Dyno Results Compilation
Old Nov 21, 2005 | 12:27 PM
Xyntax's Avatar
THREAD KILLER
Post Dyno Results Compilation
I'm starting one since everyone keeps asking for it and nobody's stepping up to create a dyno thread. So since I'm starting this, here are the rules: <edited per dmp's suggestion>
1. Post as much detail as possible about the dyno session (i.e. Dyno machine used, Ambient temp, Altitude/location, etc.)
2. Post your results in HP/TQ format (SAE corrected if possible)
3. Post your charts if you have them.
4. Post your car's modifications.
5. If your reply does not include any of the four, please do not post. This thread is for dyno results only. No questions or comments allowed.
Here's my dyno results:
Session: Mustang Dyno, taken on February 2005, Bay Area California.
Results:
145 HP 112 TQ - stock
156 HP 116.3 TQ - CZ Stage 1.1
Link to charts: https://www.rx8club.com/showpost.php...2&postcount=35
Session: Mustang Dyno, taken on August 2005, Bay Area California.
Result:
188 HP 125 TQ - REVi intake/CAI, Hot leading spark plugs, Custom CZ map
Link to charts: https://www.rx8club.com/showpost.php...74&postcount=1
Old Nov 21, 2005 | 12:51 PM
dmp's Avatar
dmp
RX8 and a Truk....
How about providing context by listing the modifications (if any) to the cars?
1. Dynojet Dyno, Feb 2006. About 50 degrees, Altitude about 250 feet, CarbConnection, Kirkland WA. RacingBeat Exhaust, REVi + Cold air duct
in-car vid
http://www.d-mphotos.com/images/rx8/...thgeardyno.wmv
Old Nov 21, 2005 | 05:48 PM
sticky
Old Nov 22, 2005 | 09:50 AM
Brice-RX8's Avatar
I know you said don't post any comments but I do have one and think is rather important. You are welcome to delete this after you read it.
You might want to have what gear the dyno was run in as well, as I would think anything less than 5th (1:1) ratio would make the results not as accurate.
Old Dec 21, 2005 | 06:27 PM
Marietta 8's Avatar
good idea
Old Dec 24, 2005 | 06:37 PM
Beodude123's Avatar
You know what I have just noticed? (I haven't been on here too long, and haven't really looked at any dynos) At every single rpm cross over point (for intake ports and fuel injectors) there is a dip right before it. I don't know if CanZoomer or the Greddy can control it, but if so, people could program them to open the ports a little earlier to avoid three dead spots in your powerbands.
Old Jan 12, 2006 | 07:37 PM
sburkett's Avatar
Stock except for drop in air filter (Green Filter) and straight pipe from factory cat/presilencer back. Motor was fresh mid season last year. Dyno from my new Dynapack 3000, oh yes, we will be doing some tuning this winter.
This was in fifth gear, but it's really not the gear that matters so much as the length of the "pull". This was a 12.5 second pull. The slower the pull the higher the horsepower since you aren't accelerating the drivetrain as fast. I can do basically a "brake" test, and was able to get 192 hp holding the car at 8200 rpm.
Steven
Old Jan 13, 2006 | 10:23 AM
dmp's Avatar
dmp
RX8 and a Truk....
can you explain that further? Are you slowly rolling onto the gas? Backing off and holding the tach at 8200?
Thanks.
Old Jan 13, 2006 | 12:39 PM
sburkett's Avatar
Neither, the Dynapack is capabable of holding the car at a set speed. I put it in "speed" mode, set the target to 8200, go to wide open throttle, and the dyno pushes back as hard as it needs to to hold at 8200. So there's no spinning up of the drivetrain to suck horsepower. It's a nice feature of the dyno designed for tuning in "real time" at a specific rpm.
Steven
Old Jan 16, 2006 | 12:11 PM
Mazdastrib's Avatar
Stock dyno done yesterday. Thin air so altitude correction made it +1000ft.
Made 179.45 hp
128.21 ft/lbs.
Old Jan 28, 2006 | 10:27 PM
Hymee's Avatar
Race Steward
Here is an independant "before and after" done yesterday on an RX-8 in Sydney, Australia.
Before = Stock
After = Hymee Catback :D
FYI:
123 kW = 165 HP
135 kW = 181 HP
Dyno runs here are typically done in a gear not to exceed 200 km/h, so we generally use 3rd gear on RX-8's.
For full discussion, please see https://www.rx8club.com.au/forum/viewtopic.php?t=881
Cheers,
Hymee.
Old Jan 29, 2006 | 10:50 AM
BRealistic's Avatar
Ok, I hate to ask this here- but I was just looking at the Wikipedia RX-8 page.
http://en.wikipedia.org/wiki/RX-8
And there it says:
"Mazda seems to be aware of this issue and may be tinkering with the engine's software management behind the scenes. Mazda has released several PCM flash upgrades since the initial release of the model. Currently, some US owners have dynoed at over 190 and 200 wheel horsepower (140 and 150 kW), an improvement over the initial figures."
Ok, where are these people making that much power at the wheels with a stock RX-8? I want to know. And I want to know what engine flash they have.
