View Full Version : Tool to push in rear brake caliper cylinders?
RX8SpdDmn 09-25-2005, 01:23 PM The rear calipers on our cars require the cylinders to be turned as they're pushed back in. It's and incredible P.I.T.A.
Is there a special tool that makes this easier???
If so, where can I get it?
cLLcLe 09-25-2005, 01:24 PM Any local auto parts store (Auto Zone, Pep Boys) should have it. They will know what you are talking about so just go and get it.
expo1 09-25-2005, 01:54 PM Like this one, works with a 3/8" drive.
RX8SpdDmn 09-25-2005, 02:47 PM Thanks! Does the cylinder have to be compressed at the same time, or will rotating it draw it back in?
StealthTL 09-25-2005, 02:49 PM Just screwed in. ;)
S
uh8medoncha 08-13-2007, 05:57 PM Just got finished replacing my pads. EBC Green Stuff. Box said they come with shims and they had them on there so I didn't have to use the stock shims. I would add one thing for the front brakes u may pliers or a wrench to prevent the female part of the 14mm bolt from spinning instead of the bolt coming loose. It was really easy actually. I bought this caliper depressor tool by the same company that makes the rear caliper turning tool. Look for it in the same area you get the caliper tool. It was 12 bucks but well worth the ease.
Brettus 08-13-2007, 06:05 PM I think I used a pair of long nosed pliers when I did mine .....
dillsrotary 08-13-2007, 08:46 PM I think I used a pair of long nosed pliers when I did mine .....
As did I, works like a charm.
woodysjh 04-03-2010, 10:50 AM I turn and turn and turn and these pistons on the rear do not go in, what do you do to get them to go back in?
Charles R. Hill 04-03-2010, 11:53 AM More pressure as you turn. It works.
ArXate 04-03-2010, 12:06 PM If it's your first time, like it was for me, still a PITA.
Bigbacon 04-03-2010, 12:17 PM I used needle nose pliers in order to turn mine to get them back in.
ShellDude 04-03-2010, 01:04 PM I'm spoiled... I have the universal caliper tool you can get from harbor freight to do mine. A C Clamp (as well as methods already mentioned) should work too.
nycgps 04-03-2010, 01:09 PM I turn and turn and turn and these pistons on the rear do not go in, what do you do to get them to go back in?
Release your hand brake, and open the MC cover.
if it goes in, well, check and see if the MC overflows (if you add fluid to it before). if it did, rinse the area with water (close the MC cover/lid first) for a couple of minutes, cuz Brake fluid eats paint. and Water is Brake Fluid's enemy.
if it still won't go in for some odd reason, open the bleed screw and Im sure it will go right in.
but then remember to bleed everything again.
Huey52 04-03-2010, 01:53 PM A 'C' clamp works for the front calipers (or a large set of slip joint pliers), but you need either the el cheapo Autozone ratchet attachment or much better the Harbor Freight caliper tool kit you have for the rotation necessary. Needle nose pliers just don't give you the torque you need. The right tool for the job.
edit: like this one: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40732
ShellDude 04-03-2010, 02:24 PM That's the one... It's great kit to own... right up there with an impact wrench!
dannobre 04-03-2010, 02:44 PM If you open the bleeder screw it goes in much easier as well....
snarlingbeast 10-06-2010, 04:27 PM This one works well. $11.99 at Pep Boys.
http://i204.photobucket.com/albums/bb205/kevin_scott_mc/IMG_0021_.jpg
04Green 10-06-2010, 10:25 PM ++ for HF tool. Autozone will rent the same one, but it is 3X to buy. the ones on my 04 were a cast iron bitch w/o the tool. Would have been the same with the cube. Could not generate the force needed. I rented the AZ one, and ordered the HF one (3 cars, will use it), already loaned it out once.
