My first DYNO session. Bone stock charts included.
Old Jun 20, 2006 | 06:00 PM
Crazy Rx-8 Driver's Avatar
XYELLR8
here are the details.
70degrees out with 3 fans blowing.
it was on a Dyno Dynamic. so have the sheets for with 'load' and 'unloaded' Dyno-Jet Converted.
My car is bone stock with a dirty filter and about 2K on the oil.
my first two runs they were unable to get A/F but they got it on the third run.
they pulled in 4th gear.
with load i was at 167.3HP without load on the jet converted was at 186.6 HP
Now that i have a base number to work with, i will continue to dyno with each mod i will add to the Rx-8. my goal is to break the 200HPmark N/A first
Attached Thumbnails My first DYNO session.  Bone stock charts included.-pics-camera-002.jpg   My first DYNO session.  Bone stock charts included.-pics-camera-014.jpg   My first DYNO session.  Bone stock charts included.-pics-camera-016.jpg
Old Jun 20, 2006 | 06:06 PM
Old Rotor's Avatar
Excellent Dude!! Cant wait to see what you do next...whats it gonna be???
Old Jun 20, 2006 | 11:11 PM
RedLineShinka's Avatar
Why 4th gear? I always thought that since 5th was the 1:1 ratio you were supposed to shift through the first 4 gears, then floor it in 5th and run it to red...
Did I mis-understand somewhere, or is there an alternate way to do it?
Old Jun 20, 2006 | 11:34 PM
Speedfreaksteve's Avatar
They really should've dyno'd it in 3rd. You very likely would've got a better number since thats more in the optimal powerband for the car.
You'd be surprised the difference you can get.. I've dyno'd a bunch of cars in 3rd or 4th with similar gearing to the RX-8.
Old Jun 21, 2006 | 07:14 AM
Brice-RX8's Avatar
You are right, optimal is the 1:1 5th gear, but most have said that the car is generating too much heat and it takes too long for 5th to wind out, so 4th is a good compromise.
Old Jun 22, 2006 | 01:12 AM
XYELLR8
i was the 5th Rx-8 to be Dyno'd at this place and they said the same thing.
Old Jun 22, 2006 | 04:11 AM
Beodude123's Avatar
I don't see why it would matter. The computer has to adjust for gearing anyways, so what does it matter?
Even though 5th is 1:1, there is still the 4.4 final drive, so I don't see any difference.
Old Jun 22, 2006 | 12:32 PM
zoom44's Avatar
using the 1:1 gear is the optimal situation. but im coming around to the idea of usingf 4th as well. 5th takes to long to run thru and things get dicey at 150mph on the dyno.
Old Jun 22, 2006 | 01:00 PM
416to212's Avatar
Utopia Taco Bell
"it was on a Dyno Dynamic. so have the sheets for with 'load' and 'unloaded' Dyno-Jet Converted."
What is the difference between "loaded" and "unloaded"?
Old Jun 22, 2006 | 02:01 PM
limepro's Avatar
ok is there a govenor on the 8 i read in the book that came with the 04's that its set at 147 but i have not gone quite that high and u whom i trust say 150(not saying thats what its limited at but saying above 150 the dyno gets dicey) assumin he is running stock and i remember someone else saying there isnt so does anyone know if there is a mph limiter?
Old Jun 22, 2006 | 02:31 PM
zoom44's Avatar
there is no speed governor on the US 6mt
Old Jun 22, 2006 | 02:34 PM
r0tor's Avatar
depending on the dyno used, it will bring the car through the rpm band at the same rate no matter what gear you use
Old Jun 22, 2006 | 02:36 PM
dtorre's Avatar
Ultimate ****** Goderator
break the 200 N/A mark first? Didn't someone allready do that with a bone stock 8 =P ....believe there was a dyno day in which someone managed to break 200 HP while everyone else was like 160-180
Old Jun 22, 2006 | 06:28 PM
XYELLR8
Loaded is to the True wheels to the ground, added resistance as you will, so HP to the wheels when you're driving.
and Unloaded is like to the wheels with no resistance, HP to the wheels when you're not driving.
sort of like a Mustang Dyno vs a Dyno Jet. Dyno Jets will always yield greater HP while a mustang Dyno and Dynamics yield lesser numbers.
oh yea! forgot to mention that the place I went to was a multi-purpose Dyno too. AWD, RWD, FWD accomodated. I was Flabbergasted when i saw an STI pull up and did a 196whp! i was but sure enough Jet converted it was around 235whp
the place is called DB performance in Rogers, MN its brand new too.
Old Jun 22, 2006 | 07:13 PM
lurch519's Avatar
www.evoperform.com
im not sure i understand. i could have sworn that to get hp figures, you had to put a load on the car, as horsepower is a measurement of work done over time. without a load, there is no way to determine the amout of work done.
Old Jun 22, 2006 | 07:34 PM
Ike's Avatar
Ike
Blue By You
There is a load, it's just not much like what you'd experience while driving.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
duworm
Oct 1, 2015 04:57 PM
