Am I okay? (Tranny Oil)
Old Apr 25, 2006 | 11:44 PM
x-ped's Avatar
So I replaced my transmission oil today with royal purple oil. I bought 2qts and filled the tranny but it didn't dribble or overflow. The capacity states 1.8qts so I should be okay right? Or should I go buy another qt and fill till it dribbles?
Old Apr 25, 2006 | 11:58 PM
maybe stick your little finger in the fill hole and see if you can get any on you...
that is an odd issue..
Old Apr 26, 2006 | 12:43 AM
Winning 8's Avatar
Hot Pit
fill til it drip is better, and do it every 30K to keep it in good shape
Old Apr 26, 2006 | 12:49 AM
yiksing's Avatar
the giant tastetickles
Is your car level?
Old Apr 26, 2006 | 12:52 AM
x-ped's Avatar
Winning 8, I assume you mean every 3k? My back end was slightly higher than my front when filling the oil. I drove it afterwards and seemed fine as the shifting was alot smoother. Maybe I'll go get another qt of rp and fill it till it drips.
Old Apr 26, 2006 | 12:54 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Had the same issue. Tranny took 2.1 qts. Capacity is stated as an approximation according to the manual.
The car was dead level. Checked it with a level on the side body rails.
Old Apr 26, 2006 | 12:58 AM
no,
every 30k is correct, and if it was not level, that is it...
Old Apr 26, 2006 | 01:20 AM
Winning 8's Avatar
Hot Pit
engin oil is 3k, tranny, diff and coolant is 30k
Old Apr 26, 2006 | 02:55 AM
yiksing's Avatar
If I'm rich enough, I would do all fluid change every 3000 miles but I'm not.
Old Apr 27, 2006 | 12:36 PM
x-ped's Avatar
Thanks for all your help guys. This morning I filled the tranny up untill it started to drip. Surpisingly I needed a extra .2 qts. I guess when I was draining the oil the back was higher I may have drained some extra oil. Hopfully I didn't harm the tranny when I took it for a spin with the .2 qts short. Anyways the royal purple is alot smoother than the redline oil that was in before, and I can chirp the tires now with my heavy 19's which I couldn't do before.
Old Apr 27, 2006 | 01:03 PM
Royal Purple is awesome stuff! I did the tranny and differential about a month or two after I got my car...I'll never use anything else.
Glad you got that .2 quarts in there. I doubt it had any negative effects on the tranny though.
OUCH... that picture is making my headache even worse. Cool fish eye lens though.
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
GARCIAC951
Sep 10, 2015 07:17 PM