Old Jan 29, 2006 | 11:34 AM
Nemesis8's Avatar
Bigus Rotus
Nemesis8 Results
1. Dynojet 1-21-06. 63 Degrees, 47% Humidity, Altitude 250 feet, Seattle
2. 200.8 RWHP / 148.6 FT-LBS (SAE Corrected to 196.77 / 142.75)
3. Below
4. REVi, Ultra Plug Wires, Lineage Grounded, UR Pulleys, MS Flywheel, RP Supercat Midpipe, RB REV8 Dual Catback, CZ with Slight Fuel Mods Only
More Info Here
Attached Thumbnails Dyno Results Compilation-rwhp_torque_web.jpg   Dyno Results Compilation-rwhp_afr_web.jpg
Old Jan 29, 2006 | 01:03 PM
Spin9k's Avatar
Momentum Keeps Me Going
spin9k, DynoJet, NH 2005 - All conditions for run are shown in the graphs. Shows comparison of a 3rd vs. 5th gear pull done minutes apart. Tires were 235/40/18 therefore ~2.2% smaller than stock, only other mod was CorkSport Exhaust.
Old Feb 7, 2006 | 05:10 PM
whenson417's Avatar
181.2 rwhp on a stock car (33k miles) with the exceptions of a grounding wire kit and revi, and duct intake. Looks like I could use some new plugs.
Old Feb 7, 2006 | 05:35 PM
L8APEX's Avatar
Smooth Criminal
my chart shows two pulls, they wre the best two pulls, from two sessions.
the first was in May '05, on a Dynojet, ambient temp was around 75, in Atlanta. Mods included: Revi Intake, and a custom exhaust, with stock wheels and tires. At the time of this dyno, I was on the "M" flash, and had 30k miles on the car, on the original plugs.
the second was from last weekend, same Dynojet, ambient temp was about 45, mods added :RB Duct, new plugs, new coils, new battery, and 245/40/18 tires, so about 1% smaller than stock. Now the car has 40k miles on it, and is on the current "R" flash.
Last edited by L8APEX; Feb 7, 2006 at 06:47 PM. Reason: Forgot information pertinent to dyno runs.
Old Feb 7, 2006 | 07:51 PM
SilverEIGHT's Avatar
CONSTANTS:
- 2005, 6MT, GT
- Mods (performance): RB Exhaust, ACT Prolite Flywheel, RED LINE Synthetic Oils
- Dynojet (Dynolab Inc. Marietta, GA)
- Same dyno operator
- 5th gear pull
SESSION #1: RED, 01/21/06
Milage: Approx. 18,000
Ambient Temp: Low to mid 60's
Session pull recorded: #3
Results: Very erratic and defined loss of power after final port opening
SESSION #2: BLUE, 02/04/06
Milage: Approx. 19,000
Ambient Temp: Mid 40's
Additional Mods: New spark plugs (due to flooding issue) and Green Air Filter
Results: Smooth with increased power
Note: Same session as "whenson417" and "L8APEX".
Maximum HP difference: 11.8 over first session
ASSUMPTION:
Approximately 28 HP gain at the peak due to new plugs.
Old Feb 18, 2006 | 12:13 PM
Nemesis8's Avatar
Bigus Rotus
Originally Posted by Sapphonica
Did you dyno +20 HP before/after with the 'R' flash?
Also, in what RPMs do you get the HP gains?
As we all know, this car is gutless down low...the 'torqueless wonder' as someone on the group said. This lack-o-torque negatively affects drivability under part throttle conditions.
Do your NA mods do anything noticeable for torque?
After the "R" flash and gains were up high and yes I have more torque from 134 to 142 ft/lbs.
Look at post 13 above
Old Feb 18, 2006 | 01:46 PM
Nemesis8's Avatar
Bigus Rotus
I think the whole ignition issue is going to haunt us all one day.
Old Feb 20, 2006 | 07:39 AM
jacksonjw81's Avatar
Is there anyway to get some serious power out of the 8, say 300 WHP or more?
Old Feb 20, 2006 | 07:42 AM
L8APEX's Avatar
Smooth Criminal
without blowing the engine? try the major horsepower upgrade section, los of discussion about it there.
Old Feb 20, 2006 | 07:50 AM
Hummmm, hope not. Wonder what the high milage guys are dealing with when it comes to these issues? Wish some of them would chime in here.
Old Mar 11, 2006 | 07:56 PM
Dyno date: 03/11/06
Changes from previous run (see post #17)
Session #3:Blue
Milage: Approx. 20,500
Session pull recorded: #4
Ambiant temp: approx. 70º F
- New OEM plug wires
- RB Revi intake with Cold Air Duct
Old Mar 11, 2006 | 08:21 PM
olddragger's Avatar
so silver you got a little more hp going on now-- diferrant days--differant results sometimes but you are on the right track.
your coils ok?
olddragger
6 more days !!!!!
Old Mar 11, 2006 | 08:42 PM
OD, I've wondered about the coils. Sutherland said they were fine. The erratic hi end is acting up again. I thought my new plugs took care of that. I ran 4 times today. Runs 1 & 2 looked much more erratic than the one above. Run 3 was a reset of the ECU. I figured, what the heck, even after our discussion at the previous session. It proved beneficial to me as the 4th run was smoothest.
