my grounding kit results
Old Mar 11, 2006 | 08:26 PM
olddragger's Avatar
say what you will but after I installed a e bay grounding kit my car does idle smoother and the rpms do not drop when I load up the electrical system. I also discovered that the grounding points on the body were on top of paint.
olddragger
Old Mar 11, 2006 | 08:33 PM
tiggerlee's Avatar
May Cause Anal Leakage
Is there any warranty issues with a grounding kit? I mean would the dealer give you a hard time if they see you have one installed?
Old Mar 11, 2006 | 08:37 PM
NgoRX8's Avatar
Take a pic for us.
Old Mar 11, 2006 | 08:55 PM
Labop's Avatar
olddragger
WEH!?
Meaning that the factory grounding points were painted over before the grounding wires were attached? If so, that's interesting.
Old Mar 11, 2006 | 08:58 PM
Nemesis8's Avatar
Bigus Rotus
Grounding kits are a must for helping the electrical on this car. The bolt threads that go into the car frame/body are not painted though.
Old Mar 11, 2006 | 09:18 PM
Ole Spiff's Avatar
Some pics and more info would be appreciated. Would it have made a difference to clean the paint off the stock ground points or is this "kit" necessary for a good ground?
Old Mar 11, 2006 | 09:34 PM
Petrus's Avatar
v e i l o c i t y
The ebay grounding kits are ridiculously cheap, so who cares if they work or not?
Seriously.... If they ebay kits work, why buy one from R Magic or Amemiya for 10 times as much... I doubt they are 10 times better.
But lets see some pics of it!!!
Old Mar 11, 2006 | 09:48 PM
olddragger's Avatar
Sorry guys ,
no digital camera. The grounding points on the engine where of course not painted. But the others one on the drivers side fender, two on the passenger side fender and one a little left on the airbox floor where all painted. True the bolts/threads were not, but the connector were all resting on paint. I sanded down through the paint and primer.
Nothing magical about the install. Just follow your common sense--cost $25 and the cool looking wire add a little bling. Cant go wrong imo.
olddragger
Old Mar 11, 2006 | 10:00 PM
expo1's Avatar
He's as bad as Can
Most of these kits install the same way. Mine was about $80, but I didn't get it from EBay it'a 4 AWG by the way.
Attached Thumbnails my grounding kit results-100_3313-small-.jpg   my grounding kit results-100_3314-small-.jpg   my grounding kit results-100_3315-small-.jpg   my grounding kit results-100_3316-small-.jpg   my grounding kit results-100_3317-small-.jpg
Old Mar 11, 2006 | 10:06 PM
expo1's Avatar
He's as bad as Can
Two more pics and I found where I got them and that I paid $75.00 for them. I didn't notice anything much different after putting them on, but it was a long time ago. All I can say Is I have 58,000 miles and very little problems with my 8. Ground Fusion
Attached Thumbnails my grounding kit results-100_3319-small-.jpg   my grounding kit results-100_3320-small-.jpg
Old Mar 11, 2006 | 10:21 PM
Labop's Avatar
expo1, you left the stock groundig kit installed and put this one on top of it?
Just wanted to make sure that was what I was seeing.
Old Mar 11, 2006 | 10:30 PM
expo1's Avatar
He's as bad as Can
Yes, Added this kit to the OEM. The instructions that came with it didn't say to remove a thing. I must have put on 40,000 miles on it since the install.
Old Mar 11, 2006 | 10:35 PM
StealthTL's Avatar
Metatron
Talking If one is good.....
....two cables to each point must be BETTER, right?
Didn't make any difference, that I could see.
....but it sure was cheap!
The red is to blend in with the car, but #1 son pointed out the error of putting two massive red cables to the ground on the battery!
Blacked them out, and marked the positive red.
S
Old Mar 12, 2006 | 10:26 AM
olddragger's Avatar
I wonder if anyone has dynoed before and after with a grounding kit on the 8. It would be very simple thing to do. Just unhook it from the battery and reattach for the 2nd run. I am wondering if it could possibily help the high rpm stutter we sometimes see on the dyno charts. I know the coils are overworked but again ????
Olddragger
Old Mar 12, 2006 | 09:08 PM
UnstoppableDrew's Avatar
Heck you can probably get everything you need to roll your own at Home Depot. How many points are there to connect ?
Old Mar 12, 2006 | 10:20 PM
Spin9k's Avatar
Momentum Keeps Me Going
Yes and no. Yes you can get something you can use, but no it's not the same as you get, e.g., with something like this http://www.angelfire.com/electronic2.../moreinfo.html where the wire is 2000+ strands and connectors are better
HD's wire is very, very stiff and difficult to work with, place, and route in the engine bay...I know... I bought some 4 guage and tried. No fun....also the wire & connectors you can get at HD are either copper or aluminum....subject to oxidation & corrosion respectively. This kit comes w/SS bolts and washers to replace the stock ones.
Saving maybe $20 or $30 on a mod that could be done so much better for just a bit more is arguably penny foolish.... but then again so are the gains.
There are 6 wires in this kit above, but I found a couple more points I connected for good measure for whatever good it does. Probably has more benefit as the car gets more miles, I found some corrosion on some of the OEM connectors.
Old Mar 13, 2006 | 08:18 AM
Wow, $56. That is SO not worth rolling your own. My Home Depot comment was based more on having seen lots of $100+ kits from various vendors. Thanks for that link, I think I'll be getting a set of those.
Old Mar 13, 2006 | 08:48 AM
none of those kits seem to hit the coilpacks, this one seems a bit expensive since that's all it is ...
http://www.sromagazine.com/shop/prod...g815-6380.html
Old Mar 13, 2006 | 09:12 AM
Spin9k's Avatar
Who said guilding the Lily was cheap? That might make a nice addition to any grounding kit... if it does anything...
IOW....are our coils grounded through the mounting bolt? Doesn't look like it from the wiring diagram, but rather grounding seems to be done through the (B) wire on the E2 connector...am I right?
Old Mar 13, 2006 | 09:34 AM
I'm not sure as some coils have a 4 wire setup with a ground to the chassis and a ground back to the ECU box, the RX-8 coil wiring is only 3 wire so I'm not sure if the coil mounts them selves host an internal ground down to the plate, you'd really have to disect a coilpack to find out
Old Mar 13, 2006 | 09:56 AM
Spin9k's Avatar
This is what I refered too....
Old Mar 13, 2006 | 11:52 AM
I know, that is what I replied to ...
Old Mar 13, 2006 | 05:57 PM
r0tor's Avatar
any comments on the quality of the $56 kit?
Old Mar 13, 2006 | 06:02 PM
Spin9k's Avatar
Excellent! Highest quality wires, thick but flexible (I got red), SS bolts and washers replace junk OEM bolts only, 6 4g wires, precut, CD-install manual, platinum dipped connectors. Nothing but the best for my 8 !
Old Mar 13, 2006 | 06:20 PM
r0tor's Avatar
i guess i'll invest in some after my dealer is done with the new starter/battery which is backordered... didn't even ask for it, they are being proactive i guess -shrug-
