Throttle Body
Old Jun 9, 2006 | 10:09 PM
RjuXice8D's Avatar
Throttle Body
Does anyone make an aftermarket larger throttle body for the 8?
Old Jun 9, 2006 | 10:10 PM
zoom44's Avatar
no
Old Jun 9, 2006 | 10:14 PM
rotarygod's Avatar
You don't need a larger one. It is already 75mm which is larger than many V8 throttlebodies. It already flows more than the engine does. It is also electric as the car is drive by wire so even if you could get a larger one installed, the ecu would have to be completely recalibrated. Larger throttlebodies are useful on some cars but not all. This is definitely one car where it isn't going to do anything for you.
Old Jun 10, 2006 | 12:33 AM
RjuXice8D's Avatar
alright.....thanks
Old Jun 10, 2006 | 04:49 AM
to do what???
sorry to easy!!!!
Old Jun 10, 2006 | 03:14 PM
gh0st's Avatar
dont the star pro formula cars have dry sump renesis with larger throttle bodies?
Old Jun 10, 2006 | 06:57 PM
zoom44's Avatar
no they use the full factory intake including throttle body- there s a pdf around here somewhere.....
Old Jun 12, 2006 | 01:47 PM
swift21's Avatar
i have a pic you will all love, but i cant post it who can i email it to?
Old Jun 12, 2006 | 01:50 PM
check pm
Old Jun 12, 2006 | 02:30 PM
Spin9k's Avatar
Momentum Keeps Me Going
Video wo/comment
http://www.spin9k.com/assets/multime...azda_motor.wmv
Old Jun 12, 2006 | 02:37 PM
rotarygod's Avatar
They have to use a new throttlebody. It's cable opertated as opposed to drive by wire. They are the same size though.
Old Jun 12, 2006 | 03:23 PM
Beodude123's Avatar
Is there any optimization to be done to it? I know there are a lot of things that you can usually do to throttle bodies to make them a little better- ie. getting rid of speed bumps, and filing down the center bar...
Is there anything on the RX that can be optimized? I know that they did an excellent job or wringing out every hp they could.
Old Jun 14, 2006 | 12:21 PM
swift21's Avatar
swoope i sent you the pic
Old Jun 14, 2006 | 04:16 PM
dgrx8's Avatar
FN GR8
i believe spacers have been discussed here before but they were considered useless by rotarygod himself... there are some of those available though... a google search will turn some up made specifically for the rx-8.
Old Jun 14, 2006 | 10:27 PM
is this a pic of an hks system????
i will resize and post if it is you...
Old Jun 14, 2006 | 11:01 PM
here you go...
i guess this you... i dont get a lot of photos of turbo systems in my email...
nice colors, but ems???????
Old Jun 15, 2006 | 08:50 AM
evilmiata's Avatar
^^^OK, Swift. Give up some info. I see two BOVs, a polished/chromed metal upper intake manifold, and a relocated coolant overflow. Where is this car and where are the parts?
Old Jun 15, 2006 | 10:04 AM
rotarygod's Avatar
There's only 1 blow off valve. It's before the throttlebody. The one by the turbo is the wastegate and the purple thing back on the firewall looks like a fuel pressure regulator.
Old Jun 15, 2006 | 12:55 PM
swift21's Avatar
there is two blow off valves the purple thing in the back is an HKS oil cap. & it's stand alone fuel management......what do you guys think?
Old Jun 15, 2006 | 01:10 PM
MadDog's Avatar
Consiglieri
Yep. Definitely 2 BOV's - both are HKS SSQVs. There is also an external wastegate. It def. pretty.
Old Jun 15, 2006 | 01:24 PM
rotarygod's Avatar
You guys are right. I didn't see the blow off valve in the front at all.
Old Aug 22, 2006 | 03:47 PM
evilmiata's Avatar
Thread from the dead: Why would one need 2 BOVs?
Old Aug 23, 2006 | 08:08 AM
silverwolf's Avatar
first off has there ever been a plenum to try for the 8 (aftermarket)
second there are definatly 2 BOVs on that setup. would the owner of the pic please stand up and shed a little light?
Old Aug 24, 2006 | 11:19 AM
KJ238's Avatar
Air + Fuel + Spark = Boom
Ummm.. THat's a T04Z... Amazingly large turbo.. wonder whats the power like? and more importantly the lag like?
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
D13
Oct 1, 2015 07:55 AM
Jb4ker96
Sep 27, 2015 10:06 PM
