Ramps
Old Apr 15, 2006 | 05:20 PM
MeToo's Avatar
Ramps
Can anyone suggest low clearance ramps that aren't going to cost me an arm and a leg... My husband saw these at walmart and said they weren't tall enough... but they are taller than the ones I am finding online. He has a lowered Magnum which has lower clearance than my 8. Thanks!
Old Apr 15, 2006 | 05:43 PM
Spin9k's Avatar
Momentum Keeps Me Going
I have these, they are ok, but the car tends to push them forward as you try to mount them. They don't get the car very high off the ground either, and since the wheels are not off the ground...just on the ramps... I have to wonder what I was thinking when I got them Oh well !
Old Apr 15, 2006 | 05:47 PM
Goodwin Racing has some great ramps.....kinda pricy though
Old Apr 15, 2006 | 05:52 PM
expo1's Avatar
He's as bad as Can
http://www.mustangworld.com/ourpics/...amps/index.htm Is what I did.
I added an extra 2 x 8 and some wheels to move them around. These ramps are not cheaper and weigh more than Rhino Ramps, but are MUCH easier to drive up on.
Old Apr 15, 2006 | 06:00 PM
MeToo's Avatar
Interesting... that is basically what he has been doing so far....
Old Apr 15, 2006 | 08:05 PM
Barry Gross's Avatar
that's the same type ramp i built a couple of years ago even before i got my 8. i used 2X6's and this ramp system has worked with dodge trucks, little toyotas and my 8 after the dealer does the first oil change.
Old Apr 15, 2006 | 11:40 PM
Hammer's Avatar
Go REDSKINS!!!!!
I have these same ramps (Rhino, from WalMart), and they work fine for me. I basically only use them when I'm changing my oil or removing the front bumper for whatever reason. I've never had any problem with them sliding on me. I guess it depends on how smooth the floor you are working on is. I use them in a standard asphalt driveway.
Old Apr 16, 2006 | 06:44 PM
stickman's Avatar
I have a pair of molded plastic ramps from Advance Auto Parts; they are low and have a high capacity. They do tend to slide but I stop that by putting some tool box rubber liner under them.
Old Apr 16, 2006 | 07:23 PM
NgoRX8's Avatar
I'm guna have to get some rhino raps or blocks. I can't lift my car up from the front or side...
Old Apr 16, 2006 | 08:54 PM
Spin9k's Avatar
Better solution, get one of these (you can find much cheaper than this too - mine was sears and was ~$180), you can lift the front, back or either side, then put some jack stands under it... and it's easily portable. A bit more but worth it...
http://www.toolsusa.com/viewitem.as...jacks&WT.srch=1
Old Apr 16, 2006 | 08:58 PM
NgoRX8's Avatar
aww.. make sure your car is higher than 3.5 inches. lol.
Old Apr 16, 2006 | 09:04 PM
juikster's Avatar
Im 8 drifting on a budget
I have some cheap *** ramps and use 2x8's 5ft. long to up my front end which is fairly low and works fine,though I don't have a solution yet to lift the sides because of the skirts, but once the fronts in the stratosphere I use my cheap *** roller jack for the side lift, which also works ok. I guess its a matter of choice
Old Apr 16, 2006 | 09:13 PM
yiksing's Avatar
the giant tastetickles
Just stack some planks or get 4 hydraulic jacks
Old Apr 17, 2006 | 06:55 PM
stickman's Avatar
I have trained my rx8 to sit up on command. Roll over and play dead are two things I am not going to teach it.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
harithac
Sep 13, 2015 08:03 AM
poppinparker
Aug 10, 2015 09:20 AM
i3man
30
Dec 10, 2004 04:27 PM
flatso
15
Mar 30, 2004 12:23 AM
