Wierd Full Sweep of Gauge Needles?
Old Jul 14, 2006 | 11:44 AM
tgeoffreyh's Avatar
Did a search and found a few threads that somewhat address the issue I'm having but no real definative info, mostly speculative. Maybe someone has since figured this out....
Got home from vacation (my 8 sat about 10 days without driving) and drove it to the gas station, started up and ran fine. After filling up, it wouldn't start, like it had a dead battery. I noticed when I first turned the key to the position where the gauges light up all gauge needles did a quick full sweep (I think it was all gauges, it happened quite fast). Had my wife drive over and give me a jump, thinking my battery was weak from sitting so long (although why did it start initially?). Started up with the jump and ran fine with no problems.
A few weeks later, the same thing happened (no start - full gauge sweep) and every time I turned the key off and back on, it did the full gauge sweep, but this time I waited a few minutes and tried starting it again and it started with no gauge sweep. It's been running fine ever since.
I would normally suspect a weak battery but, from past experience, I know once my battery gets "low" enough to not start my car, waiting a minute or two won't magically charge it back up. Am I incorrect? Anyone else experience this?
Old Jul 14, 2006 | 03:08 PM
Aseras's Avatar
the stock batteries are crap. take it to a dealer or a auto parts store and have them check the cranking amps... if it's below about 250 have it replaced under warranty. There's a TSB for it. Don't let the dealer charge you a pro rated amount.
Old Jul 14, 2006 | 04:31 PM
MadDashRX8's Avatar
Resu Deretsiger
Doesn't sound like a battery issue to me, but I'm no expert. Full sweep of the needle was a sign that you had cleared one of the two forms of memory retained within the pcm. You can recreate it by turning the key to the on position and quickly tapping your brake pedal 20+ times within 8 seconds. But, maybe it's due to a low battery . Hmmm. Wish I had an answer for you.
Old Jul 15, 2006 | 10:28 AM
zoom44's Avatar
plano
where are you located? maybe one of the other forum members can check it out with a canscan or scanalyser
Old Jul 17, 2006 | 10:33 AM
tgeoffreyh's Avatar
Originally Posted by abbid
Im going to agree with low battery. This has happenned to me on about 3 occasions when i let my 8 sit without starting it.
Thanks, hoping that's all it is. Getting the battery checked will probably be the easiest thing to do and a good place to start.
Old Jul 17, 2006 | 10:37 AM
tgeoffreyh's Avatar
Originally Posted by zoom44
plano
Near Indianapolis, anyone close by willing to help would be greatly appreciated!
cliffkemp
Dec 24, 2024 10:48 AM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
