Cel Is On...ttok It To Autozone And I Got No Readings From Programers? Help
Old Mar 13, 2006 | 04:25 PM
dova's Avatar
Angry Cel Is On...ttok It To Autozone And I Got No Readings From Programers? Help
Im Going To Disconect The Batterie. \
Is There Any Risk Of Messing Something In The Car Pcm?
Any Comment Pls Help?
Old Mar 13, 2006 | 04:42 PM
Glyphon's Avatar
脾臓が痛みました
Nope. but disconnecting the battery won't accomplish what you want. you're cel will still be there, and you'll have to reset your dsc.
Originally Posted by manual p. 5-22
If the battery is disconnected, the DSC
will be inoperable. In this case, the DSC
OFF indicator light flashes and the
TCS/DSC indicator light illuminates.
To make the DSC operable, do the
following procedure.
1. Turn the ignition switch to the ON
position.
2. Turn the steering clockwise fully,
then turn it counterclockwise fully.
3. Make sure the DSC OFF indicator
goes off.
4. Turn the ignition switch to the OFF
position, then turn it to the ON
position again.
5. Make sure the TCS/DSC indicator
light goes off.
If the TCS/DSC indicator light and the
DSC OFF indicator light remain
illuminated even after turning the
ignition switch to the ON position,
consult an Authorized Mazda Dealer.
Old Mar 13, 2006 | 04:47 PM
Go48's Avatar
AutoZone people may be trying to read the code with a non CAN bus reader.
Make sure your gas cap is tight before you clear the PCM. That may be the cause of the CEL. If the CEL comes back, take the car to the dealer to have them read the DTC code(s).
You'll have to calibrate the DSC, reset the clock and reprogram the radio buttons after you reattach the battery cable. See the owners manual on how to do that.
Old Mar 14, 2006 | 12:23 AM
dastallion951's Avatar
or what u can do is this, go to a local shop n or dealership non mazda, n have them use a microscanner, generic would work has in my case, if its generic it should read off the DTC, then dependin on what urs is, then u can go from there if its small problem u can repair, or take to a dealership for warranty work.
Old Mar 17, 2006 | 08:40 AM
dova's Avatar
no is not out of warranty, i work from 630am to around 7pm by than dealerships is closed. i was coming from work and autozone was open and i needed a quart of oil hey thanks guys ... today i got to take the car in i went late to work and got a rental from dealership... a neon...
Old Mar 17, 2006 | 08:34 PM
dova's Avatar
i got the car back today. the car had a leak on the evaporative emission system, they replace they replace the evaporative emission system. the leak was real small... i was real please with the service ... but man that neon was a piece of **** it had 25000 miles only but felt like if it was going to come apart...
Old Mar 18, 2006 | 01:59 AM
that would be a bad gas cap...
Old Mar 18, 2006 | 05:56 AM
Go48's Avatar
^^^ Yup! Fancy words for a non-sealing gas cap.
BTW, it is really obvious how pampered many of us have become when we complain about a FREE loaner car some of the dealers provide. Maybe walking would be preferred?
Old Mar 18, 2006 | 05:59 AM
not free loaner cars, part of the deal you signed up for. i got a sentra.
it sucked.
RevMeHarder
Jun 1, 2026 02:30 PM
Eraser
Aug 11, 2023 11:31 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
Forevermore
Sep 20, 2015 01:04 PM
