throwing codes like crazy
Old Oct 31, 2005 | 05:48 PM
r0tor's Avatar
got a good ol check engine light today...
MIL is ON Stored Trouble Codes Present
Misfire Monitoring Complete
Fuel Sys. Monitoring Complete
Component Monitoring Complete
Catalyst Monitoring Incomplete
Evaporative System Monitoring Incomplete
Sec. Air System Monitoring Incomplete
O2 Sensor Monitoring Complete
O2 Sensor Heater Monitoring Complete
Fuel Sys1-Open Loop Driving
ECU #=10
MIL is ON
Vehicle Reports 1 Stored Trouble Code(s)
TC1 -P2070
P2070 Intake Manifold Tuning (IMT) Valve Stuck Open a)
Pending Code 1 -P0020--P0020 a) "A" Camshaft Position Actuator Circuit Bank 2
Pending Code 2 -P7000--Trouble code definition not found
so... umm anyone have an idea how i went from never having a code to 3 codes instantly?
I tried resetting the codes and resetting the computer and they cam back right away
Old Oct 31, 2005 | 05:50 PM
r0tor's Avatar
oh, and anyone think these could be even remotely caused by a CZ and an RP supercat??
Old Oct 31, 2005 | 06:11 PM
zoom44's Avatar
the CEL is actually for SSV but same thing really. so you have the last valve in the sdais stuck open. the other 2 are not correct codes. what scanner are you using?
Old Oct 31, 2005 | 06:13 PM
have you changed the intake??? i got a code like that after changing to the revi. code did not come up by itself, but after a more important code.
Old Oct 31, 2005 | 07:25 PM
r0tor's Avatar
a) using a canscan.... and yea, i don't see the other 2 codes listed in the service manual... and i sure as hell shouldn't need to worry about camshafts -shrug-
b) haven't changed the intake... only installed a supercat a week ago and reprogrammed my cz box yesterday
updated - i just pulled my cz box thinking i'll be taking it to the dealer soon. Took it for a spin and the CEL went off. Not sure if maybe i have a bad connection in the box, or since the CEL takes 2 driving cycles if it will come back on tomorrow morning (but that shouldn't be the case as i didn't kill the battery or reset the codes last trip). We will see....
Old Oct 31, 2005 | 07:34 PM
zoom44's Avatar
well it could mean eshaft position sensor. check with harrison on why it would give those weird codes. could have 2 isues- stuck valve and canscan problem. or it could be a pcm problem
Old Oct 31, 2005 | 07:48 PM
r0tor's Avatar
would it still run smoothly if it was the e-shaft position sensor going? I would think i'd be getting misfires from that?
Old Oct 31, 2005 | 07:56 PM
sco's Avatar
sco
I've seen false misfire codes when there have been problems with the eccentric shaft position sensor, but still running smoothly.
Old Nov 1, 2005 | 06:38 AM
r0tor's Avatar
well, the SSV code is back... looks like i'll be calling up the dealer
Old Nov 2, 2005 | 06:47 PM
r0tor's Avatar
I talked with Harrison and the 2 strange pending codes were just some strange unknown error... doesn't show up now with my old software or my new software he just sent me -shrug-
mdl0209
May 23, 2019 05:46 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
alming1132
Sep 30, 2015 11:30 AM
pjwermuth
Sep 28, 2015 11:36 PM
