Nitrogen in my Tyres - or Air in my Head?
Old Dec 3, 2005 | 10:42 PM
mboptom's Avatar
At 48,000km and nearly 2 yrs old, I've just replaced my tyres with same type, Bridgestone Potenzas. Got them filled with nitrogen cause told "it's better"!
Is it just me, but I was expecting awesome handling just like when it was new, but the car seems to "float" more, doesn't seem to hug as sweet as before and seems jittery on the road. Still grips well, but don't have the immediate confidence as before.
Have I done the wrong thing? I haven't talked to mazda yet or BJ Tmart, thought I'd check here first for anyone with similar experience.
Michael
Old Dec 3, 2005 | 10:50 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Air is 78% nitrogen. And alot cheaper. Should try Helium.
Old Dec 3, 2005 | 11:26 PM
JonnyBoy's Avatar
Ive got the nitrogen air in my tyres too, it came together when i bought new tyres, dont think it will have any bearing on the perforamnce/handling. THe idea behind using pure nitrogen is apparently it doesnt leak as much as like using normal air.
Old Dec 3, 2005 | 11:32 PM
New tires are always "squidgy" when new.....they actually have better grip...and less tread block distortion when they are about 1/2 worn out. Thats why racers shave the tires.....for dry traction
Give them a chance to wear in a bit for a bit as well....the can really be slippery till you wear of the mold release and stuff
Old Dec 4, 2005 | 12:16 AM
takahashi's Avatar
I love this logic
Old Dec 4, 2005 | 12:29 AM
labrat's Avatar
Probably the main advantage of nitrogen out of a bottle versus air from the compressor is that it has less moisture in it - it's quite dry. When the air in the tyre cools, the water vapour can condense and the tyre pressure drops. If you fill your tyres in a very humid climate, this can make a bit of difference. Every 18mL of liquid water makes 22.4L of water vapour at normal temperature and pressure (this is a fact of physical chemistry). If you fill your tyres with dry nitrogen (or dry air), there will be less pressure variation between hot and cold. This is probably of interest to racing drivers where fractions of a second spell the difference, but for the rest of us punters, well, I'd say you'll never notice it.
As has already been stated, air is already 78% nitrogen. I'm not even sure whether pure nitrogen would leak at a slower rate, since there's not much difference in the size of the molecules. In fact, the atomic weight of oxygen (16) is a bit higher than nitrogen (14). Even when it gets down to the specific heat of the two gases, it's scarcely enough to make a difference.
So I reckon the nitrogen in tyres thingy is probably 98% hot air and 2% fact.
Going off topic ever so slightly, I think the best time to check your tyre pressure is first thing in the morning, before you drive off and the tyres warm up.
Old Dec 4, 2005 | 12:56 AM
auzoom's Avatar
Hmmmmmm.........
I was told by the guy that does my nitrogen that nitrogen will leak faster than air and the biggest benefit from nitrogen is that it doesnt expand like air does when the tyres heat up.
Andrew
Old Dec 4, 2005 | 02:21 AM
Hymee's Avatar
Race Steward
"Better" Hehehe - better for the tyre stores $$$$
Old Dec 4, 2005 | 02:36 AM
Gomez's Avatar
Shifty Bastard.
I had this discussion over twelve months back. Some guy claimed amazing performance benefits when using nitrogen in his RX-8 tyres....
Originally Posted by Gomez
Nitrogen is superior to air in tyres as it has a larger molecular structure. Think of your rubber tyre as a membrane with tiny holes in it. Some of the smaller oxygen molecules escape through it which reduces the tyres pressure. This leads to poor mileage, poor handling, and a lesser tyre life.
The nitrogen molecules, being larger, have a more difficult time negotiating their way through the membrane. Hence, a tyre filled with nitrogen only will maintain it's pressure longer. That's why nitrogen is better. But it is dearer, air is free. Buy some good alloy/metal valve caps and stop the loss of air through your valves. Your tyre pressure will be maintained at the correct pressure for longer and you will have all the nitrogen benefits for bugger all cost!
