it up to get it up in to the 190deg range..... and yes this is with outside temps of 94 deg...
pm me if you need more info..
Old Aug 21, 2006 | 09:12 PM
High Revving's Avatar
what kinda results have you had with a aftermarket radiator and hoses
Old Aug 21, 2006 | 09:15 PM
BoosTED's Avatar
I've noticed my n/a 8 cooling fans seem to only come on for about 5 seconds after I turn the car off. Does this kit keep them on even after the car is off?
Old Aug 21, 2006 | 09:23 PM
Mazsport.net
Slightly better when used with an aftermarket radiator. The reality is the cooling fan control kit with the stock radiator reduces the temps more than the aftermarket radiator alone!
Old Aug 21, 2006 | 09:24 PM
no,
they still run, but not for as long.... it is warmer down here.....
Old Aug 21, 2006 | 10:17 PM
rkostolni's Avatar
My Rx8 was one of the "testing" vehicles. I've had this product installed for about a week now. Here's a summary of my before and after temps with a 90deg ambient.
Idling/traffic: Before 200-210 After 170
Hard acceleration 1st-3rd gear: Before 210 After 185-190
High speed Cruising: 170 Before and After
I have an aftermarket radiator, I've tried water wetter and tried running a 60/40 water coolant mix in the summer. This mod made far more difference then any of my previous mods.
Rotaries definitely run much stronger when cool. I noticed a significant increase in power when taking off after sitting at a light after installing this mod. Besides the increased power, this mod is great for reliability. As we've all seen, heat and rotaries don't agree very well.
IMO any mod you can do to lower temps in a rotary, whether oil, coolant or air, is worth doing.
Old Aug 21, 2006 | 10:48 PM
BaronVonBigmeat's Avatar
Senor Carnegrande
This is pretty interesting, I wonder why it's set to run so hot by the factory?
Scott, if you really want to develop something awesome, how about something that makes the A/C compressor stay engaged, for those of us who have the infamous cycling issue. Hell, you can actually hear the compressor kick on/off if you listen closely enough at moderate speeds, and then feel the burst of cool air shortly afterwards. There was that recall for the electronic do-dad that controls the a/c clutch, but it didn't do much of anything. You take your car in, they go through the steps to fix it, and nothing changes. I can't help but wonder if this isn't a deliberate move by Mazda, keeping a compressor clutch engaged shouldn't be rocket science I don't imagine.
Old Aug 21, 2006 | 11:01 PM
check pm
Old Aug 21, 2006 | 11:07 PM
rkostolni's Avatar
Emissions reasons.
Old Aug 21, 2006 | 11:10 PM
Trekk's Avatar
Goat rider
I was thinking "Wow cool, sign me up!" Then I had seen the price.
Maybe in future......
Old Aug 22, 2006 | 12:51 AM
N rider89's Avatar
^NieL
its only $150, sounds really resonable to me
Old Aug 22, 2006 | 01:11 AM
Brettus's Avatar
Boosted Kiwi
Is this mod only necessary in hotter climates ?
Never gets much over 30 deg C here & most days are below 25 deg C .
Also : i've never seen my temp guauge deviate from just left of centre - what happens with you guys in hot climates ?
Old Aug 22, 2006 | 01:18 AM
RazzyBRX-8's Avatar
Representin'!
More power? for 150 dollars?
I agree with the "things that really make you go hmmmmmmm." statement.
Sounds like a very productive modification! Maybe after college finishes.
...definately after college finishes!
Old Aug 22, 2006 | 01:19 AM
the temp gauge on your dash is almost a hot or not hot gauge...
right now in the cool of the night it is 23c... you need a scan tool to read the temps.... mine used to go from ~180 to 205 on a na car...
now i have to beat the crap out of it to get it to 190...
see hymee for the scan tool....
Old Aug 22, 2006 | 01:21 AM
Brettus's Avatar
Boosted Kiwi
already have scan tool on way
Old Aug 22, 2006 | 02:28 AM
KJ238's Avatar
Air + Fuel + Spark = Boom
i want this
Old Aug 22, 2006 | 03:12 AM
Brettus's Avatar
Boosted Kiwi
notice this mod is in the RB flash upgrade also (although they do it with the ECU) - very interesting !
Old Aug 22, 2006 | 08:55 AM
silverwolf's Avatar
they say increased power. and i mean no disrespect but can anyone validate this? more torque perhaps? 1-2 hp if it really helps compression that much? can we get a dyno here?
Old Aug 22, 2006 | 10:18 AM
Mantis's Avatar
I have this mod and it really makes a difference during the summer heat in Florida. My 8 doesnt feel it is struggling anymore after a long day out running errands or autocross. The fan doesnt stay on as long either....
a must have in Florida for sure!
Old Aug 22, 2006 | 10:31 AM
mike1324a's Avatar
Need'd a Turbo
Theres no real point in a dyno because the gain will probably negligable. This is a support mod not a power mod.
