DS Drive Shaft Boot Leaking
Old Aug 6, 2006 | 02:55 PM
legokcen's Avatar
The Turkish Delight
While changing brakes today, I discovered some grease around the inside Driver's Side drive shaft boot. It is the boot connecting the D/S shaft to the rear diff. Upon inspection, I found a 1/2" tear in the boot which must be flinging the grease out. No sure how long this has been going on. The car has 43.5K miles on it.
What are my options? Will the warrantee cover it? Can I change the boot or does the whole shaft have to change?
Thanks in advance...
Old Aug 7, 2006 | 02:07 PM
Go48's Avatar
Mazda should cover the repair if the damage is due to boot failure and not due to foreign object impact. If your dealer is customer friendly, they will likely do the work under warranty. Of couse, if they won't cover it under warranty, and you are mechanically inclined, get a copy of the workshop manual and go for it.
Old Aug 7, 2006 | 04:59 PM
Im_DANomite's Avatar
I love GOOOLD
its called a CV boot. they have CV boot repair kits available. no need to replace the entire axle shaft. it should be could covered under warranty.
Old Aug 7, 2006 | 05:14 PM
Take it in...the boot is easily and inexpensively changed. The whole shaft will only need to be replaced if you drive it like that for a long time and it gets dirty and contaminated.....
HMSS013
Aug 28, 2015 03:08 PM
Eastcoastmod
12
Aug 27, 2015 06:29 PM
MolsonB
Aug 18, 2015 08:42 PM
marc2820
Jul 26, 2015 10:47 PM