Look, rubber is not impermeable...rubber is porous. Why do rubber balloons filled with helium deflate quicker than balloons inflated with air? "Cos a helium molecule is smaller than an oxygen or nitrogen molecule, the main two components of air. The helium leaks through the balloon skin at a greater rate due to it's reduced molecular size.
Oxygen which makes up approx 20% of air has a smaller molecular structure that of nitrogen, which makes up approx 80% of air. If you put air in a tyre, then the oxygen component of air will be diffused through the porous tyre carcass at a greater rate than that of nitrogen. Ipso facto, a tyre inflated with pure nitrogen will hold it's pressure longer than the same tyre filled with air.
Read the whole thread here.
Old Dec 4, 2005 | 02:56 AM
EZZY's Avatar
cry me a river...
had done the Nitrogen inflation on my TT... to be honest, it doesnt do jack **** on normal traffic jammed daily communit.....
from what i have been told/read, it is lighter than air, due to less/no water content, and therefore will not expand.
it isnt supposed to leak when compared to the normal air.
the main advantage for doing that is if you will be doing lots of long distance driving.....
BJ T-mart charged 20 buck for 4 back in 2003..... and i traded it in for the 8 about 2/2.5 months after
Old Dec 4, 2005 | 11:15 AM
unless they pulled a vacuum on the tire and eliminated all the air in the cavity before inserting N2 you probably aren't much better than using air, and over time O2 will actually osmosis through the sidewall, which isn't as solid as you think and nature can't stand an imbalance. And you will eventually need to add pressure for the same reason, what are you going to do then, whip out your charged canister of N2? Moisture isn't the only thing responsible for a a pressure change when hot/cold, you still have the General Ideal Gas Law to contend with PV=nRT
FWIW, helium is even worse ... it's a racing deal and a racing deal only i.e., short term and high maintenance.
Old Dec 4, 2005 | 12:52 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Yeah Fick's second law is a bitch.
And the He suggestion was facetious.
Old Dec 4, 2005 | 01:44 PM
takahashi's Avatar
And the He suggestion was a facetious.
At least you will speak funny when you let the air out to lower the tyre's psi.
Old Dec 4, 2005 | 03:12 PM
auzoom's Avatar
Hmmmmmm.........
HA HA...Synical bastard
Andrew
Old Dec 4, 2005 | 08:44 PM
xxup's Avatar
Funny I seem to remember that most of the air we breathe anyway is Nitrogen...
Old Dec 4, 2005 | 09:19 PM
Hymee's Avatar
Race Steward
Yeah - 78%, apparently. So if we put 2 atmoshperes pressure or air in it, does that mean it end up at 156% nitrogen? j/k Hehehehehe.
Old Dec 5, 2005 | 06:40 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
There is three total atms (cause there is one atm in the tire before you start to fill it), 2 gauge. so that would be 234%
Old Dec 5, 2005 | 01:46 PM
Hymee's Avatar
Race Steward
Dang, I hate it when I get the math wrong. :p
Old Dec 5, 2005 | 02:47 PM
KYLiquid's Avatar
Oil Injection
nitrogen = pro teams use it cause it contains less water wapor, it expands less than air, and provides a more constant air pressure.
remeber this is in a place where every 1/100th of a sec can mean a win or a loss, and gain or lose you tens of thousands of dollars.
On the street i think its pointless to pay extra, if it comes with the package then who cares..
Old Dec 5, 2005 | 04:59 PM
labrat's Avatar
You can get the same effect out of dry compressed air, however, it is more convenient to get dry nitrogen, since it is produced during the separation of oxygen and nitrogen during the liquifaction process. The water vapour gets frozen out first.
There's insufficent difference in the physical properties of nitrogen and air (78%N2, 22%O2) to make any measurable improvement. It's the water vapour which is the problem.
JimmyBlack
273
Feb 10, 2020 10:23 PM
Azki23
Jun 27, 2018 03:48 PM
WranglerFan
Nov 5, 2017 09:35 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Forevermore
Sep 20, 2015 01:04 PM
